I have a Crosley CR249 record player. When I switch it to "On", it doesn't turn on and the red light doesn't go on either. I've tried switching the outlet it's in as well as the AC Adapter and neither thing has helped.
I know this is really late, but I thought I would add my answer to help any others searching for solutions.
I have the same model and had the same problem. I opened it up with a friend of mine and noticed that the joints to the power/volume connection were not good. We resoldered the connections that were bad and it worked 100%.
Hope this helps.
Try first to put the arm parts 90 degrees to the right and that will reset a autostop function the player has.
Plaese change the power cable and check the main fuse
take a screw driver and force the thing to open. Then toss the Crosley. Its low end junk.
