Question about HP OfficeJet 7310 All-In-One InkJet Printer
I don't know where the ink goes on the darn thing
I was given a used officejet 7310 and I can't figure out how to replace the ink
    President:
  • 1,901 Answers
Go to this web page for step by step instructions changing your cartridges:
HP7310 Ink Replacement
Thanks for using Fixya.
Posted on May 22, 2009
  • Wayne Mineard
    Wayne Mineard May 22, 2009
    Note that the printer must be ON to replace the ink.
I have an HP Officejet 7310xi all-in-one printer. I simply want to know how to replace the ink cartridges. there is a plastic plast that sticks up where you would pull the cartridge out that has a arrow...
Here is a link to the HP page showing replacement of the ink cartridges. Complete with pictures and video.
OfficeJet Ink Replacement
Note: The printer must be powered ON for replacement.
Jul 30, 2011 | HP OfficeJet 7310 All-In-One InkJet...
HP Office jet 7310 all in one. Suddenly will not print after a very light printing. Low ink message did not come on.
Hp devices are famous for simply stopping printing if they even 'think' they are out of ink. The way this is done is electrically through the circuity on the ink cartridges. Two things I'd recommend:
1) Remove each cartridge and take a pencil eraser and rub up and down with the eraser on the circuit side of the cartridge. Don't over do it, but do rub until you see the metal become a bit shinier. Then reinstall the cartridge and see if the problem goes away.
2) Try a new cartridge and see if the issue goes away. Always a good practice to keep a spare on hand!
Hope this helps!
Jun 20, 2011 | HP OfficeJet 7310 All-In-One InkJet...
Hp officejet 7310 all in one... flashishing check
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Jan 31, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Problem for HP OfficeJet 7310 All-In-One InkJet Printer Hp 7310 print cartridge alignment failed
You must replace all ink carts with GENUINE HP carts to get a sucessful alignment.
Jan 19, 2010 | HP OfficeJet 7310 All-In-One InkJet...
I changed the ink in my officejet 7130 and it still says the cartridge needs to be replaced. When I check ink supply it reads that the cartridge is full. It wont align or clean the print heads.
If things were working before you replaced the new ink cartridges, the chances are that the new cartridges are defective. This is common for aftermarket and refilled cartridges. The aftermarket ink has probably clogged the nozzles. The simple solution is to replace the cartrtridges with OEM cartridges, run the nozzle cleaning utility an number of times (suggest 3x) and align the printheads. This should clear your printer problem.
Please let me know if this works for you. Thanks.
Nov 10, 2009 | HP OfficeJet 7310 All-In-One InkJet...
I just got a Dell computer with windows Vista and my hp officejet 7310 doesn't have software for Vista
First thing is to go to this page:
HP OfficeJet 7310 Support
(Bookmark this page for future use.)
Select Software & Driver Downloads. Then select your operating system. (Vista) A list of availble software will be given. Click on the name of the software to download.
When the download window comes up, select Save and direct it to save to your desktop. When the download is complete, close the window and any other open programs.
Prepare your printer: power ON, ink IN, paper IN, telephone line IN (if used). DO NOT CONNECT YOUR USB CABLE.
Run (double-click) the file on your desktop that you downloaded. When promted by the software connect the USB cable and follow any other instructions. That should get you going.
Note: There is also a link on the download page to order a CD if so desired. You could also burn one with that desktop file on it.
Oct 22, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Changed ink cartridge now it won't work
Try removing the black and see if the error is still there. If it goes away the black is bad, if it stays you got a defective new color cartridge.
Jul 01, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Printing is crooked on the page...otherwise prints beautifully
Sounds like the print head / ink cartridge is not seated all the way. Open the door and check it. It also may be the wrong print head / ink cartridge. If you replaced the print head / ink cartridge recently, you may have the wrong one for your device. If it is a off brand or refilled print head / ink cartridge it may be damaged or incorrectly identified.
Jun 11, 2008 | HP OfficeJet 7310 All-In-One InkJet...
HP OfficeJet 7310 All-In-One InkJet Printer Logo
114 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
