Question about ASUS K501J WXGA HD 15.6" LED Panel
Error 21 geometry error 21
  • 1,511 Answers
Is this a computer problem or what? Try another catagorey for your question.
Posted on Jan 29, 2014
Geometry options of philips 21 rf vardaan tv
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 27, 2016 | Philips Televison & Video
Philips magavox model 19pr15
1. To enter the Service Alignment Mode (SAM), press the following key sequence on the remote control transmitter: 0-6-2-5-9-6-Status.
2. From the top level SAM menu, use the Menu Up/Down keys to highlight the Geometry sub menu.
3. Use the Menu Left/Right keys to enter the Geometry sub menu.
4. In the Geometry sub-menu, use the Menu Up/Down buttons to select VAM.
5. Using the Menu Left/Right keys, adjust VSH so that the horizontal bar is properly centered, top to bottom.
6. Using the cursor up/down keys, select VAM from the Geometry sub-menu, and use the Menu Right key to
increase the value to obtain a slight overscan.
7. If other Geometry adjustments are needed, proceed to the necessary adjustment using the Menu Up/Down
buttons.
8. Upon completion of Geometry adjustments, press the Menu button to return to the top level SAM menu.
9. To exit the Service Alignment Mode, turn the set off with the Power button on the remote control.
Oct 30, 2007 | Philips 19PR19 19" TV
Panasonic 29 crt tv problems with the geometry
If there is a picture geometry problem, you have to check its Pin Amp section circuit inside the circuit board for any damaged component/s. If this section have any fault, the picture geometry will be distorted. Before adjusting the picture geometry after entering its service mode settings, you have to check this section first. If you want to know how to enter the service mode option window to this set, check this link.
Jan 27, 2013 | Panasonic TC-29P22R 29" TV
A scalene triangle has side measuremnts a=43, b=55, c=30 . Angle a plus Angle b must equal 43. Angle b plus Angle c must equal 55. Angle c plus Angle a must equal 30.
Answer: angle a=9 degree angle b=34 degree angle c=21 degree Explanation: we have, a+b=43............(1) c+b=55..............(2) c+a=30..............(3) from (3) we get, c=30-a...........(4) substituting value of c from (4) in (2) we get, 30-a+b=55.........(5) a+b=43..........(1) (5)-(1) give 30-2a=12 30-12=2a a=18/2=9 degree giving value of 'a' in (1) 9+b=43 b=34 degree similarly giving value of 'a' in (3) c+9=30 c=21 degree
Oct 14, 2012 | TOPICS Entertainment Snap! Geometry...
When I logon to my computer, 2 little error messages come up with the same message: Runtime error 21 025D49D2. I can exit out of one of them, but if I try to exit out of the second one my screen loses...
Having Problems With Error 21?
Cause: Error 21 takes place when the system is misconfigured or its essential files are missing. Such problems occur when a PC is not maintained properly and has accumulated many critical issues that require immediate repair.
Solution: To repair Error 21 correctly, download and install the repair tool below. This tool was design to successfully diagnose, find and fix the problems on your computer.
http://www.restoreguard.com/p/error-21.html?keyword=Error%2021&gclid=CKXWrq7il6UCFS9e7AodYkPWHw
I found this by google.com searched "run time error 21 025D49D2"
it came up with run time error 21....
click on this link above...
good luck...
Nov 11, 2010 | HP Computers & Internet
What are the importance of geometry?
Here are just some answers I was able to search through the web.
  • First, the world is built of shape and space, and geometry is its mathematics.
  • Second, informal geometry is good preparation. Students have trouble with abstraction if they lack sufficient experience with more concrete materials and activities.
  • Third, geometry has more applications than just within the field itself. Often students can solve problems from other fields more easily when they represent the problems geometrically.
  • And finally-a related point-many people think well visually. Geometry can be a doorway to their success in mathematics.
  • because of geometry their so many beautiful buildings
That's the most important part. But read the entire section from this site,
http://www.learner.org/teacherslab/math/geometry/across.html
Credits to this site! :) ;)
Hope this helps. :D
Jun 21, 2010 | Riverdeep Mighty Math Cosmic Geometry...
Wen i switch on it sas grub hard disk error... its
"Grub Hard Disk Error" A minor technical note, if you don't mind. The error message is "Grub Hard Disk Error", about which the Grub manual has this to say: "The stage2 or stage1.5 is being read from a hard disk, and the attempt to determine the size and geometry of the hard disk failed." To resolve this problem, the manual then suggests that: "The general way that the Stage 1.5 handles errors is to print an error number in the form Error num and then halt. Pressing <CTRL>-<ALT>-<DEL> will reboot." ... which isn't really a suggestion at all. What's really going on is that your BIOS is buggy, and it's lying to GRUB about the geometry of your hard disk. You need to update your motherboard's BIOS with the latest version from the manufacturer. You can can do this by getting the latest version of the BIOS and your manufacturer's reflashing utility from their website, copying it onto a bootable floppy, and running it according to the manufacturer's instructions. You can download a FreeDOS boot disk image for this, if you don't have a DOS boot floppy available.
Jan 10, 2010 | Computers & Internet
Yahoo Error 21
Yahoo error 21 is a javascript problem somewhere on the page. Yahoo says it is your problem not their's. Yeah right! Ever since Yahoo started JavaScriping everything on the page Yahoo mail has been flaky and turned into a P-O-S
I'm slowly moving over to Gmail as it is rock stable.
Jul 13, 2009 | Yahoo Mail
Error code 21
There are 3 step to repair 21 error
If you got 21 error then there is a 94% chance that your computer has registry problems. To repair 21 error you need to follow the steps below:
* Step 1 - Download a Perfect Optimizer,install this error repair tool.
* Step 2 - Click the Repair All Button.It will scan you pc for Free.
* Step 3 - Then click the Repair All Button again and your done! It is very easy to repair 21 error.
Jun 09, 2009 | Yahoo Mail
Same Problem Again - Mega Raid.... Unknown Error
Hi
The title of your post suggests that you have "Maga RAID" errors. Maga RAID messages would be in line with issues on the LSI PERC sub-system.
However, the extract posted in your suggests network problems.
Any number of physical to driver and configuration issues can result in network problems.
Try the basic checks;
1. Change or try a known patch cable
2. Run "ping" test to a known good system connected to same network switch or direct connect with a "cross-over" cable and check for dropped connections.
3. Is the NIC and switch set to Auto-Negotiation or static at 10, 100 or 1000Mbps speed
4. Can you try another switch
5. Check and load correct or latest manufacture's drivers
Reply with more info.
Mike
Jan 23, 2008 | Dell PowerEdge 1800 Server
ASUS K501J WXGA HD 15.6" LED Panel Logo
55 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
