Power fuse? or reset?
Westinghouse tv... lost power last night, tv came on then went out and cannot get it to turn back on
  • Televison & ... Master
  • 1,525 Answers
Hi is the tv totally dead. would need the model first to give you more information thanks
regards
shaun
Posted on Jan 04, 2014
snakehead
  • 1074 Answers
SOURCE: tv will not turn on
your tv needs to be repair again power supply problem or circuit.good luck.
Posted on Apr 04, 2007
  • 21 Answers
SOURCE: Plasma Tv turning off and turning right back off
Hi there, Im Kanth, i had the same problem, and i found a person in Mississauga, they fix all kind of problems in Plasma, they fixed my LG before a 7 months, its still running good, i came to know lots of ppls were having same problems, i sujest u to being the plasma to electronics @ Dixie and Britannia Mississauga, call them now 905 565 6595 or check there wesite for more info. http://dukeelectronic.com
Posted on Apr 22, 2008
Ajkill
  • 2035 Answers
SOURCE: Westinghouse Green Screen
You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
Posted on Jun 10, 2008
ginko
  • 19396 Answers
SOURCE: Tv wont turn on worked fine last night
If there is no power at all, then the problem is likely the power supply unit.
The PSU must be tested, then eventually replaced.
Posted on May 30, 2009
  • 8457 Answers
SOURCE: last night watching tv, picture cut off (black
Power supply board is dying not giving the tv correct voltage anymore.The power supply board,that the board power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Posted on Sep 10, 2010
Is there a reset button on tv? tv went out in a thunderstorm last night and will not come back on.
Hi Anne,
It is not a case of reset. The power supply section of your TV is damaged in the thunder storm. It is a common thing happening to TVs. Yes, sometimes, if you are lucky you escape with small damage like fuse and a few safety components. Otherwise you may have to replace the entire power board. Please consult some local TV tech,
Good Luck.
May 28, 2015 | Televison & Video
I have a panasonic TH-C42HD18. Last night a fuse in my fuse box flipped so I lost power to the tv. I reset the fuse (in the fuse box) but now My tv will not turn on. Everything else plugged in to that...
If you have no power light on TV ,then you must have a blowed Fuse on the power supply board.
Check Fuse and check board for Bad Capacitors they will be vented or swollen on Top.
1000uf 16v 2200uf 10v 3300uf 10v.
Jun 02, 2011 | Panasonic TH-C42HD18 42 in. Plasma TV
Had electrical storm last night. Tv shows the Westinghouse symbol, nothing else. This is when it is turned off. When you turn it on (from the tv, remote won't work at all), symbol disappears for 30...
If your TV has a reset switch on the back, use it. If not, Unplug the TV, hold the power button down for 30 seconds, let it go and remain unplugged for another 5 minutes or so.
Plug it back in, and see what happens. Try changing the inputs/channels/etc to see what happens. If you're still having this issue, Take your TV in for repair.
- Sidenote, a $25 power bar with built in protection curcuits are the easiest way to protect your equipment from this kind of thing, and quite a bit cheaper than forking over $300 for a new TV everytime there's thinder and lighting.
May 11, 2011 | Westinghouse 32" Flat Panel LCD HDTV
Won't turn on
The power supply module may have gone out, need to check and see if you do have 5vdc standby voltage at the power supply module, also check the fuse in the power supply.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=westinghouse+LTV-32W1
http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
http://s807.photobucket.com/albums/yy352/budm/Westinghouse%20LTV-32W1/
May 09, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
I purchased my tv 2 years ago. Watched it
Try leaving the TV unplugged for 30 minutes so theTV can reset itself.
If that doesn't work, most likely the TV has a power supply board is the problem. Or, it's just a fuse that blown inside the TV.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20. And most cases the new part cost less than $15.
I hope I shed some light on the subject for you.
Jul 05, 2009 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Turned TV off, went to turn it back on the next night and nothing
yes it could because if you did somthing to the fuse it could cause this problem
May 19, 2009 | Microsoft Xbox 360 Console
No Power to my TV after power outage
A lot of times its simply a fuse that goes out. Either way someone is going to have to open it up and inspect the fuses first. It 's a fairly inexpensive service call.
Hopefully the fuse took the hit from the storm.
Jun 04, 2008 | Televison & Video
My HDMI ports won't work on my Westinghouse tx-42f430s TV. I have things plugged into 3 ports and they all quit working. I had to connect the composite cales to get my TV to work.???
FOUND A SOLUTION! (at least in my case) thanks to some creative Google searching...
Apparently the HDMI ports can get into a state where they are unable to negotiate the input signal properly. The way to "clear" the ports and allow the HDMI signal to be detected is to perform a "reset" on the unit.
Just turn the set off using the power button on the right side of the unit. Then, press and HOLD the power button for at least 10 seconds, then release.
The set should turn on and essentially do a "reboot" where it displays the Westinghouse logo. After that your HDMI ports should be functional again.
It worked for me :-) Best of luck..
Nov 06, 2007 | Westinghouse TX-42F430S Television
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
Electro Med Services...
