Question about Danby Silhouette Select Silhouette 15 Inch Wide Built-in Ice Maker W/ Stainless Steel Door
I wouldn't be so its select will not make iceand the on off switch light is blinking and in standby condition. the drain hoses are clear and everything seems operational. has anybody experienced this problem please help.
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
Trying turning power of and on to see if it will reset
Posted on Apr 07, 2014
I HAVE HASS WASHINE IT IS SHOWING ERROR FH AND HEAVY DUTY FUNCTION IS BLINKING BUT MACHINE NOT WORKING EVEN I PRESS START BUTON
Question is, is the unit getting water, check the supply lines. I know my lines have screens in them and calcium will build up and cause no water flow. You may have to press/cancel to clear code.. if water is getting to the unit then: drain pump operation; pressure switch hose is in good condition and properly connected. Then verify there is not a siphon problem(last sentence), wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU). Also, check all hoses for possible leaks. LASTLY make sure you don't have something around your drain pipe ( taped, cloth filling drain hole around hose,etc) as it needs that air gap to drain properly. Hope this helps...MERRY CHRISTMAS, Tim
Dec 25, 2016 | Washing Machines
Standby light always flashing have to switch of at plug to clear it
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic /Timeslide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window. Blinking code details to many popular brand TVs are given in detail.
Nov 08, 2013 | Televison & Video
The standby light on our Luxor Combi is flashing pink and the tv will not turn on either via the remote or on the tv. The standby light is normally steady blue when in standby. Steady red when in operation...
Flashing of standby light are fault indication, and is called blinking codes. From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the number of blinks carefully for at least 3 times switch ON / OFF. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window. Blinking codes details to many popular brand TVs are given in detail.
Oct 28, 2013 | Televison & Video
Cornea 47" Flatscreen won't power on, red standby light lit
Could be power supply failure. Capacitors can be defective without visible indications.
Jun 07, 2017 | pcb Televison & Video
Looking for a sky remote control code for beko.
Hello
The three digit Sky remote code for Beco TV are:
514 398 065
Four digit code is:
0125
1* Turn your TV and SkyHD box on and press tv on your remote control.
2* Hold down select and the red button together until the red light on your remote
control blinks twice (this is after about two seconds).
3* Press tv again.
4* Key in your TV's brand code. The light on your remote control blinks twice.
5* Press standby on your remote control.
If your TV switches off, press select.
The light on your remote control should blink twice.
If your TV does not switch off, press tv, then press standby.
Repeat the sequence of pressing tv then standby until the TV switches off,
then press select.
If the light blinks three times, your remote control has checked all the possible
settings for the code you used. Check you have the right code and start again
at step 1.
*6 Turn your TV back on and press the tv guide button on your remote control.
The TV Guide screen appears, meaning the remote control settings have
been reset.
Aug 12, 2011 | Televison & Video
When plugged in the hose light blinks
My spotbot lights would blink and it, for a time, only worked on deep clean even after unplugging and plugging back in. Finally it wouldn't work at all, only the hose light would blink. I unplugged the hose and plugged it back in and the machine started working as it should.
Apr 10, 2011 | Bissell SpotBot Robotic Wet/Dry Vacuum
TV won't turn on and standby light blinks 9 times... what can I do to fix this? Thanks, David
Nine blinks - Indication of shorted/leaky diodes - D6116 and D6301 on the "G" board. Panel Module Error or Thermal Error. Unless you are technically experienced, this can only be repaired by an authorised service centre. Obtain a quote for this, the parts are inexpensive, but labour costs might not be.
If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching IC regulator on the "G" board or check connections. Make sure the regulator is -12V or -13V (negative rail).
If the repair is done by an approved workshop, they will clear the error codes (standby LED blinks) as part of their 'soak-testing' and it should reset the TV back to factory condition. Remember to ask about what work was done and if the errors have been cleared/reset before you pay their bill.
Mar 27, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
What is the code for LG 37LE4500 TO WORK WITH SKY REMOTE CONTROL
I also have an LG TV. I used this 4 digit code: 0742.
TO PROGRAM THE remote USING THE 4 DIGIT CODE:
1. Turn your TV on.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the four digit code for your brand of TV. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code for your brand of TV and start again at Step 1.
6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
Mar 12, 2011 | LG Televison & Video
F02 problem. Took drain hose and cleaned that out but it didnt help. Is there another spot to clean out?
if the pressure switch detects either water or suds, it commands the drain pump to continue. After 8 or so minutes, if it's still detecting water or suds, the F02 error is displayed.
try the following :
1. Check Wire Harness connections -
2. Check Drain pump. , as water drains at a rapid rate
3. Check Drain pump motor - , as water drains at a rapid rate
4. Check that the Drain hose and Drain Pump Filter is clear of
foreign objects. – , run a cable through both hose assemblies (exterior and interior) and to check if blocked.
5. Check the CCU –.
6. check for kinks in the hoses, and the height of the pump if beyond what the manual recommends.
if okay then check the Pressure Switch if stuck then run many Rinse and Normal cycles with no detergent and if you still get this F02 error. checked the state of the Pressure Switch’s Empty and Level 1 contacts which intermittently reported correct water level condition (EMPTY and Level 1). In all cases is contacts 11 and 14 (SUDS) continuously made (connected) irrespective of water level, rinse conditions and the use of no detergent.
Iremove the pressure switch and test it by blowing into the inlet and check to hear the switch click, test the switch
blew into the pressure switch hose to clear the blockage,
Oct 21, 2009 | Kenmore Elite 45986 Front Load Washer
Danby Silhouette Select Silhouette 15 Inch Wide Built-in Ice Maker W/ Stainless Steel Door Logo
143 people viewed this question
Top Danby Silhouette Select Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Danby Silhouette Select Kitchen Appliances - Other Expert? Answer questions, earn points and help others
