Question about Rinnai Heating & Cooling
Rennai heater RC-318e
Sir i have just bought the heater ..the heater works for almost 5 minutes but then i think there is some timer due to which it shuts off automatically...Do to the language written on it i cant figure out which button should i press..please help...
    New Friend:
Helo my heater toytomi antique 5 problem e2
Posted on Jan 03, 2014
4 Suggested Answers
SOURCE: How to reset Tilt Switch in LASKO Ceramic Heater 5540?
I don't have manual, it's a borrowed one. Several days later, I pushed the botton at the bottom several times, looks it solved my problem.
Posted on Feb 15, 2009
  • 8 Answers
SOURCE: lasko heater run about 5 minutes and shut down/how to clean
i have the same problem ... i almost throw this heater out ,,
the fix .. open the unit theres 6 screw at the back.. remove it if you have problem removing the triangle screw use the small square head screw ...size 0 and then you also need to open the black plastic ..
i believe it has 8 screws .. then vaccuum all the dust .. chances are the front and the back of the heating element is covered with dust ..
after that put all back together and i guaranteed it should work like brand new ,,,, dont worry its not that hard ... the only hard thing for me was removing the 2 triangle screws at the back .. Goodluck
Posted on Feb 23, 2009
  • 53 Answers
SOURCE: rennai gas unflued heater kerosene fumes
Have it checked properly - sometimes the reg won't open fully, but the heater will still run, but with improper combustion resulting in a funny smell.
Posted on Aug 16, 2009
Tip
Freezer working but no cool in Fridge/No Ice making
This is one of the common problem throughout the world. It's because of not going through User Manual before using the fridge. <br /><br />To get better cooling, dispensing water, ice cubes from your refrigerator, please follow the steps. <br />1. Keep temp setting between 3 degree and 5 degree Centigrade.<br />2. Ensure, freezer door and mail door of Refrigerator are closed properly.<br />3. Check freezer fan is working. If struck by frosting behind the freezer, you have to defrost it.<br />4. Defrost cycling is not functioning properly. Because your set temp is less than 3 degree or in minus.<br />5. Auto defrost cycle not activated due to thermostat, timer, heater malfunction. <br />First, locate the defrost timer which may hiddenbehind corners of the fridge at the back bottom, in some models located in theceiling of the fresh food section or behind the cold control cover. Once youlocate the defrost timer, slowly turn the screw in the middle of the defrosttimer with straight screwdriver until the fridge shuts off. Now it's indefrost. If the defrost heater(s) starts, replace the defrost timer and defrostthermostat. If the heater(s) does not start, unplug wire cord to check ohm testfor continuity of heater. If continuity is there, plug cord wire which givespower 120volts (check specification) to heater. If heater no starts, bypassdefrost thermostat by join the 2 wires in the defrost thermostat. If the heaternow comes on, replace the defrost timer and defrost thermostat. If the heateritself is bad, replace it<br />6. Check water line to make ice are not tint or remove kinks in water source line in the back of refrigerator to increase water pressure.<br />7. Check solenoid valve in the rear side of refrigerator back is activated. <br />8. If solenoid activated,no water flow means, have to clean solenoid valve. <br />9. Check shut off arm is not struck due to over ice stores in the ice bucket. Remove it.
on Feb 07, 2011 | Refrigerators
Ice buildup on evaporator coils
Can you locate the model number of your Kenmore? The number should look like this 521.345678 and located around the inside of the fresh food section door.
It could be that the defrost heater came on the time you were watching bugt may have a bad connection or a defective defrost element. You need to test the heater for continuity to assure that the element is not broken. the defrost timer and defrost thermostat being new eliminates that as being the problem so I think your element or the connection is the most next likely cause, Let me know I don't mind helping, Thanks Sea Breeze
Defrost Heater Testing for Continuity
Jun 23, 2012 | Kenmore 25.1 cu. ft. Side-By-Side...
I have a side by side hotpoint refrigerator, it is an older one and the frezzer is fine but the frig part wont get cold
The leading cuase of the freezer working fine yet the refrig. isn't warm is a defrost problem so the freezer cant defrost causing the air flow into the ref. section to be totally blocked due to frost build up in the freezer.Do you see frost build up on the back wall of the freezer??
If you do see frost build up here is what to check to see why the frost is building up instead of melting automatically as it is supposed to do.
DEFROST HEATER ...remove back wall of freezer and you will see a black heater at the bottom of the coil thats frosted up,it looks similar to the bake element in your oven,or in some cases it is going to be a spiraled wires inside of a glass tube. To check it,use a multimeter set to the lowest ohms of resistiance setting and follow and find the wires at the top of that frosted coil,unplug/disconnect those wires and check for continuty with around 5-20 ohms of resistiance. If it has that amount of ohms the heater is good. If your meter display does not change or displays OL the defrost heater is broke and needs to be replaced
DEFROST TERMINATION THERMOSTAT... it's round and has 2 wires and clips to the top of that frosted up coil. IT MUST BE CHECKED WHEN COLD SO BEST TO DO WHEN FROST IS STILL BUILT UP. To check it disconnect the wires on it and check for ZERO ohms of resistiance. As with the heater if the meter display OL or doesnt change,it is the problem
DEFROST TIMER...It fits into the control panel in the REF. (NOT FREEZER) section. To check it move the center wheel in a clockwise direction until the compressor and fan in the freezer shuts off,then when they shutoff...within 5 minutes the defrost heater should be on if the heater is on within 5 minutes THE DEFROST TIMER IS BAD..if the heater does not come on within 5 minutes the timer is good and it will be either the heater or termination t-stat that is the problemoldtech2332_90.jpgoldtech2332_91.jpgoldtech2332_92.jpg
Good luck,
Gene
While these pictures are for a different brand ALL refrigerators are similar and may look some what different than your but will be similar enough
Sep 05, 2011 | Refrigerators
Freezer is cold, but cold air is not circulating in refrigerator
Check freezer fan is working.If ice formed over freezer fan by working. It's a common problem due to irregular defrosting. Keep freezer setting temp at 5 degree. And check defrost timer, thermostat,heater are working properly.
Turn timer with small tip screw driver to shut off fridge. If not shut off, replace timer. Turn counter clockwise defrost thermostat. If fridge not shuts off replace defrost thermostat.Check heater by join the 2 wires in the defrost thermostat. And after 1 minute, unplug power and keep your arm on heater. If it's warm heater is o.k. Otherwise, replace heater.
Once heater starts work at regular interval controlled by thermostat and timer, defrost will be good and effective cooling will also be in fridge compartment.
Jan 24, 2011 | Amana ABB2524DE Bottom Freezer...
Freezer working fridge not
There are screws around the edge to remove it. It's probably iced up due to defrost system failure. How to check everything http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 25, 2009 | Zanussi ZX99 / 5 Bottom Freezer...
Timer Shuts off after 5 seconds
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Is it 5 seconds or 5 minutes? The difference coulsd be important, but either could indicate a bad magnetron.
Let us know if the hard reset doen't fix it.
Please write back with more details if you need further help.
We appreciate your thoughtful rating of our answer.
Nov 18, 2007 | GE JES1289SK Microwave Oven
Heating & Cooling Logo
263 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
