Question about Samsung PS50Q97HDX 50 in. Plasma TV
Best picture settings
Ihave a ghost effect on my tv screen
    Problem Solver:
  • 18 Answers
Hav a samsung ps51d495 if ya remotes same try these two things hold down the return button and popup comes up diagnosis sreen may do on yours 2nd one hold down the exit button and a popup come up sayin rest thing come up or go to ya menu do factory rest
Posted on Jan 03, 2014
My Sanyo Vizon 32 inch flat panel has times when part of the picture becomes a "white ghost". How do I adjust?
Actually that is quite a rare case on today's modern digital flat panel TV's. You're not saying where you live, and you're not saying if you have previous issues on older TV you had before digital, and (again) you're not even saying whether you're on a hill or deep into a gorge. No TV has ghosting these days, but if you're living in an area as above, go see the TV people and they will probably recommend a set top box. But that isn't really necessary if you have a modern flat screen TV because most of these TV do two things, they give you a crystal clear picture or they don't. Digital TVs have a channel searching system that does the searching for you, and, as the case may be, these only pick up the best channels that give the sharpest picture. Anything that is of poor reception they ignore, so you're actually missing all the channels available because of this ghosting issue. AN there is nothing to adjust on the ghosting, snowing and vertical or horizontal bars, etc. These issues are things from the past, e.g. old analog TV's.
Dec 28, 2014 | Sanyo Televison & Video
I have a Mitsubishi DLP WD-57831 and the dark colors are hazy/milky on the screen, and the lighter colors look normal. There's a 'ghosting' effect which makes it difficult to watch night time/dark scenes. ...
This tv require projection colors lens R,G,B clean and it coolant chemical replacement.Should check for it prices by a tv shop or shops for best prices for it services.
Feb 01, 2011 | Mitsubishi WD57831 Television
Sony Bravia with really bad ghosting
The little board on top attached to panel.
Jul 05, 2010 | Sony Bravia KDL-32ML130 32 in. LCD TV
Ihave had problems switching my thomson 30lcdb03 tv on for about 3/4 months. I have had a completely green screen, balnk screen with sound only, and a white ghosting on the picture. Now the tv will not...
thomsom or RCA tv;s are known for power supply issues
check yours for puffed up can like devices on both main and power board if you find one the value is on the side replace it and you will have fixed it won't hurt to try
Nov 20, 2009 | Thomson 30LCDB03B 30 in. HDTV
Ghost on the screen one is a circle in the middle of the screen, the size of a quarter, the second is a black could the size 2"x 5"
Usually when you get this "ghost effect" the caused by signals reflecting from large buildngs.To improve move antenna for best reception or install an aerial wit a small pick up front print.
Or check you have the correct aerial for the tv installed.
Nov 02, 2009 | Protron PLTV-32 Television
Hey, i have a samsung ln32b360, just 2 months old. worked beautifully when i got it, but recently it started ghosting a little in very specific situations. then it started ghosting a lot, but only in dark...
First,If there are double images or "ghost" images on the TV's picture, check the cable connections and make sure they are secure.Because the loose cable connection would be a chance for the ghost picture
But if the cable is perfect and if you still get ghost picture then here is the solution:
The LCD Panel is defective. The problem is the T-con board that is used to decode the signal from the main board to the LCD Panel. The only way to fix it is to replace the whole LCD Panel or T-con board if possible. The T-con will cost about 1/10 of the price as the LCD panel but except for a few new models, the T-con is not available. The LCD Panel is very expensive (usually from $600-700 for a 32" Sony).
The reason is that Sony makes the T-cons for each individual TV with different specs to match that of the LCD panel because of the low threshold for error between the LCD Panel and the T-con.
Its best to avil warranty and change the panel...
Please leave me comment, if you need furher assitance
Rnj VINODKUMAR
Oct 27, 2009 | Sony Bravia KDL-32ML130 32 in. LCD TV
Convergence
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Aug 20, 2008 | Hitachi 60V500 60" Rear Projection...
THE RED, BLUE, AND YELLOW COLORS SEPERATED ON A 52 IN HDTV. THE PICTURE SEEMS TO HAVE A GHOSTING EFFECT TO IT
Have you used the color convergence settings on your TV?When the settings are off you will get this effect sometimes if the TV was jarred pretty hard it goes out of alignment.There should be a setting on your menu.If that doesn't help it may need re aligned by a repairman.
Aug 10, 2008 | RCA Televison & Video
LCD picture distortion.
This is caused by a failure of the main board. The failure causes the refresh rate of the unit to be off creating a trailing or ghost effect. This will require a technician to replace that board though. Hope this help.
Feb 14, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Blurry Image problem with Mitsubishi WS-55805
Hello, if you want I can supply you with the service manual, please leave your email. Best regards, Arpi
Aug 14, 2007 | Mitsubishi WS-55805 55" Rear Projection...
Samsung PS50Q97HDX 50 in. Plasma TV Logo
281 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
