Question about IBM Rdx 160GB/320GB Cartridge 46C5375 46C5366 (883436045803) Media
IBM RDX Cartridge 160GB/320GB - IBM Rdx 160GB/320GB Cartridge 46C5375 46C5366 (883436045803) Media
I am using K8S MX Motherboard with OS-Windows XP. but my hard disk is not working. i want to purchase a new 160gb IDE hard drive. please tell me if it supports 160gb hard drive or not
The specs for this motherboard say it has a Utra-DMA 133, and 2 SATA 3Gbs ports.
You can connect any IDE HD, and any SATA 3 or lower HD. These standards are backwards compatible. When it comes to size, there is a 2TB MBR limit.
I would skip IDE and go directly with a SATA 3 drive.
http://www.asus.com/Motherboards/AMD_Socket_754/K8SMX/#specifications
GL
Dec 11, 2012 | ASUS K8S-MX Motherboard
Installing a new larger hard drive, and it will not accept it?
Wait a minute! Hold the phone!
HOW, are you trying to install this 320GB harddrive?
You cannot just grab a fresh, new harddrive, and put it in. There's no Operating System on it. It's on the 160GB harddrive.
(Windows XP?)
Not trying to 'sound' condescending, but I do not see anything to support that you know what you are doing.
If you are using a Western Digital 160GB IDE harddrive, you have a motherboard, and BIOS, that is past the size limitation for an IDE harddrive.
The size limitation was 137GB for motherboards, (BIOS program, actually), that had this limitation.
Size limitation isn't your problem.
Plus, LEAVE BIOS ALONE, as far as upgrading.
Why?
A) Power goes out while you are upgrading, and when asked, you do not save a copy of the original BIOS program, you can take your motherboard out, and use it for a Frisbee.
B) IF, there was a BIOS upgrade, AND it is NOT compatible, AND when asked you do not save a copy of the original BIOS program, you can take your motherboard out, and use it for a Frisbee.
Also, if it IS an IDE harddrive, and the old 160GB is an IDE harddrive, you cannot put both harddrives on that flat ribbon cable, AND use the 320GB as a Primary harddrive.
Want to use the 320GB as a Primary harddrive, (Master), and the 160GB as a Secondary harddrive? (Slave) There is a proper procedure.
No, I'm wrong? You have a fresh, new GENUINE copy of Windows, and are going to install it on this 320GB?
[Microsoft makes one Master disk. From it all GENUINE copies are made, and sold to the consumer ]
I hope it is Windows XP, (Home or Pro)
Why?
Because drivers are not be available for Windows Vista (Yecch!), or Windows 7.
What are drivers?
Small pieces of software that allow the Operating System to communicate with a device.
Windows XP and Windows 7, are just two examples of an O/S.
Harddrive, motherboard chipset, optical drive, (CD/DVD drive), audio (Sound), etc., are Devices.
http://support.gateway.com/us/en/emac/product/default.aspx?tab=1&modelId=1460
Winfast is no longer in operation. No help from them.
(The motherboard manufacturer that made the motherboard for eMachines/Gateway. Confusing? Yes, I know.
eMachines sold out to Gateway. Guess what? Gateway SOLD OUT to Acer. Isn't this fun(?)
The motherboard is a Gateway MCP61SM2MA. Part number Gateway 4006232R.
http://support.gateway.com/s/MOTHERBD/Shared/4006232R/4006232Rnv.shtml
1) Has one Parallel ATA connector on the motherboard.
[PATA. Term is also known as IDE. Just to be more confusing, it is also known as EIDE. Enhanced IDE brought out by Western Digital, back in the day. The reason PATA is used, is to help distinguish it from SATA.
Serial ATA. This will help you understand,
http://en.wikipedia.org/wiki/Parallel_ATA ]
On the main Gateway support page I linked above, click on ->
Product Views.
In the list click on the blue -> Parallel ATA IDE connector.
2) The motherboard also has two SATA connectors,
http://en.wikipedia.org/wiki/Serial_ATA
On the Hardware Details list, click on the blue -> U - SATA connectors
Do not know if it is a PATA harddrive, (320GB), or a SATA harddrive?
Look at the label. Example on WD 160GB might be WD1600BEVT.
What is it on the 320GB?
Blank, new 320GB WD harddrive? BIOS isn't going to recognize it.
Why?
It hasn't been formatted.
WD does have a software tool to do this. Do I recommend this for a beginner? NO.
Better to install the 320GB in an economical external enclosure, and plug the USB cable from the enclosure into any available USB port on your computer.
Now you have a 160GB harddrive with WinXP on it, and 320GB's of extra storage.
Example (IMHO) of an economical external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1733195&CatId=2779
If you have no clue of what I have posted above, it is going to look like so much gibberish. Not my intent.
Not after 'Points'. Could give 2 cents.
{With this website you can rate ANY solution you see, and ALL solutions you see}
My intent is to teach. I have been at this for 8 years. (3 here, 5 elsewhere)
I want you to understand. Post back in a Comment, with the answers I need, from the questions I stated above.
We together WILL find a solution.
Regards,
joecoolvette
Jun 20, 2012 | E-Machines Computers & Internet
My IBM X201 can't install itune
does it give you an error. anything please be more specific
May 10, 2011 | IBM TOPSELLER X201 I5560M 266G 2GB 160GB...
Lost the power adapter for my SimpleTech 160GB external hard drive. Where can I get one? DL
You can use any 12V, 2A tip positive adapter. You can find one at Best Buy, Radio Shack, etc.
May 09, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
Just updated my disk drives from 2 160gb to 2 320gb. system sees all 640gb but only partioned 160gb. please help I have a sony vaio
Create another partition in the free space using a partition software like
http://www.partition-tool.com/
Jan 05, 2011 | Sony VAIO RB54G (VGCRB54G) PC Desktop
The compaq presario v3000 replace hard drive
Yes of course you can install the Seagate Mementus 160GB, the laptop will take a dive with a 320GB capacity.
Regards.
Dec 02, 2009 | Compaq Presario Notebook
How to install ThinkPad 160GB 7200 rpm Serial ATA "hard drive on a ibm thinkpad T60 serial # 1952
Here is a video on how to remove it. Look at how they remove it and try to do the reverse with the new hard drive. Hope this helps.
http://www-307.ibm.com/pc/support/site.wss/MIGR-63909.html
Nov 09, 2009 | IBM ThinkPad T60 Notebook
Upgrade hard drive from 40GB to 160 or 320?
A computer can handle any amount of Hard disk. The speed and performance of the computer depends upon the way you use it. It is possible to replace the harddisk by youself. Here is a guide : http://www.fonerbooks.com/laptop_1.htm
Jun 19, 2009 | IBM ThinkPad T30 2366 Notebook
WD Scorpio Black 320GB SATA drive
Halarious, I had the same problem yet I used norton ghost. At least you still show 160 gb. Mine went all the way to 60 gb. Here is what I had to do to reclaim the lost. I downloaded something called "Magic Boot Disk" It gave me the whole 320 back yet have not found good cloning software yet. Magic Boot Disc is freeware avaliable at http://hddguru.com/content/en/software/2006.02.10-Magic-Boot-Disk/ Good luck cloning
Feb 21, 2009 | Western Digital (WD3200JS) 320 GB Hard...
IBM Rdx 160GB/320GB Cartridge 46C5375 46C5366 (883436045803) Media Logo
24 people viewed this question
Top IBM Electronics - Others Experts
Are you an IBM Electronics - Other Expert? Answer questions, earn points and help others
