Question about Bella Cucina 13401 Deep Fryer
The fryer power is off
After I turned on for the first time in the middle of cooking the power is out. when I tried to turn it on it is not working.
Do you have Air Fryer directions for frozen fries?
pre heat fryer to 180 deg C and cook for approximately 15-20 min depending on thickness of fries stir every 5 mins . if cooked before end time just turn timer to zero or if not done extend cooking time in small amounts.
Oct 11, 2017 | Kitchen Appliances - Others
The air fryer is not getting hot and not cooking the food
This may be a simple fix, or it may be time to get a new air fryer. First, check to make sure everything is properly connected and your circuit breaker is not blown. Then, check the timer to make sure it is not set yet. Sometimes, air fryers do not turn on if the timer is in the middle of a cooking session. If none of these solutions fix the problem, it is time to recycle your air fryer and upgrade to a newer model.
Sep 21, 2017 | The Kitchen Appliances - Others
Cook's essential air fryer doesn't turn on. Have to push basket/food holder in and out and sometimes it works. Help
it aint gonna run on until shut so check make sure nothing is in there to stop the complete closing of the machine is what I would try
Dec 29, 2016 | Kitchen Appliances - Others
I need an instruction manual for a cooks essentials air fryer
How to Use Your Fryer:
  • Remove all packaging materials, sticker, and labels.
  • Clean the basket and pan with hot water, soap and a non-abrasive sponge. These parts are dishwasher safe.
  • Wipe the inside and outside of the appliance with a clean cloth.
  • Place the air fryer on a flat and even surface.
  • Put the basket in the pan.
  • Plug unit in to an approved wall socket.
  • Place the ingredients in the basket and then put the basket and pan back into the appliance. The fryer LED will light up.
  • Set your cooking time and temperature by either choosing one of the 8 presets or manually set it with the "+" or "-" buttons. See "Cooking Guide" to determine the right time and temperature.
  • Once you have set your cooking time and temperature, press the "Start" Button.
  • The heating icon and fan icon will be blinking and this means that the fryer is starting and is circulating the hot air in the fryer. NOTE: During hot air frying, you will notice that the heating up icon will blink and stays from time to time. When the heating icon is on, it means that the temperature inside the fryer has reached the set temperature. When the heating icon is blinking, it means that the temperature inside the fryer dropped and is below the set temperature and is currently heating up to the reach the set temperature.
  • Some ingredients may need to be shaken halfway through the cooking cycle (see "Cooking Guide"), To do this, pull the pan out of the air fryer by the handle, the air fryer will automatically shut down. Then shake the contents in the basket, then slide the pan back into the air fryer and it will resume the cooking cycle. CAUTION: Do not press the button on the handle during shaking; this will detach the basket from the pan.
  • When the cooking time has been reacher, the air blower will stop in 20 seconds.
  • Pull the pan out of the fryer and place it on a pot holder. The cooking pan is VERY HOT do not put on surface that can burn. NOTE: Oil from the ingredients will gather in the bottom of the pan, so be careful when pulling the pan out of the fryer.
  • To remove the ingredients, press the button on the handle of the pan to detach the basket. DO NOT TURN THE PAN OVER. PLACE ON A POT HOLDER.
  • Upon placing the cooking basket back into the air fryer, the air fryer will automatically go to the previous cooking cycle and will repeat the previous cooking cycle, press the cancel button to stop and reset the air fryer if desired.
Mar 25, 2016 | Kitchen Appliances - Others
Why did it stop working?
Big Boss™ Oil-Less Fryer - BedBathandBeyond.com
www.bedbathandbeyond.com/.../big-boss-oil-less-fr...
Bed Bath & BeyondHome > Gifts by Interest > Healthy Living > Big Boss™ Oil-Less Fryer. "Big Boss™Oil-Less ... Right size for family cooking, fried taste without oil, does what it is supposed to do ! ... I purchased a new one when my old Big Boss stopped working.
Big Boss Oil-Less Fryer Reviews and Complaints - Genuine ...
www.asseenontvonsale.com/kitchen/big-boss-oil-less-fryer/
Feb 22, 2012 - The working of Big Boss Oil-Less Fryer is very simple. ..... I am returning it because it does not work (does not turn on) but I don't want another ...
BIG BOSS KITCHEN PRODUCTS - Facebook
Dec 25, 2015 | Big Boss Oil-less Fryer
My Phillips airfryer turns itself off after about 15 mins of cooking. When I try to re start it turns itself off
I would refer to the operating instructions
I suspect that the fryer is switching itself off because it has reached the preset temperature or preser cooking time and will wait for a period of time to switch itself back on
The units I have seen do not run continuously but do the cooking in stages
Jun 29, 2015 | Philips AirFryer Healthier Oil-Free Fryer...
I bought a new tefal actifry family Ah9000 and when open the box and connect it to power then pressed on/off button nothing happened. Just a green screen with hardly to see sun shape on the left side
Use the timer. Unlike the Actifry and Actifry Plus models, the timer on the Actifry Family controls the fryer, and turns it off at the end of the cooking time.
Jul 20, 2012 | Tefal ActiFry Deep Fryer
Pitco fryer
Try removing the oil and boil out the fry tank.
Fryer cleaning manual is downloadable on PITCO site at http://www.middleby.com
Jul 19, 2010 | Pitco Frialator SG14 Deep Fryer
My GE 168997 is not heating up enough..
call and complain. possibly ask for a now one
Jan 07, 2008 | GE 168997 Deep Fryer
Rival 3-L Cool Touch Deep Fryer
Hi, Its very possible that you have the wrong power to your fryer. I noticed that you said that you tried to plug it in. If it does not seem to fit or if you had to bend anything on the plug to make it fit you need to have an electrician check to make sure you have the correct power to the fryer. The wall outlet will have the power information printed on it. The manual will give you the power requirements. It the plug fits ok, check your breaker for that outlet. Good Luck. If this solution does not rate an (Almost There) Please do not rate.
Thank You,
kstfas
Oct 07, 2007 | Kitchen Appliances - Others
Bella Cucina 13401 Deep Fryer Logo
Top Bella Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
richie46
ray gallant
Are you a Bella Kitchen Appliances - Other Expert? Answer questions, earn points and help others
