Question about Frigidaire Dryers
FFSE5115PA i have the frigidaire dont work say the error e61
3 Suggested Answers
  • 574 Answers
SOURCE: Frigidaire affinity front load dryer e61 code. Replaced the control board and display board. Still have the same problem e61. How do you check heater relays?
ther is a thermocouple next to heater elements , check continuity of elements and thermocouple
Posted on Mar 22, 2012
goodwinpeg
  • 744 Answers
SOURCE: Error code E61 shows on my Frigidair Affinity washer. Do you know what E61 Means?
Hello Murray;
My name is Peter. I am a retired field service appliance technician.
Hi E61 means that the control board is sensing an incorrect/abnormal voltage present at its input.
1.) Unplug the unit for 5 minutes. If the error comes back -
2.) Lets check your power cord:
a.) Unplug the machine. Is the middle connector on your power cord connected to 'N'?
b.) Tighten all the connectors. Make sure you have a good ground.
c.) Check the voltage. Between 'L2' & 'N' = 110V, 'L1' & 'N' = 110V, 'L2' & 'L3' = 240V.
3.) Lets check your control board for shorts:
a.) The following link will show you how to access. Ground yourself by rubbing your hands on bare metal. Static electricity will knock out a board.
b.) Check all of the connections, push in on the wires at the connectors.
c.) Reassemble and try to start
http://www.applianceblog.com/manuals/5995413084_Washer_2004.pdf
4.) Well, if none of the above solved the problem, you have to replace the control panel.
Part #: 134523106 - Cost: $168.00
Posted on Dec 08, 2014
Replaced heating element now I get error E61, I ohmed out the thermostat on top of heating element seem to be ok
Hello Louie, I appreciate your inquiry!
Based off the information you have provided your Frigidaire dryer is displaying an error code of "E61" after you have replaced the element. An "E61" error code means that there could be an issue with your heater relay or main control board. You may need to seek additional assistance from a professional technician for proper diagnosis and repair. This will help you avoid any unnecessary part purchases. I hope this information is helpful to you. -Matt
Mar 28, 2016 | Frigidaire FASE7073LW Affinity 7.0 cu ft...
Replaced circuit board and i have heat but still shows e61 code
Hello friend, thanks for your post!
Based off what you have described your Frigidaire dryer is displaying an error code of E61. I understand that you have replaced the circuit board and you are still receiving the error code. An E61 means that your heater relay as had a failure which could be a potential problem with your heater relay or a wiring harness. You may need to seek professional assistance with proper troubleshooting this will help you to avoid any further unnecessary part purchases. If you need help locating a local technician you can visit your manufacturer's website for a list of available technicians. -Matt
Aug 05, 2015 | Frigidaire Dryers
I have a Frigidaire Affinity electric dryer model number FASE7021NW0. It suddenly began giving error code E61. I called frigidaire. they said it was likely a shorted wire and put me in contact with an
I appreciate your post, Doug Anderson! From the information you have provided your Frigidaire dryer is displaying an error code of "E61". "E61" stands for heater relay failure which could be a problem with wiring, heater relay, or main control board. I would recommend performing a reset on your dryer and you can do that by disconnecting the power cord for ten minutes. This should help clear out any potential false error codes. Hope this information is helpful. -Matt
Dec 20, 2014 | Frigidaire Dryers
Hello... I have a Frigidaire Affinity electric dryer model number FASE7021NW0. It suddenly began giving error code E61. I called Frigidaire. They said it was likely a shorted wire and put me in contac
http://www.manualslib.com/manual/417069/Frigidaire-Fase7073lw.html
you can read the error code E61 here
it says its a heater control relay or the heater element is duff
its prob corroded and worn out and needs replaced
"Check for short circuit across heater relay(s) (RL5, RL6, RL7)
or L1 applied to heater relay output(s) (J5-2, J7-1, J7-3)
with cycle stopped. Check for open circuit between L1 and heater relay connection(s) (J5-1, J5-3, J7-2).
If no wiring problems are found, replace Electronic Control Board and retest"
you can download the schematics etc also in the same manual
i think you need a tech too look at the heater now you know whats up
I am getting E61 code on my Frigidaire Affinity Dryer model number FASE7073NA, how do I clear this error code?
Good Morning Friend, thank you for your post!
An error code E61 on your Frigidaire dryer is associated with a failure in the heater relay. A qualified technician would pinpoint the problem by checking the wiring for both open and short circuit across heater relay(s). If the wiring isn't the issue, he/she would need to determine whether the problem rest with the main control board. It really could be a hit or miss calculation in parts so I would personally reach out to an experienced tech that will be able to identify the precise reason.
May 27, 2014 | Dryers
E61 Error code Frigidaire Affinity dryer?
Good Afternoon Friend, this is Z. Thank you for your post!
If you are receiving an error code E61 on your Frigidaire Affinity dryer, first check if it is a false error code by resetting the power to your appliance by either unplugging it or flipping off the breaker for about ten minutes. If the error code persists, it could potentially mean that your dryer is experiencing a failure with the heater relay. This is not a typical DIY job. I would recommend reaching out to an experienced appliance tech just to ensure no troubleshooting step has been missed. You can often locate a qualified service provider through the manufacturer website.
Best regards.
Apr 25, 2014 | Frigidaire Dryers
E61 shows up and it wont heat up
Hi Carrie, this is JK. I understand that you are experiencing an E61 error message on your dryer. Typically this error could mean that there may be a failure in the heather relay. I would recommend having a professional check the wiring. If no problems are found, you may want to consider replacing the Main Control Board. Hope this helps!
Mar 16, 2014 | Frigidaire Dryers
I have a Frigidaire Front Load Washer (FAFW3801LW) that is registering an error code and continuously beeps on and off at random times. I held the start/cancel buttons and E61 or Eb1 popped up. I assumed...
check in the manual for the error code most of washing machine if the error code is in users manual its means its only minor problem,but if the error code is not in users manual its means you need to call an service technician to not waste your money or time if you do by your self.
Nov 01, 2013 | Frigidaire Washing Machines
Dryers Logo
54 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
