Question about LG WM-2277HW Front Load Washer
WASHING MACHINE TAKES IN AND GIVE OUT WATER AT THE SAME TIME
    New Friend:
  • 66 Answers
Kindly hang up drain hose 2,1/2 feet,,
Posted on Feb 22, 2014
2 Suggested Answers
SOURCE: washing machhine takes water and then switches of
I have a front loading whirlpool that did the same thing, I removed the bottom cover,then where the drain hoses go is a filter trap. You unscrew the cover, pull out the trap, clean out the loose change and junk,then screw the trap back on and your good to go.Make sure you try to get as much water out as you can, because what ever is left in the washer will come out as soon as the trap cover is removed.
Posted on Jan 30, 2009
I have a kenmore front load washing machine that water shuts off after 5 seconds. Timer continues to count down but nothing happens in the machine. Timer also takes about 3x longer to get to zero.
Troubleshooting Appliances: Washing Machine and Dryer ...
www.realestate.com > Realestate.com Blog > Articles
Sep 16, 2012 - If your washing machine or dryer seems ready to give up the ghost, follow ... When you start your washer, a solenoid-operated water inlet mixing valve ... Afront-loading washer lacks the agitator, instead using the tumbling ... Clothes Remain Wet After the Spin Cycle. 1. .... Bought washer/dryer second hand.
Oct 19, 2015 | Kenmore Washing Machines
Tip
Washing machine takes a long time to end cycle.
When a washing machine takes a long time to complete the cycle, that means that one of the conditions required to complete the cycle takes a long time before being met or detected.
In simple words this means that, depending on what part of the cycle the machine hesitates, you are in one of the following conditions:
1 The water inlet is blocked or restricted.
2 There is a water heating problem, usually thermostat not detecting temperature correctly.
3 There is a drain blockage and drain takes longer than usual.
4 The pressure switch used to detect water level is defective, and timer board does not detect that drain is complete and keeps draining for a while.
1 If possible move the machine and check the inlet hose at the back, ensure that there is pressure, that the hose is not restricted or blocked. Check also for blockage at inlet valve.
2 This must be tested removing parts from washer and using a multimeter. The job is better done by a technician.
3 You can check the drain pump. On most front loader models this is accessible opening a panel at the front lower side of the washer, under the door. On top loads the pump is accessed from behind (also some top loader), and from underneath the washer. Instructions are often described in the manual. The hose or filter housing can be removed to check for blockage.
4 Same as 2, the pressure switch is replaced when there is long drain or water level related problems.
Disconnect power before performing any maintainance.
As first step check warranty status by contacting the manufacturer at the number listed on manual. Long cycle is a fault condition, if your warranty is still valid, manufacturer will send an authorized technician at their expenses.
Here a practical description of the problem. Article is referring to a Maytag Neptune: washing machine takes an unusually long time to complete
on Sep 15, 2010 | Washing Machines
It takes long to fill with water
Holly, there are a number of reason why your washer may be taking a long time to fill. Some of them are very easy to fix. Can you give me the model number of your machine?
Jan 22, 2015 | Washing Machines
Water fills slowing in washing machine, kenmore ultra fabric care
Check the water inlet valve. If there is a problem it can cause a slow fill condition. Unplug the machine, turn off the water and remove the water supply hoses. Check the small metal screens inside the openings on the valve. Make sure they are clear of rust or debris. The solenoids can be tested using a multimeter or ohmmeter. A lack of continuity means a bad solenoid and the valve assy will need replaced. I will attach a photo for reference. Hope this helped and best wishes.
Oct 04, 2009 | Kenmore 24032\24036 Top Load Washer
TAKES HOURS TO GO THROUGH THE CYCLES
Please check that the inlet filter for the water is not blocked, reduced inlet of water will extend the wash and rinse times by a considerable time.
Run the machine with the water turned off at the fawcet that will take the pressure out of the hose
Switch off the machine
Unscrew the connector at the back of the machine which holds the supply pipe in
Look in the hole which is revealed is ther a load of bits of grit and gunk in there , if there is pull out the filter and give it a wash under a tap.
Jun 05, 2009 | GE WSXH208A Front Load Washer
I got a washing machine ''Admiral''Model 7010 i can not operate properly. It takes too much water and time as well.coulkd you pls send me the instruction manual so that i could save time and water. thank...
make sure the standpipe the washer drains into is higher than the water level in the machine and that the drain hose is not pushed too far down into the pipe as this may cause syphoning increasing cycle time and water usage.
May 04, 2009 | Admiral AW22 Top Load Washer
Washing machine problem
If I remember right the washer has err codes on it. Does it bring up anything?
Feb 27, 2008 | Fisher and Paykel Fisher & Paykel Washer
Zanussi fx1465W not working
the machine should make humming noise,before it takes in water check water feed to machine get back if you cant sort it
Nov 28, 2007 | Washing Machines
LG WM-2277HW Front Load Washer Logo
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
