Question about Sport & Outdoor - Others
Replacement parts fort marksman 1010
Retaining clip for marksman 1010
2 Suggested Answers
  • 97 Answers
SOURCE: The color cartridge retainer clip has broken. I
You will need to replace the complete carriage unit.
Posted on Sep 01, 2009
Is it possible that someone replaced the stud that is mounted on the brake pedal arm and to which the brake light switch and the push rod are attached.
It sounds like someone was performing maintenance before you on the brakes for an exceptionally similar issue and lost/broke the retainer clip. Run down to your local parts store and get the correct retention hardware to replace the cap-style retainer and repair it correctly. Brakes are the last thing I want incorrectly repaired.
Oct 22, 2017 | Cars & Trucks
How do I replace bugaboo frog chameleon gekko rear wheel retaining clip?
Old clip just pulls out with pliers if it's jammed. Hard part is finding a new clip. Try eBay or face book. I sell them but have to post them from New Zealand. Google bugaboo repair guy.
Oct 31, 2015 | Bugaboo Frog Baby Gear
2000 model ford forte antenna removel
Power antennas require two people to replace. watch old mast as radio is turned on and off, then remove retainer nut and parts turn on and assist old mast out watching the teeth on plastic cable. fully extend new mast and lubricate with machine oil 3 and 1 works great feed new mask trying start teeth then turn radio off feeding into motor assembly install retainer parts and work antenna several time the overrun clutch will make final setting.
Nov 09, 2013 | Ford Cars & Trucks
Parts schematic marksman repeater pistol
http://www.pyramydair.com/manual/marksman-1010
This is easy to disassemble but take careful notes/ pictures as you go because the springs have to be in the right places.
Oct 21, 2013 | Sport & Outdoor - Others
Water leaking from bottom part of the faucet ...not sure if the model is a 10433 Fort Single control pullout
I had a similar problem with my relatively new Forte model. I disassembled the handle, removed the retaining ring and the valve assembly. I thought at first it was the valve assembly but wasn't convinced. I continued to remove the entire faucet hub by gripping and pulling straight up. When I did, the diverter valve popped out of the back to the counter behind the sink. I cleaned all the parts up, made sure all the rings were in place, presse the diverter securely into place back in its hole, and reassembled the rest of the parts. That seemed to do the trick. I'm guessing that the diverter lost its seal and was displaced inside the hub. Hope that helps someone else.
Jul 26, 2010 | Kohler Model 10433: FortĀ® Single-control...
How do you remove a push on retaining nut on the shaft of a kenmore dishwasher
You need a push-on-retainer removal tool (of course). However, what most people use is a pair of pliers and rotate back and forth while pulling and it will slowly wiggle off. When you buy a replacement part, many times the push-on retainer clip comes with the part and you are expected to simply ruin the clip to remove it. Goodluck<Macgivor
Jan 16, 2010 | Kenmore Dishwashers
Top arm on my Maytag MDB5600AWW keeps falling off
Sounds like the retainer clip for top arm is defective. Replace the following parts:
1: 99002676 Washer Arm
2: 99002753 Top Washer Arm Retainer
To replace unclip top manifold from rear top clip on back wall then pull down on top retainer clip and remove arm, replace in reverse of these instructions.
Part can be ordered off net or thru any appliance parts house.
Nov 12, 2009 | Dishwashers
Marksman 1010C repeater air pistol
sorry if you already learned but you have to **** it, and at the front under the barrel exit is a button looking shape press down on that really hard and on the top of the gun a sloped shape should appear. do not put the bb in the circle shape hole put the bbs in the top square shaped hole. push the object down and aim then pull the trigger!
Sep 08, 2008 | Sport & Outdoor - Others
Sport & Outdoor - Others Logo
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
