Question about KitchenAid KSRG22FK Side by Side Refrigerator
The Water dispenser is leaking water
OK so the water dispenser seems to not be functioning.  Water is steadily flowing from the dispenser. there does not appear to be a leak in the back of the refrigerator from the tubing, it all is coming from the dispenser.  Even putting the lock on the use of the dispenser does not help.  What should i try to do?
  • elianna Jan 21, 2008
    My Kenmore is doing the same thing. I can't even get the constant and fast drip drip out of the water dispenser tube to stop when shutting off the thumb valve under the sink.
  • Anonymous Mar 19, 2014
    Water Tank Dispenser
  • 473 Answers
It's either a bad water valve or the switch in the dispenser is stuck.
Posted on Oct 20, 2007
GE profile refrigerator ice maker not working
Ice dispenser doesn't work
  1. Dispenser control board
If the ice dispenser is not functioning at all the most likely cause is going to be the dispenser control board. The dispenser control board governs the major portion of the systematic functions of the dispenser and is less likely to be the issue if only certain components are malfunctioning. If the dispenser control board is at fault, it will need to be replaced.
  1. Water inlet valve & low water pressure from house supply
If the ice dispenser on your refrigerator is not working properly, one of the first things to consider as an issue is the water pressure to your appliance. The ice dispenser cannot properly function with a psi less than 20. If psi is appropriate, proceed to replace the water inlet valve to correct the issue. You may also be dealing with low household water pressure. This low flow can be examined by using a water pressure test gauge. Once the household water pressure is resolved, you can double check your refrigerator connection to ensure it is now flowing properly and that the ice dispenser is functioning.
  1. Water tube in door is frozen
If the ice dispenser is not working on your refrigerator, the issue could be a frozen water supply tube located in the door. Although this may be a tricky problem to locate, the first thing to do is find a connection point in the tube. After this has been found, attempt to blow air through the tube. If the air flows freely through the tube, it is not frozen and this is not the issue. If it does not, the tube is frozen and needs to be removed to thaw out. As it thaws, attempt to ascertain why it froze and correct the positioning of the tubing to prevent the issue from occurring again in the future.
  1. Dispenser switch
If the refrigerator ice dispenser is not working properly you could be dealing with a defective dispenser switch. Activated by the dispenser actuator, the switches are responsible for numerous actions including ice cube disbursement, type of ice, and water controls. The switch can be tested using an ohm meter and should be replaced if it does not reveal continuity.
  1. Door switch
If the refrigerator ice dispenser is not working, the functionality of the door switch can be inspected. This switch is responsible for turning on the light in the freezer and simultaneously turning off the ice dispenser when the freezer door is opened. If this switch malfunctions, it will show no continuity on the ohm meter and will require replacement.
  1. Dispenser switch
  1. Door switch
Water dispenser doesn't work
If the water dispenser is not functioning at all the most likely cause is going to be the dispenser control board. The dispenser control board governs the major portion of the systematic functions of the dispenser and is less likely to be the issue if only certain components are malfunctioning. If the dispenser control board is at fault, it will need to be replaced.
If the water dispenser on your refrigerator is not working properly, one of the first things to consider as an issue is the water pressure to your appliance. The water dispenser cannot properly function with a psi less than 20. If psi is appropriate, proceed to replace the water inlet valve to correct the issue. You may also be dealing with low household water pressure. This low flow can be examined by using a water pressure test gauge. Once the household water pressure is resolved, you can double check your refrigerator connection to ensure it is now flowing properly and that the water dispenser is functioning.
If the water dispenser is not working on your refrigerator, the issue could be a frozen water supply tube located in the door. Although this may be a tricky problem to locate, the first thing to do is find a connection point in the tube. After this has been found, attempt to blow air through the tube. If the air flows freely through the tube, it is not frozen and this is not the issue. If it does not, the tube is frozen and needs to be removed to thaw out. As it thaws, attempt to ascertain why it froze and correct the positioning of the tubing to prevent the issue from occurring again in the future.
  1. Dispenser switch
If the refrigerator water dispenser is not working properly you could be dealing with a defective dispenser switch. Activated by the dispenser actuator, the switches are responsible for numerous actions including ice cube disbursement, type of ice, and water controls. The switch can be tested using an ohm meter and should be replaced if it does not reveal continuity.
  1. Water filter
If your water dispenser's flow is running slow check to ensure that your water filter is not clogged. If after checking you determine that the filter is clogged, simply replace the filter. Filters should be replaced every six months to ensure clean drinking water.
  1. Door switch
If the refrigerator water dispenser is not working, the functionality of the door switch can be inspected. This switch is responsible for turning on the light in the freezer and simultaneously turning off the water dispenser when the freezer door is opened. If this switch malfunctions, it will show no continuity on the ohm meter and will require replacement. Appliance Repair Help Troubleshooting and Appliance Parts
Aug 18, 2014 | GE Refrigerators
Why is my Water dispenser not working?
  1. Dispenser switch
  1. Water filter
  1. Door switch
If the refrigerator water dispenser is not working, the functionality of the door switch can be inspected. This switch is responsible for turning on the light in the freezer and simultaneously turning off the water dispenser when the freezer door is opened. If this switch malfunctions, it will show no continuity on the ohm meter and will require replacement. Refrigerator Repair Help Troubleshooting and Parts
Aug 17, 2014 | GE Refrigerators
Water dispenser is not working
The water flow needs to be checked,if the flow of water is very slow or no water is flowing then water dispenser will not dispense water.But water flow is checked ok then other possibilities like water valve and water line needs to be inspected.For more details.Click the link below:---
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
This should help.Thanks.Helpmech.
Oct 20, 2011 | GE GSL25JFPBS Side by Side Refrigerator
Have SDX23VW - water leaks from rear bottom when dispensing water; also, seems t/b leaking when water flows into ice maker (hear water flowing) & water dispensing not used.
Hello, Thank You for using FixYa. I will be helping you today.You have a crack in one of the water lines or the valve.Have someone press the dispenser while you find the leak in back.
Thank You and please rate my answer if it was helpful..
Jun 15, 2011 | Amana SXD524VW Side by Side Refrigerator
No ice and no water dispenser
Would have to talk you thru with chat .
Jul 17, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
The water dispenser will only work part of the time.
Ok, there is a water valve assembly(dual), that has solenoid functions that feed the ice maker and water dispenser as well. this valve is damaged and you will need ot replace it asap if possible.
The replacement of this dysfunctional water valve assembly will fix your issue.
May 30, 2009 | GE Profile Performance 25.2 cu. ft....
Low flow from water dispenser
hi, this can be because of the filter. when the water is flowing threw the filter, it is sent threw many channels inside the filter before it reaches the dispenser. this slows it down a bit. this is quite normal but, if it's slowed down to a dribble, i suspect a water valve malfunction or you may need to change the filter.
Mar 15, 2009 | GE GSH25JFR Side by Side Refrigerator
Water filter in fridge leaks
if the filter froze, its probably cracked the housing.
Jun 05, 2008 | Maytag MZD2766GES Side by Side...
KitchenAid KSRG22FK Side by Side Refrigerator Logo
601 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
