I bought a Gogear 4gb, battery was good only for 2 hours
I conected the smal spare plug to the computer & my mp3, leaved it for the whole night charging, how ever i haven't being able to turn it on again, it didn't work out, what would be wrong? is new , i charged and it's still not working, i tryied in another computer and same think, i holded on the slide to turn it and no way no light, signal, nothing , what would be wrong? would any body help me pls? Thank you.>Ana>
    Problem Solver:
  • 6 Answers
My bros had a disc with it and u have to install it on ur computer and repair the a go gear
Posted on May 22, 2009
When I plug my GoGear Vibe 16GB into the computer with its USB lead, all I get is a picture of an empty battery. I can't get any charge into it, so it doesn't do anything at all
This may be caused by a fault in the GoGear itself - however the first thing to do is try a different USB lead.
If you find that the same thing happens with a different USB lead I would advise you to leave the GoGear plugged in for at least 2 hours befor checking it again. The reason for this is that if the battery is extremely discharged the display will not show correctly on the GoGear exactly like you describe.
You should also connect the new USB lead to a different port on your computer to help rule out any problem with a failed charge from the computer itself.
If the problem remains after this then the unit is faulty and will need service attention.
Thanks for using FixYa.
Aug 13, 2011 | Philips Audio Players & Recorders
When I try to turn on the MP3 (Philips GoGear Mix) I see a symbol of a battery and then it shuts down. When I plug the MP3 to the computer it shows it is fully charged. What shell I do? Thanks
I have had a GoGear for a while and those things have horrible firmware and are very fragile. I have experienced the same issue myself, so I suggest leaving it plugged in for several hours no matter what the screen says to try and let it charge. It should charge up. If not, try charging via a usb wall charger, which should allow usage of the player while it charges.
Jun 01, 2011 | Philips GOGEAR SA6045 MP3 Player
Batterylife,GoGear Vibe 4GB how long between each charge, getting 5 to 6 hours.
The battery life is rated at 25 hours for audio and 4 hours for video. If the charge is not holding you can try ensuring device is secured while charging. If this does not work the battery is bad and should be replaced. This is not horrible news, batteries for the GoGear Vibe 4GB are only $10.00.
Aug 05, 2010 | Philips GOGEAR SA6045 MP3 Player
My son got a go geat 4GB mp3 player for christmas
Did you intially charge the battery for 6-8 hours before 1st using?
Jan 12, 2010 | Philips GOGEAR SA6045 MP3 Player
Battery wont charge
I would say leave it stay on then after its fully dead charge it up again . That should fix your problem if it doesn't leave a comment and ill try to help again.
Jan 09, 2010 | GPX Audio Players & Recorders
My Creative Zen Mozaic 4GB won't turn on
Use the reset button located on the left side. Worked for me!
Feb 05, 2009 | Creative Labs Creative Technology Zen MP3...
Lost cd software
www.usasupport.philips.com has the software - just enter your model #
Jul 21, 2008 | Philips GOGEAR SA6045 MP3 Player
Freezes and wont charge
Try repairing the device:
1) Open up Philips Device Manager (Start --> All Programs --> Philips) - if you don't see it, then re-run the installation CD or grab the "Device/Firmware Manager" from the Philips website
2) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
3) Disconnect the GoGear from the computer and turn the GoGear off (if you haven't done so already) - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new.
You may have to charge the device fully for 3 or 4 hours AFTER this process is complete.
-Tha Mp3 Doctor
Jan 31, 2008 | Philips SA5125/37 MP3 Player
Mp3 wont load fully
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Oct 06, 2006 | Philips GoGear HDD1850 MP3 Player
78 people viewed this question
 Grubhead
Grubhead
