Question about Nordic Track NordicTrack E5.7 Elliptical
Resistance wont work
Set on 1 resistance cant increase hear noise in back each time increase is attempted
Golds gym 380 elliptical is not increasing resistance
follow this steps, God bless you
    • Be aware that the resistance is often the part that requires repair. Resistance is managed magnetically, so often if the machine is working, but the resistance isn't setting correctly or at all, check the bolts that secure the magnets. If they are loose, the resistance will slip. If the bolts are fine, check the magnets themselves by using a refrigerator magnet and see if it is attracted or repelled by the your fridge magnet. If not, the magnets have de-magnetized and need to be replaced.
    • Consider that if the foot pedals are attached with bolts, any slipping can be fixed with a quick use of the wrench. But if the foot pedals are damaged or breaking, order new foot pedals (see Resources below) rather than run the risk of a pedal breaking while you're on the machine.
Nov 14, 2012 | Golds Gym StrideTrainer 380 Elliptical
RCA D52W20 HDTV TRIES TO TURN ON 3 TIMES BUT WONT POWER UP
remove all the electrical wire connections from the back of the tv .remove the power plug from the electrical outlet and wait for two minutes and replug the wire and then ckeck.it should work.
reply.
Oct 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Starter wont turn over
It would help a whole lot if you could describe the problem with more information. Do any of the lights on the car work? Do you hear any noise when you attempt to start car?
Try moving the gear shifter out of Park position and then back again a few times. Turn the key to the start position a few times.
Problem could be a bad ignition switch, neutral safety switch, starter or starter relay (located in underhood fuse box, #47 relay)
Dec 29, 2010 | 2002 Chevrolet TrailBlazer
Loud knocking noise with increased resistance
Sounds like you a bearing in flywheel is failing need to call Accell Fitness of North America @ Phone: 1-800-667-1020 they are the distributors of Tunturi equipment
May 03, 2010 | Exercise & Fitness
TUNTURI E433 exercise bike--- can't change resistance
Hey roger,
I have buyed me a E430 but i have problem with it. does the bike work without the heart rate counter? I don't have it and the resistance is always changing in every program. So i like to know my bike is ok or not
Apr 13, 2010 | Tunturi E30 Ergonomic Exercise Bike
My 1996 Chevrolet Blazer won't start most of the time. Engine don't turn over, or the starter when I turn the key. All I can hear is some clicking coming from the carbarator & a humming noise under my...
The humming noise you hear is the fuel pump. It is probably your starter soleniod. If you hear an electric click under the dash near the steering column when you turn the key then the ignition switch is ok and your starter needs to be replaced. This happened to me last month.
Dec 08, 2009 | 1996 Chevrolet Blazer
I keep hering a taping noise coming from the back of the car somewher it lasts for about 1 to 2 mins but what i cant work out is its doing it when the car isnt even turnt on and its a mitsubishi carisma...
There are 2 possibilities causing your problem. 1. Fuel pump. On some cars it is possible to hear the fuel pump when they are mounted in the rear. They are the electric impulse type, and only operate on demad.
2. automotaic load leveling suspension. The car will automotically adjust to the increase or decease of load thru its shocks.
Bill
Nov 19, 2008 | Mitsubishi Tredia Cars & Trucks
Amana Range, Electric wont bake or broil
the fact that the time keeps flashing is odd, an you set the clock?? and if so does it return to blinking again???sme stoves wont allow proper operation of oven without the clock being set.
Mar 23, 2008 | Kitchen Ranges
Camera wont turn on
The camera may in fact be hung in voice recording mode, or may in fact have a low voltage error or internal failure. Suggest that you follow this routine. 1 remove batteries and press the on button, nothing should happen. Allow camera to sit for five minutes. 2 remove memory card if one is installed into camera. 3 install two fresh batteries in camera and attempt to power it on. 4. once on set the time and date. attempt to take a photo. then cycle the camera off. Once again power it on and see if the settings remain intact. If it is working then power off and insert the memory card and test again. I have found that allowing the camera batteries to run low and die in the camera cause a series of problems like the one that you have. Always use rechargable batteries of the Nickel metal hydride construction in this camera. This is the only known reliable power source for this camera. Note: camera instructions for this model can not be found on the samsungusa site and you will have to go to http://www.samsungcamera.com to find instructions for this older model.
Jan 27, 2008 | Samsung Digimax D53 Digital Camera
Nordic Track NordicTrack E5.7 Elliptical Logo
55 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
