Question about YouTube Videos
No display on screen
I have acer aspire one 7213801. Have a power light button but no any display on screen..pls help
ASPIRE 4253 problem,why it can't be turn on once it switched on?
i have also a problem with my acer aspire 4253.. it has no power even the lights, and fan is not working,,, but i plug it on my charger
Jul 26, 2012 | Acer Aspire 4250 4251 4252 4253 4333 4339...
My acer aspire one wont turn on. the screan doesnt got switched on. pls help?
Does the power light comes on? Try a power drain. Disconnect the adapter, remove the battery, press and hold down the power button for 10 seconds. Put the battery back and the adapter and try to turn it on. Still no display? Take it to an Acer repair center.
Dec 21, 2010 | Acer Aspire One PC Notebook
Acer aspire one no boot menu screen blank power light on no other lights showing except a brief flutter on when using power button when pulling power lead out display show flicker of light
sounds like your lcd inverter may have went out,,,thats a good chance ,,its what powers ur lcd backlight,,check acer website for support,,
Nov 03, 2010 | Acer Aspire One PC Notebook
My Acer Aspire L100 PC Desktop won't start.. when i press power button it only flash LED light jus one time but no HDD sound or CDROM working sound. only CPU fan works thas bout it...Any help? pls
Do you see anything on the screen?
Try the following things:
  1. Try starting the computer with only the battery
  2. Remove the battery and try booting with only the power adapter
  3. Try removing and replacing your memory
Could be a bad power supply or bad battery. After you try the above steps, report your results.
May 22, 2010 | Acer Aspire L100 PC Desktop
Acer Aspire 7520 black screen wont boot
Turn off notebook. Remove the battery. Press Power button. Notebook should start working. Wait for 15 secs. If the screen still blank press Power button and hold it for approx. 4 seconds until notebook is powered off. Then press power button again. Bingo, problem should be solved.
Dec 19, 2009 | Acer Aspire 7520-5185 Laptop
Acer aspire one power button comes on but screen doesn't come on.
1/ Take a close look at the display in bright light; can you see anything there? (If so then the CCFL (or its power supply) needs replacing on the display
2/ hook up an external monitor and see if that works (or at least if the light stays green on the monitor)
3/ Any boot beep? any "Windows sound"?
4/ try removing the battery and (using only external power) see if it starts.
4/ remove the battery AND the external supply, hold the power switch in at least 30 seconds. Hoojk it up again, try it.
JOAT
Oct 16, 2009 | Acer Aspire One PC Notebook
My Acer Aspire 1710 failed to boot and no Acer logo
use my acer aspire daily, went to put a memory stick in and it just died, no power at all but power light on charger still showing green
Feb 01, 2009 | Acer Aspire 1710 Notebook
My acer laptop light is weak the light starts for 1min when I swich on then become dim & dark I can see when I come more cloth to the screen but its weak,I have tried all the Fn how can I fix it? can you...
This will be in the Display settings. Which will be set to reduce the power for display properties. Also Check that your charger is plugged in and working Correctly. Laptops automatically dim on Battery Power to save Power.
Thankyou For Using Fixya.
Mike @ Compurepair.
Jan 08, 2009 | Acer Aspire 5610-4648 Notebook
Acer Aspire 3000 pc screen problem
Have u tried re-installing the video drivers?
Nov 27, 2007 | Acer Aspire 3000 Notebook
YouTube Videos Logo
Top YouTube Computers & Internet Experts
Rizwan Hanif
Level 1 Expert
Michael Terence...
Michael Terence...
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
