Whirlpool instruction manuals
Leaking water during spin cycle
Jimster
  • 240 Answers
SOURCE: Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Posted on Sep 09, 2007
robocop
  • 90 Answers
SOURCE: whirlpool washer wont spin during high spin cycle
Try www.Repairclinic.com.
Posted on Jan 19, 2009
SOURCE: My Whirlpool washer won't agitate or spin . But it does drain the water.
i also had the same problem, and it ended up being the coupler. It was not hard to replace, it cost me about 19.00. I didn't follow full recomende instructions. I tipped the washer backwards. Removed the drain pump and the motor itself. Then I removed the old coupling and placed the new one. The washer is working like new...
Posted on Jun 02, 2009
venexcsd
  • 1185 Answers
SOURCE: During the final spin cycle, water is leaking inside the machine
You have a problem with the pressure switch cutting in too early before all of the water has drained away from the outer drum
There is either an obstruction in the outlet pipe or pump which is not allowing the water to discharge fast enough.
The machine is then spinning with too much water left in the outer drum added to the water which is being expelled from the clothes equals leaking
Take the hose off the back of the machine and put it in a sink , make sure it is secure and do a rinse cycle
Watch the outlet and make sure it is a strong flow if it is weak then you have probably got an item of clothing stuck in the pipe from the drum to the pump and a strip down is required
One more thing there is a small plastic bottle attached to the back of the outer drum this has tube which leads to the pressure switch
Make sure there is no congealed soap in the Air Bell as it is called
Posted on Jul 05, 2009
GodBlessU
  • 3513 Answers
SOURCE: water leaks during final spin cycle only
The first thing to do is get the machine up off the floor onto a base that allows you to slide under machine on your back with a flash light. Make sure whatever you decide to lift machine up onto is very stable and durable. Bricks, blocks, or a utility cart maybe. You need to look under machine to see where the leak is coming from. You want to make sure it is not going to fall on you. The machine is not that heavy, just awkward to lift or move because of it's size. So, you could slide something under each corner, one at a time, or ask a friend to help lift it onto a base. Now you are ready to go. Don't worry, this is really easy.
Get a towel, flashlight, and start machine on a small load with shortest cycle set.(probably delicate). After you start machine, slide under and and try to find where water is leaking from. The pump is going to be a plastic circular shape thing with ridges on outside. Probably dead front center and attached to motor. If water is leaking anywhere from plastic circle thing, then this is your problem. BUT, also follow all the black hoses that are under machine. Sometimes leak can be a cracked hose or loose attachment. That is real cheap and easy. The hoses are attached with metal ring deals. You take a pair of channel locks or big pliers and squeeze them to open. There are 2 or 3 hoses that attach to pump that will need to be removed if this is where leak is coming from. Then, the pump is only attached with metal clips that you pull out to release pump from motor. No tools needed. Take the pump to sears or local appliance shop and I guarantee they will have replacement.
Thank you for contacting Fixya.com
Posted on Aug 10, 2009
Kenmore, model 796.4031, water draining out of opening in back of washer onto floor during spin cycle, this hole is not on the picture in the manual!
Seven water should not be coming out of anything but the drain hose-open it up and look for loose hoes or connection which would leak because of the vibration during the spin cycle-cheers Denny
Oct 18, 2013 | Whirlpool Washing Machines
Whirlpool Washing Machine Leaking At top During Spin Cycle
Is it possible that the water level is too high. This can be caused by the sensor that controls the amount of water. The control knob that says small low medium large does it work if you put our small setting is the water stopped early like it is supposed to. If the water level is too high during spin cycle it is possible to run up and over the side. Let me know Ed
Nov 28, 2011 | Whirlpool Washing Machines
My whirlpool wtw5500sq0 leaks water when washing
There can be many causes for this leak, and where it leaks helps diagnose what to fix. Most commonly the water pump leaks from its seal and bushing over time since it spins whenever the motor is engaged. The reason it never spins water out until the spin cycle engages is because it is turning in the opposite direction as flow to prevent water running out as you wash, You way also have a separation of the washtubs water ring, or a crack near the top, since the leak only happens during wash time.
Mar 18, 2010 | Washing Machines
Water coming out of the botton during spin cycle
Take the bottom panel off the waher, put water in the machine, and watch to see where it is leaking. If you don't see a leak during the regular cycle, put the machine in drain and spin mode, and watch for leaks there. You should find your leak during one of these cycles so you will know what part you need.
Feb 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer stops after agitation cycle
Maybe check the belt is it cracked worn or fibers showing if so replace it
Jul 26, 2009 | Whirlpool Washing Machines
Oct 18, 2008 | Whirlpool LSR5132PQ Top Load Washer
Washing Machines Logo
225 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
