Will not wake up after waking computer. Only way to print is by unplugging USB cable and reconnecting. Tons of stuff on line, but none of it works. At least not in this Windows 7 64 bit app.
SOURCE: Zebra LP 2844 printer will not print anything but the test page
possibly not a real LP2844 but an LP2543, a printer mass produced for and used by UPS. refurbishers change the label and sell as LP2844 because they are almost identical.
if it has an AC-AC adapter, it is an LP2543. LP2844 uses a AC-DC adapter, and all LP2844's have USB ports.
SOURCE: Zebra TLP 2844 prints slow in WinXP, but fast in
when submitting the print, un-tick the collate box. Use the properties section to check the speed settings in the driver and try again
SOURCE: how to print to zebra tlp 2844 using vb6 through usb port
You need to use a printer driver or use ZPL commands to print.
SOURCE: Zebra TLP 2844 printing landscape instead of portrait.
To change from "page mode" (protrait) to "line mode" (landscape) you need to complete the following steps.
1. turn the power off
2. hold the feed button down
3. turn power on, the feed button should blink, release the button.
4. when the feed button blinks green, press and hold until it turns red or amber. release the button.
5. turn the power off.
6. hold down the feed button and turn power on, the button should blink and release. it will now print a calibration page. 4 blanks followerd by 2 text pages, the last saying "Now in DUMP" press feed to exit. on the first print, the 4th line down will say either page mode or line mode.
SOURCE: Zebra LP 2844 Printer Error, Cannot Print
Try this
START
SETTINGS
PRINTER/FAXES
in the pop up window go to
FILE/SERVER PROPERTIES
DRIVERS
SELECT THE MFC5440 DRIVER AND REMOVE
SELEST THE LP 2844 DRIVER AND REMOVE
Now go to www.seagullscientific.com and download the Zebra driver pack, once downloaded run it and install the Zebra Lp2844 to with the USb port.
This should solve the problem, if not please come back.
trevor
