Question about Whirlpool AWM6100 Front Load Washer
Where do I put bleach on the whirlpool awm 6100
Hit it again
  • 13 Answers
SOURCE: Whirlpool AWM 6100/s - stopping
Yeah. This is a pump problem. Our machine first did this about 3 months ago. I took the filter plug out and removed about 10 coins from around the pump impeller area! I removed the pump and dismantled it. Unfortunately water was getting in past the seal on the pump spindle. I cleaned it all out and reassembled it. Worked fine till a couple of weeks ago. It has worn out the spindle "bearings" and because of the loose play it gets stuck, intermittently. If you are by the machine when the drain cycle starts , you can give the filter housing a few bangs(take off the circular cover) . The pump will start up .It makes a grumbly sound, as it is knackered. But once started will generally keep going.The answer however is a new pump. And probably a pact with everyone in your household to be more careful not to leave stuff in the clothes you put in the machine. Our washer has got through 2 mobile phones. a packet of bradding nails, a lot of cash, both coins and notes.Various other stuff that i wont mention! The pump gets very hot when it is trying to turn but cant because of debris on the impeller. This will lead to the pump failing after a time.
Posted on Jan 27, 2010
SOURCE: Front loader washing machine AWM 6100 Whirlpool
check brushes on motor. how old is machine?
Posted on Feb 01, 2010
  • 56 Answers
SOURCE: Front loader AWM 6100 - door open light flashes and won't wash
I think it may have try and get your local engineer out to have a quick look tell your thinking of buying new and what price can he supply 4. and you like a free estimate .
Posted on Feb 11, 2010
BIKER T
  • 909 Answers
SOURCE: I have a Whirlpool AWM
Very possible the door latching mechanism is faulty because when door is closed the contacts in the switch will see condition is correct for operation and light will extinguish. With power plug pulled out, remove the lid and buy using a small screwdriver try and wedge the doot latch open from the inside. Possibly it will need to be broken off to remove. Once off, door will open then replace with new one.
Posted on Aug 05, 2010
allbrands
  • 600 Answers
SOURCE: whirlpool awm 6100 Our machine is
Hello, Thank You for using FixYa. I will be helping you today. Is the unit making it through the wash and rinse part of the cycle? Did you open the filter on the front to make sure it is not blocked up? The start flashing could be a sign the door is not being closed all the way and coming open enough to pause the cycle also. These are based on the model # AWM6100 and not the duet number.
Thank You and please rate my answer if it was helpful..
Posted on Jun 22, 2011
Whirlpool AWM 6100/s Front load washer
Sounds like the front door switch has come out of place, or the actuator is out of place. If you can take the front cover off to get to this switch, you should be able to get it back into place pretty easily. Hope this helps, chad
Nov 01, 2008 | Whirlpool AWM6100 Front Load Washer
I require an operation manual for a Whirlpool AWM302
The Whirlpool UK site has support for the AWM 302. The direct link to the manual is http://docs.whirlpool.eu/_doc/501910006566GB.pdf . If this isn't your model, start at http://www.whirlpool.co.uk/support/instructions-for-use/instructions-for-use.content.html and click on Search. Then search using the Commercial code box. (There are also washers with the commercial code AWM 302/3 and AWM 302/4.)
I hope this helps.
Jun 03, 2012 | Whirlpool Washing Machines
Whirlpool awm 6100
It will be one of 2 things, a faulty inlet solenoid or an electronic controller issue, If you have a multimeter you can test the voltage supplied to the inlet solenoid and if there is voltage being supplied the valve is faulty, if there is no voltage then it is the electronics.
Mar 06, 2012 | Whirlpool Washing Machines
Do you have instructions in English?
Hi.
Please click in the link below to open Whirlpool download page. To get the user manual for Whirlpool AWM 6100 in PDF format put "AWM6100" where it says "commercial code" in the Whirlpool page search form:
Whirlpool manual locator.
Here also a copy of the service manual for the same washer.
Regards.
Ginko
Sep 10, 2011 | Whirlpool AWM6100 Front Load Washer
I have a Whirlpool AWM 6100. The light indicating door is open is on, however there is nothing obstructing the door and is is closed? Won't work with this light on, and can't open door!
Aug 05, 2010 | Whirlpool Washing Machines
Feb 11, 2010 | Whirlpool AWM6100 Front Load Washer
How do I clean the filter
unscrew the circular cover, pull the filter out and clean it. water may come out.
Sep 01, 2008 | Whirlpool AWM6100 Front Load Washer
Whirlpool AWM 6100 wont let in water?
this may sound silly but is the hot and cold hoses around the right way
Feb 18, 2008 | Washing Machines
Whirlpool AWM6100 Front Load Washer Logo
18 people viewed this question
Dan Webster
Dan Webster
Sal De
