Question about Refrigerators
Westinghouse rj390m defrost timer location - Refrigerators
SOURCE: Fridge timer location
THREE DIFFERENT LOCATIONS FOR DEFROST TIMERS ON
MOST REFRIGERATORS.
1 BEHIND THE REFRIGERATOR IN THE COMPRESSOR COMPARTMENT.
2 BEHIND THE TOE PLATE LOCATED ON THE FRONT BOTTOM OF THE REFRIGERATOR.
3 IN THE FRESH FOOD SECTION WITH THE CONTROLS
ON SOME NEWER ELECTRONIC MODELS, THE DEFROST IS
PART OF THE ELECTRONIC CONTROL LOCATED BEHIND A PANEL ON THE BACK OF THE UNIT.
Posted on Apr 01, 2008
22yooper
  • 828 Answers
SOURCE: Defrost timer
http://www.us1internet.com/FRS24XGCW2_141846.htm
The above URL will take you to an exploded view of the controls. Look at number 23 which will be located behind toe plate below door on the left side. That is the defrost timer. Rotate the clutch head screw Clockwise SLOWLY until you hear a loud click. That is the defrost timer starting the defrost. If the unit restarts after 18-22 minutes and defrost does not take place you problem is most likely the defrost thermostat.
Posted on Jun 20, 2008
Krazytech
  • 725 Answers
SOURCE: defrost timer location
need to know the make and model...
GE are in the top right back
Frigidaire are under the toe plate left and right also in the back by the compressor. cheaper frigdaire are in the middle center top refer... so you see they hide them in a lot of places..
Posted on Aug 25, 2008
  • 531 Answers
SOURCE: Location of Defrost Timer
you unit do not carry it carry a board it at the back off the unit
Posted on Apr 01, 2009
rylee_smith
  • 8619 Answers
SOURCE: WHERE IS THE DEFROST TIMER LOCATED ?
Hi
The defrost timer is sometimes found behind the front grill of the refrigerator. It may also be found behind a cover plate inside the refrigerator or freezer, in the temperature control console, or behind the refrigerator near the compressor.
The timer is usually held in place with one or more screws. Remove the screws and gently pull the timer out far enough to disconnect the wiring connector.
Locate the timer switch and turn it clockwise until you hear it click. One click and the refrigerator shuts off = defrost mode, second click the compressor and fans come back on = run/cooling mode.
*Some defrost timers are a constant or continuous run timer, which means when ever the refrigerator is plugged in the defrost timer is powered up and running. Some defrost timers are an accumulative run timer, which means when the refrigerator is off the defrost timer is off and not running, when the refrigerator is running the defrost timer is running. This is also sometimes called a demand defrost. The power for the defrost timer goes through the cold control first on an accumulative defrost system. The timers are often the same but will be wired differently to get the different operations.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on May 31, 2009
Where do I find the defrost timer and main thermostat in a Westinghouse Virtuoso RS643T side by side fridge?
Go to www.repairclinic.com and enter RS643T. With luck, you will be presented with a list of common replacement parts and may be able to view a generic disassembly video showing parts location.
Dec 14, 2017 | Westinghouse Refrigerators
Westinghouse model RS663T - not cooling fridge or
IT IS THE DEFROST THERMO STAT REMOVE REAR COVER AND MELT ICE IT IS ROUND SILVER PART
Jan 31, 2010 | Refrigerators
My defrost heater is not working. Westinghouse
You did not mention if your unit was 120VAC or 220VAC parts replacement mandate you know exactly which it is your searching for as far as replacement part sources.
120VAC US parts source
220VAC UK parts source
Most often a Defrost problem is one of the following:
1. Defrost timer (there are 4 terminal timers MECHANICAL and Multi terminal ELECTRONIC timers) Any generic Defrost timer will work as long as you know the input voltage and the number of require terminals match.
2. The 60 Deg Thermostat
3. The actual heating element
This company ships international USPS
Welcome to A-1 Appliance Parts We are the ultimate source for the do-it-yourselfer appliance repair person. USA Phone 1-800-841-0312
Here is a link to multiple Defrost timer examples. You should be able to match yours up with the images on this page. It may take a while but you can do it.
http://www.appliancepartsworldwide.com/Store_SearchResults.aspx?S=Defrost%20timer&ST=BIP
After a US Westinhouse search I get the feeling you may have to do a web search for "appliance repair parts UK" I hope this was of some help. (Last time I was in your area was 1997 US Navy....)
Jan 28, 2010 | Westinghouse Refrigerators
Location of defrost timer for frigidaire side by side
REMOVE BOTTOM FRONT TRIM UNDER FRONT DOORS
THE TIMER I BELIEVE IS ON THE LEFT SIDE YOU WILL SEE TWO PHILIP SCREWS REMOVE AND UNPLUG THE WIRE HARNESS FROM TIMER AND VOILA!
Jan 19, 2010 | Frigidaire Defrost Timer 215846602 ...
Where is the defrost timer located on a Frigidaire model # FRS24WNF?
its a defrost trermostat located near the evaporator coil and defrost heater coil
Oct 24, 2009 | Frigidaire Defrost Timer 215846602 ...
Water/condensation in both dairy tray and bottom of fridge
My guess is you have a blocked defrost drain. The water instead of going down its drain goes down the backside of the frig and pools up under the crispers. Blow out the defrost drain. The only other thing to look for is bad door gaskets.
Dec 16, 2008 | Refrigerators
MOST REFRIGERATORS.
Mar 30, 2008 | Refrigerators
Refrigerators Logo
83 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
