Question about Misty Harbor Woman Belted Rain Coat Trench Coat Sz 10 Zip Out Lining
I am trying to find replacement buttons for my Misty Harbor trench coat. Thay are very ornate and lavender blue in color, Is there a website I can search?
Where do the color numbers for coats and clark come from because i can't find these numbers to purchase the thread
Hello, Jenia -
Coats & Clark creates the thread colors and the numbers to identify each thread color.
However, I don't think "where do the color numbers for coats and clark come from" is REALLY your question.
Apparently, Coats & Clark made major changes with their thread colors and numbering in 2009. See the information here:
http://sewing.craftgossip.com/new-coats-clark-thread-colors-plus-new-numbering/2009/06/23/
and read this Coats & Clark blog article:
http://www.makeitcoats.com/us/new-thread-colors-numbers-2/
This is a link to a Coats & Clark thread color number cross reference chart, listing the pre-2009 thread numbers and the corresponding new thread numbers:
http://ep.yimg.com/ty/cdn/sewingwarehouse/sewingsupplywarehouse-com-coats-200-to-s900-color-conversion-chart.pdf
The chart was created by SewingSupplyWarehouse.com .
In the blog (link given above), author Lynn Browne writes, "If you find yourself running out of thread in the middle of buttonholes or topstitching with a color that was retired, or that isn't an exact match-contact us through the website and we will try to help."
This is the link to the Make It Coats Contact Us web page:
http://www.makeitcoats.com/us/contact-us/
The Click Here to Contact "button" in the lower left corner will lead you to a form you can complete to send an email.
Best wishes.
Feb 20, 2018 | Sewing Machines
I am home this weekend and I decided to paint my living room. Is there an amount of coats that you are needing to put on the wall? It has been a while sense I have painted. I heard maybe about 3 to be...
if the existing paint is a light color and you are doing the same color, then 2 coats should suffice,. Painting it darker, I would go 3 coats, painting it lighter, you may need to go more than 3 go to harbor freight tools and buy some plastic drop sheets, masking tape {blue} and some cheap brushes and roller and tray, turn on some tunes and a glass of wine, enjoy the "me time" depending on the quality of paint too will determine the coats needed, ask your home depot guy. behr brands are good cover paints. good luck have fun.{ps..wear some old clothes}
Oct 15, 2013 | Corel Paint Shop Pro 9
Realistic TRC-459 manual
  • Hi Marc. There really is no free users manual online for this CB. But if you go here http://support.radioshack.com/support_electronics/26577.htm there will be options you can click on. It's basically the manual split up into links. It will tell you everything about your radio and the pages are printable just the same. You will see what I mean.
  • Hope this helps.
Nov 25, 2011 | Radio Communications
Prebleached hair to 9G-Applied Inkworks over this with purple . Turned out so blue and a horrid lavender gray on some parts of hair. Why Very uneven and certainly not the color that was expected.
your hair may have been over processed and the lighter parts didn't hold the color. had you colored before the bleaching at all? As for it being blue, purple is a mostly blue base, if your hair was porous at all it will grab the base and hold onto it. and as for being a 9g , purple neutralizes gold so you got the more neutral of the 2.
May 02, 2011 | Paul Mitchell INKWORKS CLEAR semi...
Brakes go to floor, I replaced brake pads, master cylinder and calipers. We have bleed the brakes and bleed the brakes and still pedal goes to the floor.an my anti brake light is on What are we missing?...
Hi chances are the master cylinder still has air in it.If thay put plastic bleeder hoses and fittings in there for you just throw them in the trash.go to your local parts store and buy steel lines to for it,you may need an adapter for one of the ports. and re bench bleed your master cylinder.You could have air traped in the system too.A vacuum pump with a brake bleed kit work's great for this.Thay are 24.99 at harbor freight I just baught one from them.If you don't have a harbor freight in your area,thay are on line at www.harborfreight.com. Hope this helps you.Thank You for using fixya....iluv2fish.......Ray.......
Jul 09, 2010 | 1991 Nissan Pickup
Colors not right
one of your ink cartridge is running out try to replace the cartridge...
Jun 04, 2010 | Canon PIXMA iP5000 InkJet Photo Printer
I need to know the color code of my 2000 ford f150 radio
Look in the driver's side door jamb. There should me a sticker with the details of your truck.
At the bottom you'll see EXT PNT:
Mine says EXT PNT: SU
I believe SU is the the color code. You can probably order the paint from the dealer, or any good paint supplier can get you the equivalent.
Remember that paint can fade and change color over time, so if you're not a pro painter, blending the bright, new color will be very hard to do; you might as well just paint the entire panel or the whole truck if you're not already going to.
Feb 27, 2009 | 2000 Ford F150 Flareside SuperCab
Color Printing Problems
Are these non-original cartridges by any chance?
We've had this problem - try oiling the cogs
Nov 09, 2007 | Konica Minolta magicolor 2300DL Laser...
Color change
I had my stk's replaced, was able to take out the board and brought it to a tv repair shop, the fellow replaced the circuits and re soldered the circuits and heat sinks. Circuit Barn- Auburn, Mass. Jeff Murray did a great job. Reinstalled, and 56 point convergence, tv looks as good as new. I was disappointed too, because the set was purchased in december of 2002.
Nov 05, 2007 | Toshiba 42H83 42" Rear Projection...
HP f1903 LCD Monitor mild flickering & color variance
I would bet it is the cable or connection. Have you tried connecting the monitor to a different PC?
Feb 14, 2007 | HP Pavilion F1903 19" Flat Panel LCD...
Misty Harbor Woman Belted Rain Coat Trench Coat Sz 10 Zip Out Lining Logo
76 people viewed this question
Top Misty Harbor Clothing Experts
ray gallant
Da Doc
Bill Boyd
Are you a Misty Harbor Clothing Expert? Answer questions, earn points and help others
