When you say short, it means to most people that you have intermittant connection in the cord, and one would say, replace it with the same or better type cord. If you are good at soldering, wire splicing and crimping, it should be fairly easy to separate the base using Security Torx Bits (i.e. tamper resistant screws are used), and a bit of judicious patience. Once appart, if they use crimped or solder connections you can cut, splice and crimp as needed. Your cord will be a bit shorter and you will have to reindex the strain relief service loop, but it should be painless. If you are not confident working with UL listed safe equipment (your loved ones will be using this appliance) you can get it serviced here:
California Electric
Service in Concord CA (it is the only Rowenta repair station in California) go to either of the following addresses:
their website is:
http://www.californiaelectricservice.com/ or tech service:
[email protected]
