Question about Heavy Machinery
Husqvarna 136 is not getting enough oil. Changed the pump, but it is not drawing it up to the bar
Husqvarna 136 is not getting enough oil. Changed the pump, but it is not drawing it up to the bar Why is there no tool expert catagory?
  • 448 Answers
What you can do is try taking the cap off of oil tank drain oil, take chain & bar off try taking compreesed air or air blow nosel in hole going to blow & if its clogged it should blow out of cap hole or there might be a hole in line but it might have saw dust in oil clogging oil from coming out
Posted on Jun 05, 2009
REPLACE CHAIN BAR STUDS 55 RANCHER
Tom, Check the attached links,instruction and guides on Husqvarna chainsaw, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Husqvarna rancher 55 chain bolt replacement
http://www.husqvarna.com/ddoc/HUSO/HUSO2002_USen/HUSO2002_USen__1140106-95.pdf
How to Change Chain on Husqvarna Chainsaw Model 445
How to Adjust the Oiler on Husqvarna 55 Rancher
Apr 02, 2016 | Husqvarna 36 41 50 51 55 136 141 154 254...
Chainsaw chain keeps getting tighter when using?
this is a sure sign of chain overheating , due to not enough oil to bar , this will eventually cause bar to wear down and chain to not stay on
ck your oil pump and oil tank for proper operation
Aug 25, 2015 | Husqvarna 435 - 16" 41cc Consumer Chainsaw
Can the chain oiler be adjusted on a 141?
No adjustment possible.
But that can be good news when you got good oil as you can run a longer bar and chain up to 20" The shorter the bar the more oil present on the chain and bar during operation
Jan 08, 2015 | Husqvarna 36 41 50 51 55 136 141 154 254...
Chain oil leakage
If its leaking straight out then its not a problem with the pump. The problem lies in the fact that its not making it to the pump, hence the leak. Now depending on the model the pump is often linked to the oil line via a little gromet. Check these parts all link up correctly and nothing has got damaged.
The picture shows the oil pump assembly on a Husqvarna 2542_9_2013_9_01_52_pm.jpg
Feb 09, 2013 | Husqvarna 36 41 50 51 55 136 141 154 254...
Chain oil leakage
To help you more please give us the model of your Husqvarna machine.
What is the recommended oil/fuel mix for Husqvarna 136 chain saw please?
40:1 is the recommended mixture for husqvarna chainsaws. Use husqvarna 2 stroke oil rather than the cheap types you get at car service stations as they will not protect your saw like the good quality oil.
Nov 24, 2010 | Husqvarna Garden
How do you adjust the oiler on a husqvarna 268 xp chainsaw
use the control screw on the oil pump
it is located on the top left side of the oil pump casing to the left of the sprocket with the chain and bar off
turn it anti clockwise the check oil output
( no chain and bar on ) if still not right try the other direction
and retry if still not putting out enough oil
may need to clean tank and pickup filter
check pump driver and drum , check oil oulet line
check oil pump itself - it could be worn or air is getting in on the oil inlet side and it not drawing oil
to get these pumps out remove clutch and drum , remove pump drinver
undo 4 x screws and remove pump assy plate
here is web site for parts
http://www.partstree.com/parts/?lc=husqvarna&mn=268+%281997-01%29
go to oil pump clutch you will see parts relationship
cheers hope it helps
Aug 11, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna chainsaw 440e - enough chain lube?
That seems low to me. Page 15 in your manual is the only oil discussion I found. Usually there is an oil pump adjustment reference somewhere. I didn't see one beyond return it for service on page 15. Are the chain and bar hot after cutting a while? I recommend you not get a longer bar without an oiler adjustment. I think the hand of the EPA has been here.
An IPL (exploded parts list) for a 440 can be found here:
http://weborder.husqvarna.com/order_static/doc/USA/2009/I09000/I0901018.pdf
There is no oiler adjuster listed. HTH
Lou
Might be a good idea to copy the IPL,
Oct 07, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Oil flow problem
had the same problem on my husqy 136. replaced oil pump, no joy. filled oil tank with brake cleaner fluid and left overnight then ran saw, this cleared blockage in oil feed pipe and everything is now ok.
Jan 07, 2009 | Husqvarna 450 e-series 18" Chain Saw
Bar oiling problem
Just a thought: Is it cold where you are? At this saw mill where it is my job to keep chain saws running, learned years ago that you cannot use "bar oil" in winter. Need thinner oil, like motor oil. ....preferably a "non-detergent" motor oil, plain 30-weight is OK, HD30W will work, but the HD part causes the chain to stretch more so than standard bar oil. The bar oil literally is so thick in cold that it stripped the worm gear out of a Poulan Pro oil pump (plastic gear, anyways, wasn't much to begin with.) But thought you may want to try thinner oil, if it is cold where you are. Oh yea we also have 2-Husqvarna 359's with 20-inch bar, and use thinner oil in winter. Our Husqvarnas have an oil adjuster located on bottom, on clutch side. Straight slot screw adjustment.
Nov 18, 2008 | Husqvarna Chain Saw 20" Bar
Heavy Machinery Logo
348 people viewed this question
Top Heavy Machinery Experts
Tom Chichester
Bill Boyd
ray gallant
Are you a Heavy Machinery Expert? Answer questions, earn points and help others
