Washing Machines
Problem for Washing Machines
Generic problem for all Washing Machines
No agitation or spin, but water pumps out.
By jwilhelmi on May 22, 2009
Kenmore 80 Series Model No: 110.20852990 The agitator nor the spin cycle works. It does pump the water out though. I can hear the motor operate. Leads me to believe that it is possibly a defective coupling / motor isolator. Am I correct?
Comments:
May 22, 2009
- I opened the washer and that was the problem. Thank you for your time. I will visit appliancepartspros.com for the correct part.
Same Problem
May 24, 2009
-   jsrock - I understand the coupling replacement.  I'm having a similar problem, but when its time to spin, the water doesn't come out, nor does the inside spin.  The motor makes a wining noise for about 8 seconds before the surge protector turns off the power.  I figured it was a motor problem, but I'm woried that the transmission might be locked and that's what's stressing the motor.  If I purchase a motor, I can't return it.  Any ideas?  -   Guest
Best Solution
posted on May 22, 2009
Very Helpful)
jsrock516
Rank: Guru  Washers & Dryers  Expert
Rating: 96%, 6996 votes
If the washer will fill and drain, but won't agitate or spin, you, indeed, may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupling can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria. Let me know if you have any questions. I hope you find this information helpful. NOTE: There are other problems that can cause the washer symptoms as you describe, but the motor coupling is the least expensive and easiest solution to try first. If the motor coupling is still intact, please let me know.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Washing Machines
Questions and Unsolved Problems for Washing Machines
Answer
Wondering about the GE GCVH6500K front-load washing machine? Cannot find any reviews etc online.
Answer
Are there any new washing machines made that still have direct drive. That means that the agitator... (More)
Answer
My Ge Adora washer fabric softener dispenser doesn't work at all (dispensing the softener). Also I... (More)
Answer
the start button on my hotpoint wt740 washing machine wont click on.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing... Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
