Question about Fossil Watch Style # AM4145 Watch for Men
How to change the battery of my watch Fossil 10 ATM ch2869
indays
  • 111 Answers
SOURCE: i have a fossil blue
to change the battery of fossil blue watch,just open the case back and remove the old battery,look the number size on the battery and put a new battery that same number size ,after replacing battery press the case back tight to avoid water damage !good luck
Posted on Aug 25, 2008
indays
  • 111 Answers
SOURCE: need to change the battery
good morning ! if your watch is waterfroop design that`s have a tread so if you want to open the case back you need a wrench or opener, but if your watch is snop in design you need a knife to open the case back,and change the battery,thank you,
Posted on Aug 27, 2008
escapement
  • 2334 Answers
SOURCE: Need to remove links in metal watch band Fossil 10
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Jul 15, 2009
SOURCE: reduce size of band for fossil 10 atm
how to set my FOSSIL 10 ATM watch... I should set the date and the day with only one button plss
Posted on Jan 02, 2010
  • 2501 Answers
SOURCE: I Have a fossil 10
Your watch is 12 hours out of step.
The date changes every second time the hour hand passes 12 O'clock.
Your watches' second pass is at midday instead of midnight, so to make it operate correctly, you need to wind it on 12 hours. The date will then change at midnight.
Posted on Jul 13, 2011
How to change battery on fossil watch
The best thing to do is take it to a jeweler and let him change it.
Jan 01, 2018 | Fossil Watches
Is the fossil fs4813 waterproof
yes, to 50 metres
Fossil Men's FS4813 Grant Stainless Steel Watch with Leather Band ...
https://www.amazon.ca/Fossil-FS4813-Grant-Stainless-Leather/dp/B00AFTTQ8I
Rating: 4.5 - ‎50 reviews
Tang clasp. Water resistant at 50 meters / 165 feet. Casual watch style. Fossil Grant Chronograph Black Dial Brown Leather Mens Watch FS4813.
Grant Chronograph Brown Leather Watch - Fossil
https://www.fossil.com/us/.../grant-chronograph-brown-leather-watch-sku-fs4813p.ht... Rating: 4.6 - ‎91 reviews - ‎US$115.00 - ‎In stock
PRODUCT DETAILS. Collection: Grant. Movement Type: Quartz Chronograph. Case Size: 44mm. Strap Material: Genuine Leather. Water Resistant: 5 ATM ...
Water Resistant Watches, 10 ATM Watches ' FOSSIL
https://www.fossil.com/us/en/******/10-atm-watch.html Water Resistant Watches up to 10 ATM. Fossil Hybrid Smartwatch - Q Nate Dark Brown Leather Ftw1114. Quick Look. Fossil Hybrid Smartwatch
Is the fossil fs4813 waterproof Google Search
Aug 16, 2017 | Fossil Watches
What size battery does fossil 10 ATM use
Take your watch to a jeweler who will open it and identify the type.
Feb 17, 2017 | Fossil Watches
How do u open back to fix an fossil black 5 atm fs-4351 hand watch
Jerry, If its smooth on the back cover, you have to pry it off carefully. Get a magnifying glass and look around the cover edge, there should be a small under cut. Pry at this point with a penknife blade or similar. If the cover has 6 or 8 small indentations in it then it likely unscrews but you may still need to see a watch shop for the tool to unscrew it.
Fossil watches have a 2 year warranty so if its inside this, take it to a dealer.
Nov 03, 2014 | Fossil Watches
Link removal of a Fossil 10 ATM
Take your watch to a jeweler.
Jun 23, 2014 | Fossil AM Watches
How to change a fossel ATM 10 battery
Take your watch to a jeweler for a demonstration.
Apr 13, 2014 | Fossil Watches
I Have a fossil 10 atm watch & the date doesn't change automatically so i change it manually but then half way thought the day it changes the date
Jul 13, 2011 | Fossil Watches
Can the glass piece of my fossil 10 atm be replaced?
Yes, it can be replaced.
Just head down to the nearest Fossil store and they will help you do it. If it is still under warranty, it will be free-of-charge.
Mar 04, 2011 | Fossil Watches
How do i set the time on a Fossil 10 ATM watch?
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all FOSSIL watch manuals.Rate me, please..
Mar 29, 2010 | Watches
Reduce size of band for fossil 10 atm
Dec 25, 2009 | Fossil Watches
Fossil Watch Style # AM4145 Watch for Men Logo
150 people viewed this question
Top Fossil Watches Experts
Ansel Alberto
Ansel Alberto
Jimmy Accardi
Are you a Fossil Watch Expert? Answer questions, earn points and help others
