Question about Tecumseh Snowblower Snow Blower Starter Handle (Tecumseh)
Electric start simplicity starter turned over for a couple of turns now won't turn over
Turned over for a couple of try's now nothing
    New Friend:
  • 27 Answers
Same thing happened to me.. I took off carburator and rebuilt it with a 20 Dollar seal and jet rebuild kit. i found all gaskets worn out. all tiny fuel inlets clogged....started first pull after and videos on rebuild on youtube make it too simple!
Posted on Mar 07, 2014
Won't turn over
Even though all your other electrical bits are working it could be that your battery doesn't have enough juice to crank the engine. It doesn't take much power to run the radio, lights, etc, but cranking the engine requires the battery to have a very strong charge. If your battery is more than 5 years old, that's very likely the issue. I'd start there. Also, be sure to check the battery terminals and ground for corrosion and clean if necessary. If replacing the battery doesn't solve the problem it could be the starter solenoid or a loose electrical connection somewhere.
Apr 30, 2013 | 1999 Volkswagen Beetle
2003 Ford Focus Engine won't turn over
Try crossing the starter wires, it should turn over. Is key ok, maybe its not coded? Also check connectors on starter . Try disconnecting battery for 30 mins, might reset electrics.
Apr 05, 2013 | Cars & Trucks
Trailblazer won't start
Open the door,when alarm goes off insert key into ignition and alarm should go off and it should start,try that.
Jul 16, 2017 | Cars & Trucks
Troy bilt pony 17.5 won't start and wires heating up
low battery or weak starter pull plugs spray pb blaster in cylinders make sure it isnt siezing up on you
Oct 11, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Won't start
How about corroded battery cables (internal)
Fusible Link wiring corroded & open circuit,does
everything electrical work except the starting circuit?
Turn key & have power to starter solenoid ?
Neutral Switch !
Ignition Switch !
Tough to guess without wiring diagrams,
to see where to start testing
Can't fix what you don't know you have
Oct 02, 2012 | 1990 Ford F150
My Husqvarna YTH2348 tractor won't start. Nothing
It could be a couple of different things. A couple of things that you can check yourself before having to take it to someone to look at it:
1. Open the hood and try turning the engine by spinning the round "cheese grater" looking part that is attached to the flywheel. - it probably won't turn.
2. Remove the spark plug(s) and try again. (Be careful, if the the cylinder is full of gas/oil it will come out as you spin it by hand.) - DO NOT use the electric start to try and turn it over! This sends spark to the plug wire and could ignite any fuel causing severe burns and/or other serious injuries.
-IF-
You were unable to spin the engine over by hand without the spark plug(s) in it, then you may be dealing with anything from a wedged starter gear to a seized engine. Fuel with ethanol added to it attacks the rubber/neoprene seals in carburetors and often times allows fuel to fill the crankcase and cylinder. If this has happened the above mentioned plan of action will let you know. As always, anytime the fuel mixes with the engine oil, you should change the oil to prevent the engine from locking up under normal operation.
I hope this gives you a little bit direction. =)
Dec 23, 2011 | Husqvarna Garden
2007 chevy cobalt ls won't start battery good starter good turn key nothing no click nothing all lites work on dash and radio works jumped starter with screwdriver turns. Over but won't start...
Ignition relay or fuse could be the problem. When you turn the key to start do you hear a fuel pump kicking on and or do you have spark when you hot wire the starter (I know it's hard to check while trying to start it)? You can email me back and I might be able to pinpoint it more.
Jun 06, 2011 | Chevrolet Cobalt Cars & Trucks
Drove car thru water. Car died instantaly. water was knee deep. Pushed car out of water. will not turn over now.???
when you say it won`t turn over do you mean it tries to turn over with the starter or it won`t start.if you mean it won`t turn over then when it dries out a bit(water has drained from electrical components)try it again.if it still wont then its possible it may have sucked up water into the cylinder.pull the plugs and try to turn the motor over.if it does then this is the problem.if you mean it won`t start then let it dry still for water in a component may cause electrical issues when wet.just suggestions.
Apr 28, 2011 | 1997 Saturn SL
Electrical issues
check your alternator belt if its good check your battery with a volt ohm meter engine off it should read 12.1-6 volts start car should read 13.3 nothing lower than this if higher 14.and above alternator is bad if lower than 13. altnator is not charging the battery.
Dec 22, 2008 | 1996 Toyota Camry
Tecumseh Snowblower Snow Blower Starter Handle (Tecumseh) Logo
Top Tecumseh Garden Experts
Mike Squire
Jim Parker
Jim Parker
lnbn1975
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
