Question about Garden
Snow blower losing power
Changed Spark plug. New Fuel filter. Starts great. Fresh gas. It's bogging down under use, even in light snow. Must keep choke on full or halfway during use. Just not picking and throwing like it used to (@ 25% of previous "power").
  • Garden Master
  • 2,478 Answers
Start with fuel. Unhook fuel line from carb. and see if fuel runs out.
Posted on Jan 03, 2014
  • 63 Answers
SOURCE: Lawnmower loses power when I engage blades
This is most likely a belt problem. Check the deck drive belt that runs from the mower deck to the engine it/s come loose and got stuck between the guides.
Posted on Mar 16, 2009
longgee
  • 322 Answers
SOURCE: I have a Craftsman lawn
Try changing the its oil-seals. The problem lies there. It may be damaged or the oil-seals are now smaller than its is used to and it is because of the heat. The oil-seal are rounded things that are made of rubber.
Posted on May 09, 2009
nova2nv
  • 197 Answers
SOURCE: Stalls after 20 mins. of running fine. (Starving for gas)
From the rear of machine look at the top left of fuel tank for the fuel line.Where line comes out of tank see if it is pinched where it goes down between frame and tank,grab line and see if it moves freely.If that is OK loosen fuel cap after 10 minutes of run time to see if your vent hole in cap is working.These are 2 common problems for the L series mowers.
Posted on May 22, 2010
daneinwv
  • 124 Answers
SOURCE: won't start; its a
My name is Dane and I am going to assist you in solving your problem.
The first thing I would check is to check your spark plug and then make sure your gas cap is venting properly. If the vent gets clogged, the tank will actually get a vacuum built up and no gas will flow to the Carburetor. The next time the mower does this, loosen the gas cap enough to allow air to get in and then retighten. If it runs fine, it was clogged. You have to clean out the vent or get another cap.
Make sure the fuel is mixed correctly. Too much oil in the mix will cause problems. Make sure you haven't left old fuel in it for a long period of time and gummed those jets up. Sometimes an engine just needs to run in order to clean the jets out. If this is the case, just replace the fuel, get it running and work it normal for a tank of fuel if you can. You should see improvement by then.
If it still doesn't run correctly, you will have to adjust or clean the Carburetor. One thing to remember: If your engine has run fine in the past, you probably have a clogged Carburetor. If it hasn't ever ran right, you should adjust the high-speed jet.
If you need to clean the Carburetor, you will probably need to remove, disassemble, soak, and use compressed air to blow out the jets in your carburetor. Pay close attention to how the carburetor is attached to the engine. Make a drawing if you need to or take some pictures. Remove the Carburetor from the engine. Remove the air filter, linkages, throttle/choke cables and fuel line. Remove the mounting bolts/nuts. You will need to disassemble the carburetor as far as possible and put it in some Carburetor cleaning solution. You can get this at any auto parts store. Do not place rubber parts in the solution. Allow it to soak in cleaner as directed, and then blow out the ports and jets with compressed air immediately after you take it out of the cleaning solution. Be careful not to get any spray back on your skin or in your eyes. Reinstall the Carburetor in the reverse order. Replace any worn or torn gaskets or o-rings as you assemble and reinstall it.
If you need to adjust the high-speed mixture setting on your Carburetor, turning the screw out just 1/2 turn or so should do the trick. It is not so hard to adjust the Carburetor, however you do need a special tool that is very hard to get your hands on. They don't make many engines with plain screw heads on the jet screws anymore. The newer Carburetors are factory set lean so they can pass emission standards. If you have a local dealer, they should adjust the mixture for a couple of bucks. If you can adjust the screw, start the engine, allow it to warm up, and apply full throttle. Start backing off the screw just until the engine gets max RPM. That's it. You're done.
Just a TIP: Always mix your fuel with an approved fuel stabilizer. Fuel begins to go bad after a few months and that's why many people have fuel problems in the spring.
I hope I've helped. Thank you! Dane
Posted on Dec 10, 2010
  • 252 Answers
SOURCE: Craftsman lawn tractor, LT2000, 18
hi there
here is web site for manual and parts diagram
http://www.hammerwall.com/Download_Manual/12377/
have the valves been adjusted correctly ? or could have a tight valve clearance
and when gets warm holds valve open - looses power
your engine will be 31p777 intek ohv avs
run the piston to tdc on compression stroke , then turn piston past tdc & set piston is 1/4 inch down the bore on power stroke this eliminates decomprssor lift from the setting
intake should be 0.003 Thou
and exhaust 0.005t thou
then check the carburettor main jets and emulsion tube and pilot jets and air bleeds and progression ports for obstruction etc for restriction / blockage
check fuel flow from tank to carb , check that the fuel solenoid has got continual 12 volt supply
when switched on and does not go o/c cutting fuel supply to main jet
have a look let me know
cheers hope it helps
pauly 46
dont forget the thumbs rating
Posted on Jun 09, 2011
1992 60 hp motor bogs under full power????
try priming the fuel bulb when it boggs down and if it speeds up then replace fuel pump diaphrams etc and clean carbs and balance to start a fresh ! fuel tank clean ?
Jul 24, 2014 | Seloc Johnson Evinrude Outboards 65-300HP...
How fo i keep my toro snow blower from bogging down?
Dry the spark plug it might probably wet
Feb 09, 2014 | Garden
Snow blower keeps stalling out
clean the carb
put fresh gas in it
change the spark plug
Jan 30, 2014 | Troy-Bilt 179cc 24-in Two-Stage Gas Snow...
Toro Power Clear 418 snowblower wont start after sitting through summer
Check the fuel line to the tank, and see if another one is inside, maybe it fell off, or it's filter is clogged.
Nov 29, 2013 | Toro Power Clear 418 ZR - Single Stage...
Blower bogs down and kills at full throttle
Check the following, then clean or replace:
  • Fuel Filter - Located IN the fuel tank
  • Spark Plug
  • Spark Arrestor - at muffler port, creates resistance of exhaust flow, engine then bogs
  • Carburetor - may need a rebuild kit
Then watch this...
and...
Mar 31, 2013 | Echo Pb265l 25.4cc Gas Powered 158 Mph Low...
1989 s-10 2.5 liter,when engine starts,the spark plugs become "fuel fouled"what causes this?
air filter really dirty, injectors stuck open. fuel pressure regulator is bad.
Feb 12, 2011 | 1988 Chevrolet S-10
My yard master 5.5 horse power snow blower isn't blowing snow I have changed belts, spark plug, share pins all fine. Starts on first pull as soon as i hit snow it bogs down and stops. Main auger turns fine...
Assuming that you mean that the engine bogs down, try increasing the main jet setting by turning the screw CCW (looking at the outer end of the screw) somewhat. If no help, the carburetor may need cleaning to allow more fuel to the engine. Make sure the muffler and fuel filter aren't plugged. Hope this helps!
Dec 27, 2010 | Garden
I have the hand held 4 stroke blower and have been having troubles with the full trottle blowing. If i get to that point it tends to bog down and if i dont let off the gas it will die out. I have cleaned...
A good carburetor cleaning may be ion order here. If you can get it, try running some SeaFoam through the fuel system. Check the bottle for the correct amount to use. If you guys don't have that available, try using some Berryman B-12 ChemTool fuel system cleaner in it. The dosage rate on that is about 1 ounce per gallon of gas or so and it will clean. I am trying to help you keep from taking the carb off and manually cleaning it. Try introducing one of those 2 additives to your fuel tank, run the machine and post back if needed.
Dec 13, 2010 | Makita Garden
Homelite leaf blower bogs down.
I don't mean to over simplify this, but are you using fresh gas? Gas blowers are extremely ticky when it comes to gas. They like it SUPER fresh. And while the gas and oil mixture should be right, it can be off a little bit and still run. Try draining all of the gas out, and then filling up with fresh mix. This is ALWAYS my first step with gas blowers, and it fixes the problem 75% of the time. Also make sure your spark plug is clean. If you are not sure, a new plug couldn't hurt.
Hope this helps!!
chad
Sep 29, 2008 | Homelite 'Yard Broom' Leaf Blower
Garden Logo
69 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
