Question about Toshiba Satellite 1400-S151 Notebook
CMOS RTC Battery Toshiba Satellite 1400cmos battery
  • 624 Answers
SOURCE: CMOS or RTC battery for this laptop : can it be replaced
Hi AshishB, Yes, Toshiba does refer to the CMOS battery in their literature as the real time clock battery. Your retailer is half right, the battery is on the motherboard but its attached via a connector and it can be replaced. Here are links to a couple of venders that sell the RTC battery for your laptop: - Http://www.sparepartswarehouse.com/Toshiba,Satellite,L15-S104,Laptop,Batteries-Backup-RTC.aspx - http://cgi.ebay.com/Toshiba-Laptop-motherboard-battery-cmos-L15-S104_W0QQitemZ170060189842QQihZ007QQcategoryZ3666QQrdZ1QQssPageNameZWD1VQQcmdZViewItem Let us know if you have any other questions and please don?t forget to rate the posting.
Posted on Jan 19, 2007
  • 624 Answers
SOURCE: Toshiba 6100
Unfortunately it is a fairly involved procedure, one of the more complex I?ve seen for a newer laptop. If you don?t have prior experience, tools and some nerve I?d suggest you take it to a shop. Some of the more challenging parts you are going to remove are the keyboard, the top half of the case, the wireless card and some of the wiring harness. -Remove the battery pack, any PCMCIA cards, the optical drive and the hard drive. -Open the laptop and carefully pry the keyboard holder (thin piece of plastic at the top of the keyboard. Toshiba has a special tool for this but in times past I have been able to successfully remove other Satellite Pro series keyboards with a plastic probe. Once that is off remove the two retention screws at the top of the keyboard, carefully disconnect the cable and remove the keyboard. -With the keyboard removed you will see the wireless card torx security screw at the top just to the left of center. Remove it, the cover plate and the card underneath. In order to remove the card you will also have to disconnect the white and black coax leads. When removing and reassembling note that these connectors are really small and fragile. -Flip the laptop over and remove all 15 screws. There are three different types so mark down where they go for reassembly later. -At the rear of the computer you will find 2x screws, one to the right of the VGA connector and the other in-between the serial and lpt1 port; remove them as well. -You will have to disconnect several leads and wire harnesses in order to lift off the top half of the case. -Once the case is removed the RTC battery is in the lower right hand corner. -Now all you have to do is reassemble the laptop and test. Good luck and don?t forget to rate this post.
Posted on Apr 16, 2007
SOURCE: cmos battery
if a laptop its usually a shrink wrapped green sleeve with 2 wires red and black and connector on end, the silver cr232 (looks like giant watch battery) is a p.c. cmos battery, flips out if you push on two retainers ive just replaced my notebook rtc battery on a tosh a50 it involved taking full base of with a little memory of were screws go! as if wrong screw and to long nice lumps on inner of your lappy, last thing isolate either p.c. or laptops power including battery as to avoid damageing or killing your board easyiest way of understanding..............
Posted on Sep 15, 2007
  • 32 Answers
SOURCE: bad cmos battery
Search in Google for How do I change the cmos battery in a toshiba satellite 5100
Posted on Jul 03, 2008
  • 10 Answers
SOURCE: want to replace cmos battery in Toshiba Satellite A10
On Toshiba laptops you hit the ESC key as soon as you turn it on & then you
are given the option to hit the F1 key to enter bios.
As to the cmos battery, they couldn't have hidden it better if it was the Queen's diamond!
It is near the bottom of the laptop on the right side, almost directly beneath the pause/break key.
Problem is, you have to disassemble the entire laptop to get at it!
Disassembly instructions for the Satellite A10 are here
http://www.irisvista.com/tech/laptops/ToshibaA15/SatelliteA15_laptop_disassembly_1.htm
Best of luck
Barb
Posted on Mar 03, 2009
How do i change a cmos battery in a toshiba 1425?
Here are the instructions for a similar laptop.Step 24 is the key to removing the cmos battery (rtc battery)http://pinout.net/disassemble/content.php?nid=173
best regards,abdielfort lauderdale network support
Nov 19, 2011 | Toshiba Computers>Laptops Satellite A10 PC...
I have a toshiba satellite r15-s822. I am trying to remove the bios password. I removed the rtc battery. Is there another cmos battery on the motherboard? What am i doing wrong?
To reset the BIOS read the information from this link.
In case of your Toshiba Satellite R15-S822 laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery (which is on the motherboard) or the jumper.
Dec 10, 2010 | Toshiba Satellite R15-S822 Tablet PC
I have a Toshiba Satellite 1415-S173 with a bios password I don't know (original owner is deceased). How can I bypass or remove?
Remove the CMOS battery from the motherboard. Turn it over, open it up, and look for a little watch battery.
Oct 31, 2009 | Toshiba Satellite 1415-S173 Notebook
Where is the CMOS battery located in a A65-5126 Toshiba
Cmos or (RTC) battery is located on the main board and can be accessed by taking the palm rest off the lower case.
Sep 06, 2009 | Toshiba Satellite A65-S126 Notebook
Jan 18, 2007 | Toshiba Satellite L15-S104 Notebook
Toshiba Satellite 1400-S151 Notebook Logo
18 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
