Question about TruTech PVS31170S1W 17 in. LCD Television
Audio when playing a DVD but not when watching TV
Why is there no audio when the tv is on, but when I insert a DVD there is audio?
    President:
  • 814 Answers
You must check you remote control and make sure you are using the right setting on it for use with the television. Did you you have to change anything on the remote to use the dvd player. If you did then, you must reset the remote for use with the television. This includes any surround sound receivers you may be using for the sound system. Look in your owners manual for the correct set-up and see if you are using it. If this does not solve your problem, you can can call TruTech customer support at these telephone numbers . !-888-252-6252 and 1-800-252-6123. I hope this information helps you with your problem.
Posted on May 22, 2009
2 Suggested Answers
ginko
  • 19396 Answers
SOURCE: No audio when watching TV but do have audio when watching a DVD
To start unplug the tv from main for one hour or so, this will drain power and reset setting to factory, solving the problem if this is caused by incorrect TV audio settings.
If you use an external receiver to watch the TV, then the problem is either the connection cable to the receiver or a bad signal (input) board.
If instead you have the problem when the unit is set to the internal TV tuner, then responsible for the fault can be a faulty tuner board, or a faulty signal board, as the audio board inside this TV process in the same way if signal is coming from built in tuner or external device.
Posted on May 29, 2009
Rca model rtd3266 won't produce aux audio through the tv even though we have hooked up the red and white cables. It only playes the surround sound when you watch the dvd.
I believe you have misunderstood something. The audio output from your TV is stereo. Your RCA system produces surround output from your TVs stereo input.
Nov 30, 2013 | RCA DRC277 DVD Player
Have alot of buzzing noise when we play a DVD but not when watching tv.
Verify the AUDIO cables from the DVD player to the TV they could be defective (even if new)
push the PLUGES firmly so they are correctly seated, play with (shake/move) the AUDIO cables while playing a DVD to see if it's not a loose connection
Cheers!
Jan 14, 2011 | Vizio L32 32 in. LCD HDTV
How to connect Blu ray disc player with my Bose 321 system. I have 1080 p samsung LCD TV. How to get the best.
hi,
do the following.
1. connect ur blue rays hdmi out to ur tvs hdmi input.
2. connct blue rays out to any one of the coaxial(aux) input of bose.
3. connect ur tvs optical audio output to optical audio input of bose
4. connect monitor out of ur bose to any one of ur av in of ur tv. connect component video to better quality .
4 . in the blue rays audio setup select audio output priority as optical/coaxial
5 . in bose set aux as digital input.
to see blue ray select hdmi of ur tv, sellect in bose in which the blue rays coaxial is connected(aux) insert disk in blue ray an watch
to see dvd in bose select tvs corresponding input, select bose to dvd . insert dvd and watch
to whach tv program set tv to corresponding mode. set bose to optical audio input mode.
ok
Dec 15, 2010 | Televison & Video
I have sound when playing a dvd but not when the
It would be the rare TV that originated anything approaching the sound quality of any other audio
source in your home or could process digital multichannel audio anywhere near as well as the
Yamaha. What model TV did you say this was and how is the audio from it getting into the Yamaha?
If you have an RCA audio pair going from it to the Yamaha that would provide the bare minumum quality stereo-only analog audio that the TV is processing. Its internal audio controls could be part of the problem of why the Yamaha can't "hear" it..
TV-related audio is best derived from as close to its source as possible. Your cable, satellite DVD, BD all have superior digital multichannel audio outputs. Why would you want to filter them through the TV first?
Those sources may also have HDMI which would be great for the TV and the receiver; they also have
standard RCA stereo outputs, each of which could be suitable to run to the TV's RCA inputs if you only want to watch news or weather with lo-fi sound.
Bottom line recommendation: BEST video to the TV; best audio to the Yamaha. Turn the TV speakers off unless you want to watch the news. Then turn the Yamaha off and save some on the electricity.
Mar 25, 2010 | Yamaha RX-V663 Receiver
55HDX99 TV with Sony DAV-HDX500
Connect RCA Red-White audio cable to INPUT of DAV-HDX500 and hook it to TV AUDIO OUT pins at back of TV.
Now select INPUT in DAV-HDX500 to get TV sound in Sony system speakers.
Apr 19, 2009 | Televison & Video
Problem getting home theatre sytem to play audio when watching tv
you need the red and white audio cable hooked into the AUDIO OUT connectors on the tv and the other end of the red and white cables into the AUDIO IN in tv to the media center (main Bose unit).....If your tv does not provide AUDIO OUT connectors, you cannot connect the tv audio to the 3-2-1 system. Continue using your tv speakers for sound.
Dec 26, 2008 | Samsung 1000W 5.1-Ch. Home Theater System...
Unable to separate VCR playback from Sat. Receiver input,both av2
try to find a multi-video selector swicth that the best you can do
Dec 19, 2008 | Dynex DXR24TV 24" TV
Cannot hear DVD through the DVD receiver port
I had to turn on the TV first then the receiver and DVD player to see the video of the DVD.
Jul 31, 2008 | Onkyo TX-SR803 Receiver
Can't get my dvd/vcr to tape and play back
Color codes for A/V cables:
Yellow: Composite Video
Red: Right Audio Channel
White: Left Audio Channel (mono)
Does your TV have a video & audio OUTPUT on the back of the TV?
If so, will need another set of audio/video cables and you need to connect the yellow cable from the video OUTPUT of the TV to the video INPUT (yellow) of the DVD/VCR and connect the Red cable from the right OUTPUT of the TV to the red INPUT of the DVD/VCR. Then connect the white cable from the left OUTPUT of the TV to the white INPUT of the DVD/VCR. If your TV is not in stereo, just connect up the white cable for mono audio.
If your TV set does NOT have audio/video OUTPUTS, then you will still need another set of audio/video cables and connect the yellow cable from the video OUTPUT of the cable box to the yellow video INPUT of the DVD/VCR and connect either the red or white (or both if possible) to the red or white audio INPUTS of the DVD/VCR.
You need two sets of cables because you want to watch DVD's & tapes on your TV (Path #1) and you want to record the TV channel shows back to your DVD/VCR (Path #2).
Please let me know if I can be of further assistance to you.
Good Luck!
- Jim
Feb 21, 2008 | Televison & Video
Sound Problems
are u runing dvd player to tv 1st audio and video and eco meens tv is on with sterio same time erther one or other run the the dvd audio to dvd in on sterio and video cables to tv only dont use souind on tv just sterios if u want tv sound tooo use tvs rca outs back into sterio on a ch tv in ok
Jan 24, 2008 | Sony STR-DG800 Receiver
TruTech PVS31170S1W 17 in. LCD Television Logo
87 people viewed this question
Top TruTech Televison & Video Experts
Radames Pagan
Radames Pagan
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
