Question about Vehicle Parts & Accessories
After changing the car battery the Prostart remote model CT-3371 wil not start the car anymore I checked for the valet mode and it should start would you have a way to reset this remote starter ? I wo
After changing tha car battery the remote starter will not start the 2003 Buick Rendez-vous , is there a way to reset this remote ? I alreddy checked for the valet mode any solution would be welcome . Thank-you
3 Suggested Answers
SOURCE: pro start car starter problem
I have a problem my light in the the antana stay on but wont flash and the car wont start either so how do i fix it
Posted on Mar 24, 2010
logosc75
  • 625 Answers
SOURCE: I installed prostart remote starter in 2002 Sonoma,used xpresskit bypass module to bypass passlock 2, truck started with remote ,now won;t start with remote,have to reset and start with truck key
If you are sure that everything is connected properly, then the only explanation could the ground when running from the remote starter to the bypass. If you are using data to data(D2D), switch over to wire to wire. Test the ground when running connection from the remote starter (white) to the ground when running connection of the Xpresskit (blue). You could even go so far as to connect the ground when running of the bypass to constant ground for the test. You CANNOT leave this wire connected to chassis ground.
Also, that vehicle has a second ignition wire(white) that MUST BE power up for remote start. If not, it will trigger the check engine light.
Posted on Oct 02, 2012
2003 Buick Le Sabre hard time to Star up sound like Staring Motor
May be a faulty starter motor or faulty battery.Check your battery leads are tight and the leads to the starter motor are also tight
Good Luck :)
Oct 15, 2016 | 2003 Buick LeSabre
I have a Prostart CT-3371 when I press the start button the lights on my vehicle flash on and off 10 times but the car will not start?
The hood is open, or at least the system thinks the hood is open. Look for a damaged pin switch under the hood and try disconnecting the wire.
Mar 07, 2016 | 2008 Toyota Highlander
Counselor
IF your transmission is truly slipping then changing the fluid is not going to help. It won't hurt but it won't help. I am wondering, are you sure the transmission is slipping. It will have a check engine light on and a trouble code if it is slipping.
Apr 20, 2014 | 2003 Buick Rendezvous
I have prostart 3 way new installed into 1995 f250diesel can't get remotes to conect to the prostart brain box
Verify batteries are installed and installed correctly in the remotes. Examine the batteries and the battery holders on the remotes for "shipping isolators", pieces of plastic film or tape that insulate the batteries from the battery contact points. Verify the batteries are fully charged with a volt meter. Beyond these basic check points, contact prostart support.
Jan 19, 2014 | Cars & Trucks
How do I reprogram Prostart remote starter/car alarm after replacing car battery?
Try turning the Prostart off, then on with the little toggle switch. Check that the hood pin switch is working as it should
Dec 03, 2013 | Cars & Trucks
Remote start wont start the car
try hitting function twice so its at level 2 code and hit the unlock button, that sends it into remote valet mode. if that isnt it make sure the valet toggle switch is on and connected
Dec 01, 2012 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Hey MECP guy, what a job you're doing; THANKS. I want to buy the Prostart CT-5472W for a 2004 Lincoln Navigator. I also want to get addt'l modules like DEI 504D shock sensor 506T audio sensor
Yes, I frequently use DEI modules with Audiovox( Prestige and Code) alarms and remote starters. I just have to hardwire them to work with the systems.
Oct 26, 2012 | Vehicle Parts & Accessories
Vehicle Parts & Accessories Logo
52 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
