Question about X2Gen Computers & Internet
X2GEN 19" Monitor keeps Disconnecting/Reconnecting in Vista
I have a Compaq Presario SR5030NX Desktop computer hooked up to a X2GEN 19'' Widescreen Monitor (MW19U).
After rebooting (and sometimes coming off sleep mode), my monitor has reverted back to a strange resolution (1072x768). This is accompanied by the monitor itself (constantly) disconnecting & reconnecting itself in the background. I know this because the Windows hardware Insert/Remove noises constantly play in the background (which I disabled), and I see the monitor dissappearing/reappearing in the Device Manager in Vista simultainiously. I have tried updating the drivers, but it doesn't stop the disconnecting and reconnecting.
When I start up, it always comes up in the wrong resolution. So I power cycle the monitor (once), which sometimes makes it revert back to the correct screen size (1440x900) automatically. If not, I keep power cycling, and try to very quickly ''catch'' it before it ''disconnects'' back, go into Display settings, and the manually change it back to 1440x900.
Reinstalling/updating drivers, as well as reloading the OS has not helped. I am guessing I have some hardware or possibly power issues (with the monitor). I was just wondering if anybody knows what this is and can help. TIA!
  • 44 Answers
SOURCE: Viewsonic monitor not detected after service
If you are running DVI-D(the white connector) then it isn't getting a digital handshake. If you have inspected the connection between the 2 and make sure there is no bent pins inside the connector that it mates with. If you have another computer, try to connect to that one.
Open windows start menu, right click on my computer, then choose properties. Next choose Hardware, then Device manager. Once there, double click on display adapters to see if installed correctly. If good, click Monitors. If good, then your video card driver must need reinstall or update as usual. Also do you have the correct driver for you monitor? How does it react when you uninstall the monitor driver(can you select 32bit and higher resolution in default drivers?
If none of this works, I would suspect that the replaced component failed due to static or faulty components within the electronics.
Is there any other changes to the PC (new video card, updated Directx9.0?)
Hope this helps and let me know if I can be of anymore assistance?
Posted on Aug 20, 2008
ginko
  • 19396 Answers
SOURCE: X2gen MW19U Monitor Black screen but sounds like it is cycling
The monitor is on protection.
Test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on Apr 25, 2009
  • 630 Answers
SOURCE: My screen resolution is not like it's supposed to be.
The native resolution of you monitor is 1440x900. If you previously had it set at a lower resolution (say 1280 x 720) the text would appear larger than it does now. You can change the appearance of internet explorer by using the Zoom function (Ctrl +).
Posted on Jul 05, 2009
  • 541 Answers
SOURCE: I get an out of range message when trying to
you need to match the resolution on the old screen on the old computer on the new screen
Posted on Oct 11, 2009
nonontech
  • 4737 Answers
SOURCE: monitor is changing colors and won't wake up
This problem should not be only with your monitor, but also with your video card. You might have left one image sitting for long hours. There is no specific solution, but for Lcd users, you can try this. Leave the monitor off for few hours without any connection, maybe power chord or vga/dvi/hdmi cable. If this doesn't fix then the problem must be from your video card. You can try the monitor on another system to make sure, which one is the culprit. Your last choice is to reset the bios, to do this, remove the bios battery and leave it for few minutes outside (2 mins will do) and put it back. Reboot your system, this will fix your problem. Good luck. Thanks for using FixYa.
Posted on May 31, 2010
Computer will not boot up
Can you describe what happens? Fans spin? Led's blink? Anything on the monitor?
Jan 16, 2013 | HP Compaq Presario SR5030NX (RX896AA) PC...
Compaq presario sr5030nx no video
compaq presario sr5030nx: This a Desktop? If so,Is the monitor plugged in, turned on, working, test with another machine, check the cabling from monitor to tower, unplug and inspect for bent pins. first. Now , when you say ,"compaq presario sr5030nx no video" and "black screen", do you mean your video player is not playing?
Nov 10, 2012 | Computers & Internet
Good morning,I want a help to download xp compaq presario sr 5030nx Drivers . thankyou so much
You can download the drivers from the Compaq/HP WEBsupport/download page. Make sure you select your model computer/laptop and the XP orVista Windows version of the drivers you require and install them. Click onthis link to download the drivers: -
www.compaq.com/country/cpq_support.html
Feb 06, 2011 | HP Compaq Presario SR5030NX (RX896AA) PC...
I have a message on my monitor that says, Out of Range. What can I do about it?
you need to change your screen resolution. the best way would be to hook it up to a bigger monitor or a television- one that can handle the present screen resolution, and then back the resolution down before re-hooking up the 19" monitor.
or you could boot in safe mode, uninstall the video driver, and then reinstall the driver, to reset the screen resolution to a basic resolution.
to change your screen resolution (hooked up to a different monitor) right click on the desktop and select "properties" in xp or "personalization>screen resolution" in vista/7.
Oct 28, 2010 | Envision 19" Widescreen Flat Panel LCD...
Ghosting of images and buzzing when on mostly white screen X2gen 19" monitor (HP/Vista )
Please bring the unit to an authorized service center as there's an internal electronic part/s of your monitor that is cold soldered / defective. regards
May 27, 2009 | X2Gen MG19VT 19" LCD Monitor
Out of Range
Usually with the resolution your computer's set resolution for ur display is to high for the screen
try using a different screen to change the frame refresh rate and resolution to ur monitor
Oct 21, 2008 | X2Gen MG19MY 19" LCD Monitor
Monitor switching to standby - CV735 monitor with Presario 5000 series desktop
my compaq crt monitor not showing color. its shows only blue, green colors . u please tell me. what is the problem in.how to solve it.
is the monitor fault or any other.
Oct 30, 2006 | Compaq CV735 17" CRT Monitor
Computers & Internet Logo
521 people viewed this question
Top X2Gen Computers & Internet Experts
Sandy Moore
Sandy Moore
William Alequin
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
