Question about Okidata Oki B431DN LED Printer - Monochrome - 1200 x 1200dpi Print - Plain Pa
How to fix service call 231: error 03
Ran out of paper. Added paper shut paper drawer and this error appeared.
231 service call error 03
https://www.youtube.com/watch?v=5C2KAer0818
Mar 14, 2016 | Oki Printing Solutions C511DN LED Printer...
How can I fix oki c3530 231: fatal error 03?
RFID Reader I/F Error An interface error was detected
with the RFID reader device.
01: communication error between
the RFID reader and the engine
PCB.
02: the transceiver circuit error of
the RFID reader.
03: communication error between
the RFID reader and the Tag
chip.
04: the RFID Tag detection error
Jun 21, 2014 | OKI C5800Ldn Led Printer
Oki
231 means RFID reader I/F error. 03 means Communication error
between the RFID reader and the tag chip. The remedial measure is to check for normal connection of the antenna cable.
May 06, 2014 | Oki Electric Industry C830DTN Laser...
Error e030 copier toshiba 202L
E030 indicates Paper remaining inside the equipment at power-ON.
If no paper is found, probably the actuator/sensor is faulty. Kindly perform input test on following sensors:
Exit sensor 03-[FAX]ON/[2]/[B
Registration sensor 03-[FAX]ON/[2]/[A]
Upper drawer feed sensor 03-[FAX]OFF/[6]/[E]
Aug 28, 2012 | Toshiba e-Studio 202L Copier
OKI C5650 231 FATAL ERROR 03
I tried putting 1.5mm of plastic foam under the RFID chip to raise it up in the toner cartridge. This seemed to work.
Jan 17, 2012 | Office Equipment & Supplies
Hp plotter T610 bacalhau. 21.1:03 Erro - troquei Estação de Serviço / APC e continua Dando o Mesmo Erro
The service station cannot move. Look for pieces of paper in there. Replace if broken. It's too dirty job to take apart the service station, to clean and find what is wrong with it.
Aug 05, 2010 | HP Designjet T610 InkJet Printer
Não Consigo acessar Serviço de hp plotter Calibração T610. apresentou o Código de 21.1:03 Erro, Substitui uma Estação de Serviço e continuou o Mesmo Erro, Substitui...
helo
Try the following:
Switch the Power OFF from the back of the Printer and disconnect the
Power cord. Check the Primer Tubes. Reconnect the power cord and
power On the Printer.
Perform the Service Station diagnostic test to troubleshoot the problem
further
If the System Error continues, replace the Service Station .
If the System Error continues, replace the PrintMech PCA
Jul 29, 2010 | HP Designjet T610 InkJet Printer
I was just switching on a copier machine ''Minolta Dialta di 522'' and it appear on the screen a message saying that there is an error 0990. What is that error and how can i solve it?
Most C0900 range codes and specifically the 990 code refers to paper tray lifting. Pull out the paper drawers and check all the paper. Reload all the trays carefully. Then open/close the front door or turn off/on the machine to reset. If the code goes away great. If not then open all of the paper drawers, reset the code with the drawers OPEN. Then close each drawer 1 at a time waiting 30 seconds between each drawer closing. Once you close a drawer the code will come up within about 10 seconds. This will tell you which drawer is causing the issue. You can leave it out a bit so you can use the machine until you either find the issue with the tray or get a service guy out to fix it.
Good Luck
Jan 24, 2010 | Konica Minolta DiALTA Di200 Copier
OKi C5800ldn 231: fatal error 03
I have the Oki 5650 which had been great for about 18 months. Then found that the C cartridge was showing error as 'not installed'. After much fiddling about with it and checking on the internet I can now rectify this by either pushing down on the top of the printer while it boots up, or removing the small chip on the left top of the toner (make sure you have 'earthed' yourself to prevent any static damaging the chip when you handle it!) and taping securly onto the top of the cartridge above the chips proper slot. This now has been working OK for 6 months. Strange how this only affects the C cartridge (which has also been replaced and had the same problem). I suspect that the printers RFID chip reader for the C cartridge is having problems reading the chip and moving the chip closer to the reader by either taping to the cartridge top of puching on the top cover while printer boots up resolves the problem (for now anyway!) This can also trigger the 'service call 231 fatal error 03' message which also disappears if you follow the above procedure.
Hope this helps you.
Feb 13, 2009 | OKI C5800Ldn Led Printer
Okidata Oki B431DN LED Printer - Monochrome - 1200 x 1200dpi Print - Plain Pa Logo
76 people viewed this question
Top Okidata Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Okidata Audio Player and Recorder Expert? Answer questions, earn points and help others
