Question about Air Conditioning and Heat for Scion xB
Scion xb has no heat - Air Conditioning and Heat for Scion xB
    New Friend:
There are a few things it could be. 1. heater core. 2. radiator. 3. thermostat. 4. could need a radiator flush. 5. switch in console is bad. How many miles is on the car? the easy and cheapest way is to replace the thermostat and do a radiator flush. If there is water leaking in side of the car leaking from behind the dash and down on the floorboard then it is more than likely your heater core.
Posted on Jan 05, 2014
Remote starter only allows my starter to turn over twice; needs at least 3 with my key. How to adjust to have it starter run longer on remote?
I know you are looking to have the remote starter run a third time but I would say you need to look at your Fuel Pressure Regulator on the Scion. Sounds like it is not holding fuel pressure at the fuel rail and that is why it requires a third Crank
Jan 05, 2016 | 2006 Scion xB
2005 scion xb
I would let a qualified mechanic do it
Sep 24, 2014 | 2005 Scion xB
Chgd. ac refrigerantbut still no cold air blows scion 2006 xb
A car does not need A/C to run, if you want to buy an A/C Pump and have the system recharged professionally, you will pay about six hundred bucks.
Aug 01, 2012 | Air Conditioning and Heat for Scion xB
Htr relay location in 2006 scion xb
It's a 40 amp fuse under the hood of your Scion. Should be in the panel by the battery. There should be a legend on the underside of the lid to that junction box. If memeory serves, the fuse you want is on the far left and up two.
Jun 20, 2012 | Air Conditioning and Heat for Scion xB
My 2005 scion xb won't go into overdrive and the speedometer doesn't work
run the fault codes and look for a failed VSS sensor
Feb 22, 2012 | 2005 Scion xB
Scion XB automatic door lock, driver's door not working with remote. How do I reset it?
This is a common problem on the Scion XB, replace the drivers door lock actuator and you should be fine.
May 19, 2011 | 2005 Scion xB
How do I reset the speedometer in my scion xb. It
Legally you can't.
All service to this system must be conducted by a licensed repair shop.
Aug 24, 2009 | 2008 Scion Xb
Air Conditioning and Heat for Scion xB Logo
94 people viewed this question
Top Scion Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Scion Vehicle Part and Accessory Expert? Answer questions, earn points and help others
