Question about Canon PC-D340 All-In-One Laser Printer
Cnet.com i have tried to change the drum together with the rear unitbut still gives e 100 syetm erroe
What is the cause of OKI C3200n fatal error 173
Fatal error code 173:
This error indicates that the Image Drum Up/Down Process is not working properly. The errors are as follows:
140 - Yellow Drum Up/Down error
141 - Magenta Drum Up/Down error
142 - Cyan Drum Up/Down error
Solution:
1. Reseat the Image Drums. Ensure they are in seating properly into the drum carriage.
2. Reseat the Toner Cartridges. Ensure they are seating properly into the Image Drums.
3. Reseat the Contact Sensor Spring assembly and inspect it for damage or mis-alignment. If the springs appear bent or dis-lodged reseat them.
Aug 12, 2014 | OKI C3200n Led Printer
Where can I find Acer 661fx-m71.2a ethernet controller? can anyone give me links?
http://download.cnet.com/intelv13-zip/3000-2112_4-195759.html
  • Intel 82557-based Integrated Ethernet PCI (10/100)
  • 82557-based Integrated Ethernet with Wake on LAN
  • Intel 82558-based Integrated Ethernet
  • Intel 82558-based Integrated Ethernet with Wake on LAN
  • Intel(R) PRO/100+ PCI Adapter
  • Intel(R) PRO/100+ Management Adapter
  • Intel(R) PRO/100+ Server Adapter
  • Intel(R) PRO/100 Network Connection
  • Intel(R) PRO/100 VE Desktop Adapter
  • Intel(R) PRO/100 VM Desktop Adapter
  • Intel(R) PRO/100 VE Network Connection
  • Intel(R) PRO/100 VM Network Connection
  • Intel(R) PRO/100 VE Desktop Connection
  • iSeries 2892 10/100 Ethernet Port
  • Intel(R) PRO/100+ Alert on LAN* 2 Management Adapter
  • Intel(R) PRO/100+ Alert on LAN* Management Adapter
  • http://download.cnet.com/intel82573l-zip/3000-2112_4-165111.html
  • if these arent right you will find ethernet drivers and more
  • http://download.cnet.com/2000-20_4.html
  • on the home page you should see a search tab just type in what you are looking for
    (be precise)but don
  • Oct 04, 2011 | EliteGroup 661FX-M7 (661FXM7V11)...
    The usb ports on my sahara notebook are not working.
    It could be that the driver of the usb ports for your syetm isnt working well or not here at all.please follow the link below to download a new one for your system.
    http://download.cnet.com/windows/usb-drivers/
    Sep 22, 2011 | Computers & Internet
    How do I put back together the rear drum?
    These are standard Bendix self energising rear drum brakes. Pictures of the assembly with exploded views can be seen here....
    http://www.pbase.com/nufsed/drumbrake
    The real difficulty with doing the re-assembling is not where the parts go, but getting it all back in place. There is a technique to use. If you have problems, get back here again.
    Apr 16, 2010 | 1999 Chevrolet Cavalier
    The drum wont rotate, is it belt driven from the motor, if so how do you get in to change? cant get lid off
    take the back panel off to get to ure belt, but first put ure hand inside ure machine n spin the drum if there is no strain wen tryin t spin the drum n the drum feels very light to spin ure belt has snapped if there is abit of strain u will need ure motor brushes changing
    Feb 03, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
    I have 293 errors on my computer i was wondering if their is any way that i can repair all these erros without purchasing any more software that is easy?
    hi there
    i read your report. I'm going to give you a site that will take care of this problem for you.
    Advanced SystemCare Free - Free software downloads and software ... This utility offers a one-stop-shop for cleaning and maintaining your computer
    for better overall system performance. http://download.cnet.com/Advanced-SystemCare-Free/3000-2086_... - 76k - Similar pages
    Nov 30, 2009 | Microsoft Windows XP Home Edition
    Cannot close the internet screen or go into
    go to the site and download the shown program. Preferrably on another computer. I believe yours is infected with malware. Intsall, update and run the program. when it runs, choose the quick scan and let the syetm get scanned. When the program finishes it will ask you to show the results, click on that button and whatever infections it finds, it will post. Make sure they are all checked and delete all it finds. Reboot the computer and try to browse once again.
    http://download.cnet.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html?tag=mncol
    Nov 29, 2009 | Toshiba Satellite P105-S6104 Notebook
    Update: Rear brakes drum 2003 ford winstar.
    due to some reasons the rim is out of shape. so change the rim and then try using the brakes
    Sep 22, 2009 | 2003 Ford Windstar
    Drum life remaining
    All you need to do is open the front door and press either the options button or menu button, whichever you have, it will ask you if you changed drum, just answer yes, and you're good to go...
    Sep 14, 2009 | Brother DCP-7020 All-In-One Laser Printer
    How do I change the drum bearings?
    The only 100% solution is to replace the whole rear tub half complete with bearings, you may also need to replace the drum shaft as well, because any slight wear on it will lead to premature falure of the bearings.
    Nov 21, 2008 | Zanussi F1045W Front Load Washer
    Canon PC-D340 All-In-One Laser Printer Logo
    254 people viewed this question
    old marine
    old marine
