Question about Cycling
Refilling ink on trimax pen
I tried my best but was not able to get to know how to fill ink in a trimax gel pen. Could you help me get to the solution?
3 Suggested Answers
benwabnick
  • 2404 Answers
SOURCE: how to remove ink of a gel pen from a LG flatron monitor
Try Goo Gone. Its a product I use to get rid of marker lines, pen lines, You can find it at Office Depot or places like that, it comes in a plastic bottle and looks like this:
http://www.amazon.com/MAGIC-AMERICA-GG12-Goo-Gone/dp/B00006IBNJ
Works very well.
Ben
Posted on May 23, 2009
  • 40 Answers
SOURCE: I have a Pilot FriXion Erasable Gel Ink Pen. I
Hi... Slightly above the rubber finger grip (about 1/8 of an inch) is where the pen unscrews. Once you have it unscrewed remove the old ink cartridge & place in the new one, there is no spring to deal with, so it just drops in.
Posted on Apr 01, 2011
How do I clean a sheaffer fountain pen, it's plunger type ie you push and pull the plunger to load the pen with ink.
methylated spirits is the best cleaner to use ( alcohol based cleaners )
sometimes if you load the pen and it is not full, tip the pen vertical active the plunger again the dip it back in the ink and do it again
That will ensure that a second go fills the pen properly
May 01, 2016 | Office Equipment & Supplies
The black ink does not work even with a new one.
Dear friend., This is tricky model printer.. U re just replaced the ink tank, not print head. Seems Print head was clogged..
For example 1. suppose you filled ink in fountain pen, if nib is faulty pen wont write.. 2. If you are using ball point pen, replacing the refill again it will work. We can say your printer as same as fountain pen. Only way is go to the nearest service center ask them to clean the print head nozzles, there is no other alter because, to reach print head lot of mechanical parts has to be removed which i can't suggest you to do so & there is no replaceable print head in side., sorry no help from my side..
Mar 13, 2014 | HP Photosmart 3110 All-In-One InkJet...
I don't know how to refill?
Refilling HP color printer ink cartridges saves money and time spent running to the store to find the right ink cartridge, which sometimes is out of stock. By having the refill kits for the HP ink cartridge, you can just refill the cartridge when the ink runs out. The refilling process is easy to do and anyone can do it in a few minutes. The ink kits come with directions and all the colors one will need to refill the ink cartridge.
1.Place a piece of paper towel on a flat surface. Remove the empty ink cartridge from the printer. To do this, open the cover and wait for the ink dispenser to move the ink to the open door. Lift up the tap that holds the ink cartridge in place and pull out the cartridge. Push the tap holder back down and close the cover.
2.Place the ink cartridge on the paper towel. Gather the ink refilling kit together with directions and place the ink jars on the paper towel along with the syringe needle.
3.Find the indents on the top of the empty ink cartridge. Poke these holes open with the pen. Sit the cartridge down and open the ink containers. The colors are yellow, cyan and magenta.
4.Read the directions to see where each color goes in the ink cartridge. Insert the syringe needle into the ink container and raise the stopper up until you have the recommended amount of ink to fill into the particular hole.
5.Insert the needle into the hole on the ink cartridge and slowly dispense it into the cartridge. Remember to go slow with this step. If you see the ink oozing out, stop filling and wipe with a paper towel.
6.Cover the holes with the tabs that come in the refill kit or you can use tape. Make sure the hole is sealed to prevent spilling or the ink drying up. Then replace the ink cartridge back into the holder in the printer.
I hope you find it very helpful. Thank you for using fixya.
Aug 22, 2011 | HP PSC 1315 All-In-One InkJet Printer
Pen won't write though plenty of ink
There are a couple reasons a pen refill won't start writing right away. The first thing to check is the tip--often there is a bit of glue or plastic over it in order to prevent leaking.
If that doesn't work, then try one (or both) of the following two methods:
1) Place the refill (but not the tip) in some warm water. Heat will allow the liquid in the gel pen to become thinner and flow more naturally.
2) Hook a rubber band around the middle of the pen, using tape to ensure safety, and wind the pen while holding the rubber band on either side of the pen. Make sure the cap is on the pen. When the rubber band is tight, when you pull straight out on the rubber band from both sides of the pen, it should spin very quickly. The centripetal force will cause the liquid in the pen (at least half of it) to move toward the tip.
Make sure you fasten the rubber band to the pen with tape or something similar; otherwise the pen may go flying off at someone nearby. Also, again, make sure the cap is on to prevent any ink spraying out--this is unlikely in a gel pen, but it could happen.
Jun 13, 2011 | Sanford UniBall Gel Impact Rt Retractable...
I have a Pilot FriXion Erasable Gel Ink Pen. I want to know how to insert the refill. Please assist. Thank you.
Mar 30, 2011 | Pilot Pen Frixion Erasable Gel
Describe your how to fill the ink in pierre cardin elite club fountainpen?
It comes with four refills. Each of the refill has a narrow end and the flat end.
Step 1 : Push the Cap out of the pen body with slight force.
Step 2: Unscrew the upper part of the pen body by rotating the top part(grooved one) which hold the nib and the bottom part in anticlockwise direction
Step 3: Take the refill cartridge and snap fit the narrow part of the cartridge to the nib part of the body . Push until the cartridge fits tightly.
Step 4: Screw the body back in clockwise direction.
Step 5 : On the brass nib gently rub with your finger until the ink starts flowing.
Step 6: Write on the paper with gentle force on the nib and its all done.
Remarks: There is also a pump with an empty cartridge which is provided. You can use it to suck ink form a regular fountain pen ink bottle and then fit the whole assembly. You can use regular ink with this technique.
Hope this helps
Oct 12, 2010 | Office Equipment & Supplies
HOW TO REFILL INK
Hi
All printer are the same ways to refill the inks up go to this website it will show you how it done there is a few Videos there for you to see how it done
http://www.youtube.com/watch?v=pnCPB9Clk5c
After you have refilled the inks make sure you know how to reset the inks after or it will still show emty, you need to find the codes,
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 23, 2010 | HP PSC 1510 All-In-One InkJet Printer
How to do service of my printer?????
Hi
Try running a head cleaning cycle from the utility. If all fails then chances are the nozzles are clog due to the fountain pen ink.
Hope this helps
Nov 09, 2008 | Epson Stylus C43SX InkJet Printer
Cycling Logo
22 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
