Question about LG Televison & Video
I have lg 1200 flatron golden eye tv. Picture is getting blurred and cloudy appearnce. Pls let me know solution.
  • LG Master
  • 1,511 Answers
The resolution is dependent on the settings. Did you check and adjust the pot controls? Check the connections from the source to see if any loose wires are in need of tightening? In some case HEAT causes the controls to go out of sync and give you a poor picture. Other than that, contact LG support services for their opinion.
Posted on Jan 03, 2014
HDTV GURU
  • 261 Answers
SOURCE: Samsung sp-r4232 cloudy image
How do you have television hooked up?
Posted on Feb 01, 2008
vinnyq
  • 157 Answers
SOURCE: My Lg TV is not displaying picture just a single line
If you have sound the problem is most likely the LCD panel but if you have no sound then it is going to be the main board.
Posted on Oct 13, 2009
caroldon
  • 17129 Answers
SOURCE: lg 29 inch flat tv
Possible failure of the SMPS power supply. Please check the fuse and switch after disconnecting and checking the circuit.
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Posted on Feb 21, 2011
  • 8 Answers
SOURCE: i have an lg golden
Try changing the tv picture settings to 16:9 ratio or widescreen/letterbox setting!! Menu > picture> newer lg's also have a quick menu button on the remote. Hope u sort it.
Posted on Feb 23, 2011
ladywinn
  • 5138 Answers
SOURCE: i have an LG golden
Whats the Model number that is printed on back of TV?
Posted on Jun 25, 2011
LG GOLDEN EYE MODEL-CF21S12E, it is running normal, after 2 to 3hours no picture but sound ok. after sw/off few hours it will work normal. every thing check found nomal,pls give suggestion
Check the soldering on the picture tube neck PCB. If possible resolder all the point in the pcb. There is some problem wit the filament voltage. It can be because of drysoldreing.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Sep 11, 2016 | LG Televison & Video
In my Lg Golden Eye 21" television remote control
Which type of remote control can I use for golden eye TV
Aug 12, 2011 | LG Televison & Video
I have an lg golden eye tv.....can see the picture perfectly except for 3-4 inches of black runnin down both sides that curves in...how can i fix it
Feb 23, 2011 | LG Televison & Video
Pls indicate the model of remote control of lg tv model flatron 1200
LG 42sl8000 remote control
images?q=tbn:and9gcqyzh_492ltc6vtiyo2cqkmmqtycgpzy4dx8oycff8xweomzwsb
Thanks for rating Good luck
Dec 24, 2010 | LG Televison & Video
I have bought LG DV456 model DVD player and I am connecting this DVD player to my LG FLATRON 1200 Golden eye TV using the cable yellow, white, red to Y, Pr, Pb to support progressive scan but it is not...
You are using the wrong cable, my friend. The RCA cables (red, white, yellow) will not work. These cables are known as composite cables (the red and white carry the audio and the yellow carries the video). they will not support progressive scan!
A word of advice: If BOTH of your units support HDMI, that's what you want. If either of them do not, then you want to use component cables (red, blue, green), although you must know that you will still have to hook up audio of some sort. If you have the capability to use optical digital audio, use this if you must use the component cables.
But again, if both units support HDMI, use it because it caries audio and video at the highest level of resolution and saves you lots of potential problems. Good luck. . .
Jul 26, 2017 | Televison & Video
I have a 21inch TV (LG golden eye) which is 10 years old from and now i am facing a problem that when i switched on the tv the standby LED of the tv blinks for a few seconds and then automatically off....
This is line output transformer problems. Before changing LOT,watch any dry soldering is there and also check vertical output ic is good or bad ?by replacement methode.
NOTE- if you know the protection pin, isolate the pin and switch on tv through 200watts bulb seriesly.then watch the symptomes.
Thanking you
Aug 04, 2010 | LG Televison & Video
My LG flatron golden eye tv got Child Locked -
dear sir,
my tv had gone child lock problem & one chenal show the tv. please slove this problem. because remote has been not working.
Sep 30, 2009 | LG Flatron 295LM 22" LCD Monitor
Televison & Video Logo
130 people viewed this question
Computer Repairing
Computer Repairing
