Question about Sharp Televison & Video
Sharp LC-LE735U, I get one short blink and then a long blink. No OPC blinks. I have cycled the TV and it works for a while, then it shuts off and back to the blinks. The last time I cycled it, it flip
This TV was purchased in March of 2012
    Top Expert:
  • Sharp Master
  • 74,383 Answers
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can vet an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. http://electronicshelponline.blogspot.com/ Check the site in 'Mosaic' view. It will make search easy.
Posted on Jan 03, 2014
3 Suggested Answers
  • 41 Answers
SOURCE: Blinking power and opc leds on front of unit
From the information you have provided failed capacitors in the power supply is likely causing the problem. The safety circuitry shuts the TV set down when it detects a problem. This model of TV has over 2,000 parts which include millions of transistors inside the integrated circuits. The capacitors will change value, leak and become defective. Resistors will change value and burn. Integrated circuits and transistors can go bad. This can cause other components to become defective, which can have a domino effect and cause other parts to fail. Replacing one defective part may make the TV operate for a short time but the part will fail again since if the parts that caused the failure to begin with are not replaced. The only way to know for sure what is causing the problem, which parts that are no longer within factory specs and for proper repair all the electronics must be diagnosed by someone with the correct electronic test equipment and the skills to use the test equipment. The repair should cost about $250 if carried into a TV repair shop. A small TV repair shop will often charge less than a large repair facility.
Posted on Feb 25, 2010
  • 8457 Answers
SOURCE: sharp lc-46d64u blinking codes. power blinks 3
Very common in Sharp,tries unplug,replug back in,tries again off/on couple times,still happen blinks than ur main video board it dead.
Posted on Nov 12, 2009
We have a SHARP AQUOS model#LC-C5277UN TV. Power and OPC blinks 2 times then OPC blinks 1 time. Black screen. HELP PLEASE
parece que tienes un problema en la fuente de poder ,debe haber un elemento en corto probablemente un capacitor .
Jan 06, 2017 | Sharp Televison & Video
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/54708-4-sharp-power-button-flashing
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from www.tomsguide.com
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
www.normsweb.com/tektips/42dh77.shtml
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
There are two green lights blinking at the bottom of the tv. where the power light is..i believe it's the opc lights. the tv shuts of it self and the two lil green light blink...we put the tv power...
The tv main logic board known as a tv Tuner signal board it is the causes and the problems.The tv main logic board,the tv Tuner signal board it is shorted and not taking in and sustance power from the tv power supply board anymore that why tv Power and OPC LED lights indication are flashing together.This main logic tv Tuner signal board that the board where that take in the tv incomming broadcasting signal wire plug into it.U must replaced the main logic tv Tuner signal bard to fixed this problems.If U have some mechanicals skills like take things aparts and putting it back together again?Yes,tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish main logic tv Tuner signal board for the replacement.Tries tv unplug,replug it back about an hour later.Tv might work again for awhile though,but to fixed this problems for good the main logic tv Tuner signal board must have to be replace.
Aug 22, 2011 | Sharp Aquos LC-52SE94U 52 in. LCD HDTV
I have an aquios LC-42D64U which suddenly has the following two lights blinking power & OPC. They both blink, once together, the second blink is only the power, and repeating the sequence. I've...
Sharp LED/LCD EEP cleared Step 1 Remove Mains Plug 2 Press On/Off Switch from LED/LCD Panel 3 Press Ch Down & Input Switch together and plug in mains cord 4 LED/LCD will start 5 "K" will appier on Screen 6 Press Ch Down & Vol Down from LED/LED Panel 7 1/9 Page will appier on Screen 8 Go to 9/10 page by pressing Up & Down arrow of remote 9 Select EEP Cleared 10 Press ok button from remote 11 On Screen dispay EEP running 12 Remove Mains Plug after complete EEP Run 13 Restart LED/LCD
Feb 05, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Power light comes on for about 30 secs, something clicks and both power and ocp lights start blinking contineously. the screen does not light up
I have this model of the sharp tv.Happen to me very often the Power and OPC LED light indicators blink continueosly.Not the power supply board,it the Tuner board that take in the comming broscast signal that have the problems.You still can used this tv.Push the power button sometime the tv it will work right away.Not,each time POWER and OPC lights continueosly blinks.Just push the power button again each time the POWER and the OPC continueosly blinks.Just have push power button again about 4 times each time Power and OPC blinks recycles,it will finally show the backlight and picture come on.My guest,if u do this by pushing power button to recycles about 10-12 times each time the POWER and OPC blinks it time to change the Tuner signal board.
Jun 03, 2010 | Sharp LC-C4655U 46 in. LCD TV
THE TV IS CUTTING OFF BY ITSELF AND THE OPC LIGHT IS BLINKING
This problems very common on Sharp Tv.Do ur tv LED power light turn on solid first.Few mins,than LED,OPC flahes.Power LED,OPC flashes,push power button again,do this at leat 5 or 6 times somtimes the backlight will come back on and work.The power LED,OPC light flashes,turn off/on more than 5 or 6 times don't work.Ur Tuner signal board is dead,must replaced.
Mar 30, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
My sharp LC-37d62u display problem
This problem very common in sharp tv.The POWER,OPC flashes.First turn on have power LED indicator light stable at all? Tries the power again couple times will have backlight come back on,than it will work.Not at all more than 5-6 times than ur main turner signal board is the problem,must replaced.
Jan 05, 2010 | Sharp LC 37D62U 37 in. LCD HDTV
Sharp LC-37D4U, the monitor doesn't turn on
It is hard to say without first looking at it.
Jun 28, 2017 | Sharp Aquos LC-32D40U Television
Tv shutting off
How many times per second does the POWER led blink? (dont worry about the OPC).
1x per second (constant, steady blink) = bad inverter/lamps
2x per second = bad power supply
3x per second = bad main board
You can buy the parts online and fix if yourself!!
Dec 02, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
460 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
