Question about Toshiba Computers & Internet
This device cannot start. (Code 10) - Toshiba Computers & Internet
    Champion:
    New Friend:
  • 206 Answers
Make sure that you have the most updated driver installed for the card. Another thing to try is removing the card (after shutting down your computer) and boot it up. Once Windows loads, give it a few minutes and then shut it back down. Reinstall the card and turn it back on.
Drivers Software Support Toshiba
Posted on Jul 15, 2014
High definition audio controller This device cannot start. (Code 10)
If you run into the error "This device cannot start. Code 10 (often followed by a driver identifier, for example "This device cannot start. Code 10 in audio driver"), here is what it means.
The Windows error "This device cannot start. Code 10 or "This device cannot start. (Code 10)" is a hardware error that most commonly means that you have a bad, missing, or incompatible device driver. So, for example, "This device cannot start. Code 10 in audio driver" means that you have a bad or missing or incompatible driver for your sound card.
The technical explanation for this message, according to Microsoft, is this:
"If the device has a FailReasonString value in its hardware key, that string appears as the error message. The driver or enumerator puts this registry string value there. If there is no FailReasonString in the hardware key, you receive the following error message:
What does that mean in plain English? It means that if the device which is throwing the error has added its own custom error text to your Windows system when the device was installed, then when the device encounters an error, you will see the custom error message specific to that device. But if it doesn't have its own custom error message, then Windows uses its own generic error message for devices, which is "This device cannot start. (Code 10)"
Microsoft recommends that when this happens, you click "Update Driver" to update the drivers for the device. You can also start the Windows troubleshooting wizard by going to the general properties tab of the device, and clicking on "Troubleshoot".
Before doing this, be sure that you have the correct and most up-to-date versions of the driver(s) for that device. You can also try uninstalling and reinstalling the device, using the disk which came with it.
Finally, you can go to the website of the device's manufacturer, and check their downloads or support section for current, up-to-date drivers.
Go to Toshiba support site look for Toshiba Satellite A135 drivers, download the one for your windows 32 or 64 bit install, restart and off you go. Regards, Mike
May 19, 2014 | Toshiba Satellite A135 Notebook
Dvd player doesn t work
The Code 10 error is one of several Device Manager error codes. The Code 10 error will almost always display in the following way:
Details on Device Manager error codes like Code 10 are available in the Device Status area in the device's properties: How To View a Device's Status in Device Manager.
Important: Device Manager error codes are exclusive to Device Manager. If you see the Code 10 error elsewhere in Windows, chances are it's a system error code which you should not troubleshoot as a Device Manager issue.
Cause of the Code 10 Error
A Code 10 error is generated when Device Manager can't start the hardware device, a situation usually caused by outdated or corrupted drivers.
A device may also receive a Code 10 error if a driver generates an error that Device Manager doesn't understand. In other words, a Code 10 error can sometimes be a very generic message indicating some kind of unspecified driver or hardware problem.
Error Code 10 Troubleshooting
1.Restart your computer if you haven't done so already.
There is always the chance that the error Code 10 you're seeing on a device was caused by some temporary problem in Device Manager or with the hardware. If so, a reboot might fix the Code 10 error.
2.Did you install a device or make a change in Device Manager just before the Code 10 error appeared? If so, it's very possible that the change you made caused the Code 10 error.
Undo the change if you can, restart your PC, and then check again for the Code 10 error.
Depending on the changes you made, some solutions might include:
•Remove or reconfigure the newly installed device.
•Roll back the driver to a version prior to your update.
•Use System Restore to undo recent Device Manager related changes.
3.Reinstall the drivers for the device. Uninstalling and then reinstalling the drivers for the device is a likely solution to a Code 10 error.
Important: If a USB device is generating the Code 10 error, uninstall every device under the Universal Serial Bus controllers hardware category in Device Manager as part of the driver reinstall. This includes any USB Mass Storage Device, USB Host Controller, and USB Root Hub.
Sep 14, 2013 | Dell Dimension E510 PC Desktop
Device cannot start code 10
Device cannot start code 10 means that you are using the wrong drivers for the device or the device has a problem try using system information for windows to find out what drivers it needs if that is the problem but if not the device might need replacing
Aug 03, 2013 | ASUS Computers & Internet
HI
A Code 10 error is generated whenDevice Manager can't start the hardware device, a situation usually caused byoutdated or corrupted driver A device may also receive a Code 10error if a driver generates an error that Device Manager doesn't understand. Inother words, a Code 10 error can sometimes be a very generic message indicatingsome kind of unspecified driver or hardware problem. Uninstalling and then reinstalling the drivers for the device is alikely solution to a Code 10 error. If reinstalling driver is not working than try to rollback the driveror restore the system on previous date.. ifyou find this is helpful for you so please rate me this will encourage me to domore free work..
regards
sandy
Sep 07, 2011 | Lexmark International Lexmark X422
It gives code 10 error. device can not start
HI
A Code 10 error is generated whenDevice Manager can't start the hardwaredevice, a situation usually caused byoutdated or corrupted driver A device mayalso receive a Code 10error if a driver generates an error that Device Managerdoesn't understand. Inother words, a Code 10 error can sometimes be a verygeneric message indicatingsome kind of unspecified driver or hardware problem.Uninstalling and then reinstalling the drivers for the device is alikelysolution to a Code 10 error. If reinstalling driver is not working than try torollback the driveror restore the system on previous date..
regards
sandy fixya
Jul 18, 2011 | Lexmark International Lexmark X422
Code 10
If you run into the error "This device cannot start. Code 10? (often followed by a driver identifier, for example "This device cannot start. Code 10 in audio driver"), here is what it means.
The Windows error "This device cannot start. Code 10? or "This device cannot start. (Code 10)" is a hardware error that most commonly means that you have a bad, missing, or incompatible device driver. So, for example, "This device cannot start. Code 10 in audio driver" means that you have a bad or missing or incompatible driver for your sound card.
Mar 15, 2011 | Computers & Internet
My audio driver is not working (error 10)
I suggest trying an update, or if you just updated it roll back the driver.
Mar 03, 2011 | Acer Realtek AC'97 Audio Driver XP W2K W98...
Cd rom wont start (code 10)
Recommended resolution
Device failed to start. Click Update Driver to update the drivers for this device. On the General Properties tab of the device, click Troubleshoot to start the Troubleshooting Wizard.
For more information about Code 10-related errors , click the following article number to view the article in the Microsoft Knowledge Base:
943104 (http://support.microsoft.com/kb/943104/) Description of Code 10-related errors that Device Manager generates on Windows XP-based computers
Jun 21, 2008 | E-Machines Computers & Internet
Code 10: Device Cannot Start
Code 10 refers to the operating system not having drivers to talk to the card. Without the drivers running windows cannot run the device.
Mar 08, 2008 | Philips SAA7130 TV Tuner/FM Radio/Video...
Computers & Internet Logo
85 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
