Can't do a test print to align new cartridges
Hi - I just got to the bottom of my ink cartridges before I realized that I was out, so after changing to new ones (except the black) I can not do a test print. Any help?
  • laxmankumar
    laxmankumar May 11, 2010
    please mention your printer model to provide help.
  • 484 Answers
Kristy,
Have you used a cotton swab (Q-Tip) with a gentle cleanser on it, to wipe both the metal strips/contcts on the bottom of the cartridges, and also the same items with which they interface in the printer's cartridge well?
If you can clean them very gently, you might find that they make better contact, thus allowing the print to work again.
Ink can be oily at times, and that will interfer with the contact between the two types of metals, which make the electrical contact to allow the printer to work.
Give it a try. Read the cartridge's packaging, as they may have some instructions on what kind of liquid cleanser to use. Perhaps an alcohol, like rubbing alcohol, or an acetone, from nail polish remover.
But you must be sure of what to use, otherwise if you use something too caustic, you can ruin it instead of fixing it.
Good Luck,
-a.
Posted on May 22, 2009
Hi, Wonder can you help my printer keeps printing off test page everytime it is turned on. this is only happening since i changed the cartridge, never did this before. thanks
Your printer is printing alignment pages, because the cartridge alignment was not completed since you replaced them. Follow the below steps to complete alignment.
  1. Turn the printer OFF and then turn back ON.
  2. Wait until the alignment sheet prints out fully.
  3. Place the alignment test page over the scanner glass.
  4. Press start color scan button.
  5. The printer "power" light will start flashing, indication the alignment process.
  6. After the printer stops flashing, turn off and then ON the printer.It will not print any test pages further.
We need to run alignment test every-time while we replace ink cartridges.
Regards
Riztech
Nov 27, 2010 | HP Photosmart Premium C309A All-In-One...
Ipls guide me for changing the catridge
  • Turn the printer on and confirm that there is paper in the tray. After the new ink cartridges are loaded, the printer will need to run an alignment test. On the front of the printer, above and to the right of the paper tray, there is an access door that swings open sideways. Open the access door. The ink cartridges will move so that they can be reached through the door.
  • Press both print cartridges down until they pop out of their holders. If you will have difficulty remembering each cartridge's position, remove only one at a time. Once a cartridge is popped out of its holder, it can be lifted freely through the access door.
  • Prepare the new ink cartridges for installation by removing them from the packaging and removing the tape from the bottom of each cartridge. Be careful not to touch the delicate metal contacts on the bottom of the cartridges.
  • Install the cartridges by aligning them slightly below the holders, then pushing them up and forward until they snap into place. Close the access door when you are finished. A test sheet will begin printing to check the alignment of the cartridges.
  • Open the lid of the scanner and place the test page face down on the scanner bed. The upper-left corner of the test page should line up with the arrow in the corner of the scanner bed.
  • Push the "Scan" button on the printer control panel. The scanner will scan the test page into the printer's memory, which will then be used to make any alignment adjustments that are necessary. The printer is ready to use when the test is complete
  • Oct 30, 2010 | HP DeskJet F4280 All In One Printer InkJet
    New brother laser printer hl-2140 with new ink cartridge . All printed pages are covered with black ink. Slide the cleaner and even change cartidge, but same problem.
    Please try to re align the print heads and service the carraige assembly of the printer ( Place where you slot in your cartridge). if it doesnt work then there is a leakage on the ink piping system.
    Replace the Ink service station.
    Sep 23, 2010 | Brother HL 2140 Laser Printer
    I just installed a new color cartridge in my 8650 Lexmark printer. The ink cartridge acts as if it is empty. Printer keeps telling me to align cargridge. Worked perfectly before the new ink installed. Not...
    1. On your computer, go to "Start," "Programs," "Lexmark Series." Click "Lexmark Control Program."
    2. Step 2 Select the "Cartridges" tab. Click "Change Cartridges." The Change Cartridges screen appears, displaying the animated instructions for installing or changing cartridges. When you have finished viewing the animation, click the "Finished" button.
    3. Step 3 Remove the tape covering the print head of the new print cartridge. Insert the new print cartridge as shown in the animation.
    4. Step 4 When the "Choose Cartridges" screen appears, select the cartridge(s) you installed in your printer from the list boxes. Click the appropriate box to reset the ink levels to full. Click "OK."
    5. Step 5 The Automatic Alignment screen appears. Click "Align" to align the print cartridges for best print quality. The printer prints a page with a bi-directional alignment pattern. On the printed test page, locate the number that comes closest to forming a straight line under the bi-directional alignment pattern. Enter that number as the bi-directional alignment setting in the Alignment Cartridge dialog box. Click "OK."
    Nov 25, 2009 | Lexmark All-in-One Printer with PictBridge
    How do I change the ink cartridge on my Dell 810 printer
    Ink Cartridge Maintenance Replacing an Ink Cartridge
    1. Turn on your printer.
    2. Lift the printer unit, and position the scanner support between the tabs to hold it open.
    The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
    1. Press down on the ink cartridge lever to raise the ink cartridge lid.
    1. Remove the old ink cartridge.
    1. Dispose of the old cartridge properly.
    2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
    1. Insert the new ink cartridge.
    1. Snap the lid closed.
    1. Lift the printer unit, and hold the scanner support up while lowering the printer unit until it is completely closed.
    rcrtdrc1.jpg Aligning an Ink Cartridge You may need to align the ink cartridge when characters are not properly formed or are not aligned at the left margin, or when vertical or straight lines appear wavy.
    To align the ink cartridge:
    1. Load plain paper. For more information, see Loading Paper.
    2. In Windows XP, click Start® Control Panel® Printers and Other Hardware® Printers and Faxes.
    In Windows 2000, click Start® Settings® Printers.
    1. Right-click the Dell AIO 810 icon.
    2. Click Printing Preferences.
    The Printing Preferences dialog box opens.
    1. Click the Maintenance tab.
    2. Click Align Print Cartridge.
    3. Click Print.
    A blue and black alignment page prints.
    1. After the alignment page has finished printing, place the page face-down on the scanner glass. Make sure the upper left corner of the front of the page aligns with the arrow on the printer.
    1. Press the Scan button scanicoa.jpg .
    The page is scanned. When the scan is complete, the cartridge is aligned. You may discard the alignment page when the alignment is complete.
    Please download the manual from the link below and go to chapter Ink Cartridge Maintenance:
    http://support.dell.com/support/edocs/systems/PRN810/en/ug/ug_en.zip
    Hope it helped.
    Nov 22, 2009 | Office Equipment & Supplies
    I changed the black ink cartridge and the printer
    Calibrate your new blank ink cartridge, have some nozzle check, cleaning check, and printer alignment. This are procedure that new ink cartridge will have to calibrate before you use. Epson printer are very sensitive when capable of changing ink cartridge. Unlink HP directly work without any print test because the cartridge head and ink join together, Epson with ink cartridge and the head separate.
    Have some test on it at Printer Maintenance.
    I'm sure 100% works on it.
    Sep 23, 2009 | Office Equipment & Supplies
    Hp psc 750 won't print with new color ink cartridge
    To solve the printing problem..
    # Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
    # Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
    # Continue doing this until it looks clean.
    # Then dab the cartridge on the towel to make sure the ink is flowing.
    # Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
    1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
    2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
    # Reinstall the cartridges, making sure you snap them correctly into the printer.
    Hope this help. Please Rate My Response! Thanks!
    Aug 24, 2009 | HP PSC 750 All-In-One InkJet Printer
    Mp370 nnot printing color even after changing ink tank
    take out both ink cartridges, lift up head clip and take out printhead block
    stand printhead block in a shallow dish of windex overnight, rinse it off, place back in printer, replace ink cartridges
    do a clean cycle
    Nov 21, 2008 | Canon MultiPASS MP370 All-In-One InkJet...
    46 people viewed this question
    k24674
    jasbo
    jasbo
