Question about Epson Stylus CX6600 All-In-One InkJet Printer
Change the ink cartridge in the CX6600
Could you please tell us how to get the carriage to move over so we can change out the cartridge on the Epson CX6600.
Brenda
  • 59 Answers
You should be able to navigate on the little screen directly on the printer. try pressing the left or right arrow keys until you see change cartridge.
Posted on Oct 19, 2007
SOURCE:
HOW CAN I CHANGE A INK CARTRIDGE IN MY EPSON DX7400 THAT IS NOT EMPTY
Connect the power cord, rise the cover that accesses to the print-carriage, turn On the printer; when the print-carriage move to left, unplug the power cord then, manually, move the carriage until the right area where you can open the cartridges-cover and change the cartridge you need.
May 21, 2010 | Epson Office Equipment & Supplies
I forgot how to change my epson cx6600. Please
There is a general how to on the printer manual.
Please visit this link:
http://files.support.epson.com/pdf/cx66__/cx66__pg.pdf
The steps on how to change the ink cartridge is on page 12.
Aug 22, 2009 | Office Equipment & Supplies
Can not change ink for epson c 91
cannot change ink. Turn on, and just unplug power when cartridge is moving. cartridge will stop not in parking position. Just move head carriage to replacement position.
Jun 21, 2009 | Epson Stylus Photo 1400 Printer
Changing Cartridges does not move into view so I change it
try the on/off button with the lid open. it should move the cartridges.
Jun 21, 2009 | Epson Stylus C86 InkJet Printer
Changing ink cartridge
Press the Setup Mode button to enter the Setup Mode and press the A button repeatedly until 5.Ink cartridge appears on the LCD panel, and then press the Color button.
The ink cartridges will move to the replacement position.
Open the scanner unit. Squeeze the cartridge end tabs and lift out of printer. Press new cartridge into carriage until it clicks into place, close the cover until it clicks closed. Close the scanner unit.
Still unsure? Download & unzip the user guide from Epson:
http://esupport.epson-europe.com/SupportHome.aspx?lng=en-GB&data=nKGrQtfEm6nvfdMIp7OaUCLjFzayZ3Y+
Please take a moment to rate this solution, thanks.
Mar 20, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Remove ink cartridge
I found that the proper way to do it only worked when the ink light was flashing red. Then when I pressed the stop button it moved across and stopped beneath the marker to show which cartridge needed changing. The I pressed the stop button again and it moved to a place where I could change it.
This happened despite the fact that the pictures I was printing blatently showed that I needed to replace my ink, it wasn't until I had printed the liney pictures a few times that the printer decided the ink level was low enough to turn the flashing light on and let me change it.
Jan 23, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Changing Cartridges
I inspected the users manual, there it writes:
The steps below to replace an ink cartridge: Caution: Leave the empty cartridge installed until you have obtained a replacement, or the ink remaining in the print head nozzles may dry out. To ensure good results, use genuine Epson ink cartridges and do not refill them. Other products may cause damage to your CX6600 not covered by Epson’s warranty. 1. If an ink cartridge is empty: Look at the LCD screen to see which cartridge is empty, then press the x Color button. If an ink cartridge is low: Press the Setup button to enter Setup Mode, then press the green button next to the LCD screen until Replace Ink is displayed. Then press the x Color button. 2. Lift up the scanner 1314127a0e502194c0d970046a123efc.png 3.Wait for the ink cartridge holder to move over, then open its cover.
4. Identify the cartridge you need to replace. Press in the tab at the back of the cartridge, then lift it straight out. Dispose of it carefully.
5. Before unwrapping the new cartridge, shake it gently four or five times. Then remove it from its wrapper.
6. Insert the new cartridge into the holder. Press down firmly until it clicks into place.
7.
Close the ink cartridge cover.
8.
Lower the scanner.
The CX6600 begins charging the ink delivery system and “Charging . . .” appears on the LCD screen. Wait for charging to finish before using your CX6600.
Caution: Never turn off the printer while “Charging . . .” appears on the LCD screen, unless the CX6600 hasn’t moved or made noise for more than 5 minutes.
Jan 23, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Cartridge changing
You can download the manual from the link below: http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=41664&prodoid=46253282&category=Products Please update the question & let us know if the information given was useful to you - Good Luck!
Sep 02, 2007 | Epson Stylus CX6600 All-In-One InkJet...
After replacing the black ink nothing prints
Before taking out a new ink cartridge from its package, shake it four to five times. Are you sure you have the proper ink replacement cartridge.The following Epson ink cartridges should be used in your device: * Black: T0431 (high capacity cartridge) or T0441 (standard capacity cartridge) * Cyan: T0442 * Magenta: T0443 * Yellow: T0444 How did you discover the ink was low? Did the machine prompt you or was the printer not printing properly? The other colors should blend together to give you atleast some form of black. If the printer alerted you to change the cartridge...Go back through the procedure to install a new cartrige. Follow the steps below to replace ink cartridges. Make sure the CX6600 is on. When the ink is empty: Refer to the LCD panel message to see which ink cartridge is empty, then press the Color button. When the ink is low: Press the Setup Mode button to enter the Setup Mode and press the A button repeatedly until 5.Ink cartridge appears on the LCD panel, then press the Color button. The ink cartridges move to the replacement position. Make sure that the document cover is closed, then open the scanner unit. Open the cartridge cover. Pinch the sides of the ink cartridge that you want to replace. Lift the cartridge out of the CX6600. reinstall the same cartridge. (Try shaking it a few times again) If none of the above works uninstall the printer. Download the newest drivers from epson and the should straighten it out. Good Luck. Tim
Feb 20, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Epson Stylus CX6600 All-In-One InkJet Printer Logo
222 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
