Question about Samsung Televison & Video
Crt tv sound ok but picture goes on & off
Picture come and go in seconds from all inputs.(TV, DVD....) but sound OK. I reset it the to factory but same. I changed EEPROM but same. RGB output to CRT goes on and off(Voltage varies from 0.5-3). any body help me.....(mesudmk@gmail.com)
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 14 Answers
Try checking the tv/av tact switch,if it is grounded or normally close or has a resistance with pressing, replace it with a new tact switch..
Posted on Jan 04, 2014
4 Suggested Answers
bhatgiri73
  • 106 Answers
SOURCE: LG CRT TV, picture becomes yellowish
yes it is due to dry solder in vedeo driver section(a board fixed to the pict-tube.).
Posted on Jan 22, 2010
  • 10 Answers
SOURCE: philips 32pw9617 crt no picture on analog channels but sound ok
this is your tuner board faulty replace tuner board hope this helps
Posted on Mar 26, 2010
  • 7 Answers
SOURCE: hi its CRT 32" proline
first check bright and contrast controol
if not open the cover of the set,make on see if crt filment okey or not and measure it about6,3v it comes from fly back,,,then check controol grid around400v,,,,then check 180v going torgb tr on crt socket at last check fly back transformer
if all are right the problem in crt it self
Posted on Jan 07, 2011
Precision TV - PTV2548 no sound when your watching cable but there is sound forvideo input
may be the source itself(i.e. cable box) also check cables between cable box & TV. If you are connecting the DVD to the same input the cable box is installed, You know that input on the TV is OK. If you get no audio when the DVD is connected to the same input as cable box, then issue is the MAIN PCB.
May 21, 2014 | Televison & Video
"32" rca tv about 3 years old was on & it went black- power light is on"
sounds like the sceen is dead, if you are receiving nothing on screen, then it sounds like either a component and/or screen is gone... however, check the tv input to make sure it wasnt acidentally switched to an input channel with nothing selected... if that does not work, call local tv repair or mfg customer service tech. if under warranty, have repaired or replaced. without physically seeing tv, it is hard to diagnose issue outside of information given. could be simple board replacement or could be screen.. but check input first, if a dvd player plays, then it could be just component or input on wrong selection
Oct 17, 2010 | RCA 32V550T 32" TV
Sound went out?
Unplug,replug the tv about an hour later.Let the tv to reset it self back to factory setting.Go in ur tv menu go to AUDIO setting.Go down to reset.Now ur tv should have sound back.No,sound after the reset.Than ur tv Tuner board is dead,require changing the Tuner board.
May 27, 2010 | Toshiba 32AV502U 31.5 in. LCD HDTV
Philips 32pw9617 crt no picture on analog channels but sound ok
Mar 26, 2010 | Televison & Video
Wharfedale DVD recorder, no sound. Scart lead connected to Sky Box & scart connection to TV. Picture OK & can play DVD's or record to HD but no sound.
HI if you mean scart connectors on rear of DVD recorder, try swapping scart inputs on DVD recorder and if no joys then on set top box. (some units have 1 input designated for TV and the other for Set top box input)
Mar 16, 2010 | Televison & Video
No Sound
first you want to make sure and check if the problem is common for other inputs as well (dvd ,player antenna A or B)
or if you have a cable or satellite box sometimes you may have problem with those too( reset them by uplugged them too)
if evething ok check tv menu and see in audio secction if speakers are not turne off.if still you have a problem the audio amp inside the set its having a problem.
Jul 03, 2008 | Toshiba CF30F40R 30" TV
Power light blinks and no picture
No picture - screen is empty. Sound is ok
Check IC101 (BA7630F), if video signal comes to input (pin 1) but not present at output (pin 14) then replace this IC
No picture and sound, only a high pitch sound at switch on
Remove horizontal transistor and measure the resistance across any two pins. This value should be no less than 200ohms
Picture fades away few seconds after start-up till no picture. Sometimes no picture at all. Sometimes picture OK for longer. Sound unaffected.
Faulty joints on CRT pcb. Cracked solder joints at tube socket connections on CRT circuit board. Caused variable supply to CRT heaters. Resolder all socket pins to pcb.
Nov 24, 2007 | Toshiba CZ36V51 36" TV
I get no picture on samsung pck5315r TV
no picture & sound ok as sound is there means your power supply &high voltage section is ok problem is in video section 1 crt is glowing or not if not check its supply. 2 check crt base or any connector for loose 3 check supply to video & crt base(g2) 4 check for video signal is coming to video sectuon from processor ic. 5 loose print if any. hope this will help
Sep 30, 2007 | Samsung PCK5315RX TV
Panasonic CT-36SL13 Can't select video inputs
On a Panasonic to do a factory reset while the set is on press in on the power and action buttons on the front of the TV at the same time. In a few seconds the screen shouls go blank and come up with a screen that says "CHK" in the upper left hand corner. Once it does that press the action button again to clear the screen. You have now reset the TV to factory settings and will have to re-program the channel memory once again. Hope that works...
Apr 23, 2007 | Panasonic CT-36SL13 32" TV
Televison & Video Logo
42 people viewed this question
Jerry Greenberg
Jerry Greenberg
