Question about Dryers
Gorenje wt 841 - Dryers
Top loading Gorenje WT 52113, it stops a few minutes into the washing cycle, an error message comes up on the small digital display, looks like d02?
This washer only has f fail code, they recommend you contact svc person for repair. Fail code for F02: F2 Door lock fault detected The door lock on the washing machine has been detected as faulty or failed to engage correctly.
  • Check that the washing machine door has been closed correctly and is engaging the door lock correctly
  • Check wiring to door lock
  • Check door lock
  • Check wiring at control module or timer
Aug 12, 2016 | Washing Machines
Need instruction manual for sony rm 841 remote control
How can i tune chanells. How can i open the menu for tuning with RM-841
Nov 07, 2012 | Sony Original Tv Vcr Remote Control Rm-841...
Error code "E2" of Gorenje K357
E2 - reporting a problem with the sensor of the evaporator in the refrigerator / in isolation 10_9_2011_3_02_24_pm.jpg
Jun 03, 2010 | Gorenje K357 / 2 Bottom Freezer...
Gorenje B 8960 W, shows blinking times only, not
Same problem, anyone knows how to fix it?
Dec 31, 2009 | Gorenje Refrigerators
Need Gorenje WA 64153 service manual
Look behind the control panel or inside the cabinet taped to the wall.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 07, 2009 | Washing Machines
Two vpn tunnels?
Most modem/routers don't support two vpn tunnels at the same time.
Check this out as there are also support details if you would like to check further!
ftp://ftp.zyxel.com/P-841/user_guide/P-841_841-25_v1.pdf
Aug 04, 2009 | Zyxel Prestige 841 (91-004-226010) Modem
I have a Gorenje fridge freezer New Line bought in 1990. The fridge door compartment rails are cracking how can I get spare parts?
I found them in Bosnia, where New Line gorenje was made in 1990. Thank you for posting my problem.
Jul 06, 2009 | Gorenje Refrigerators
No manual for Gorenje front loading washer.
Here is a link to the Gorenje website, you can download the manuals from there which explain all the symbols. This link is for the WA50140 machine which I have, just click on the 'manuals' tab
http://www.gorenje.co.uk/laundry/washing_machines?c=161105
Jan 27, 2009 | Washing Machines
Gorenje Tumble Dryer WT 881 - how do I replace heating element fuse?
I would start with house fuses or breakers, if breakers then turn breakers off then back on several times then try the dryer again. Then I would check the cord where it connects to the dryer. After that I would start checking elements, thermal overloads/cutoffs, etc. most dryers have several normally closed t'stat/ overloads and a thermal fuse. If the thermal fuse or cutoff is blown you also need to check your venting. these safety fuses are not resettable and are usually an indication that the vent may be clogged and/or obstructed.
Nov 04, 2008 | Dryers
Dryers Logo
24 people viewed this question
Top Dryers Experts
