Question about Roomba iRobot Scooba 230
My scooba 230's bladder is leaky. How to fix this?
Need new rubber tube for pump
Based on my measurements with a caliper, the inner diameter (ID) is about 3.5mm and the outer diameter (OD) is about 4.5mm. Length of tube is just shy of 60mm. Hope that helps! IF you find any sources for this tubing, please post more information.
May 21, 2015 | Roomba iRobot Scooba 230
Tip
IRobot Scooba Guides Tutorials how to total maintenance
IRobot Scooba Guides Tutorials to all you ever need to Fix and Maintain
on Apr 26, 2014 | iRobot Scooba 380 Robotic Vacuum
Scooba 390 "Charger Failed"
If this is a new Roomba make sure that the Battery pull-tab has been completely removed.
Dec 06, 2013 | Roomba iRobot Scooba 390 Floor Washing...
Scooba 230 not going straight
Sounds like you have something rapped around the wheel, take a good look at the inside of both wheels. Take a knife or sissors and cut it out.
Nov 29, 2013 | Roomba iRobot Scooba 230
Scooba 385 - Making Grinding Noises - Video I
there are no parts available for these ( toys ) so called vacuum cleaners. Sorry you wasted your money.
Oct 10, 2013 | iRobot Scooba 350 Robotic Vacuum
I fixed my scooba's check tank problem, now it has the service light on and keeps beeping 4 times
amber it might be a valve stuck get a straw and blow air into the solution valve under tank on right or try droping scooba 2 inches from ground as this might reset the ball valve .
Apr 25, 2009 | iRobot 5800 Scooba Vacuum
Roomba iRobot Scooba 230 Logo
286 people viewed this question
Top Roomba Vacuums Experts
NOEL
NOEL
Lonnie Arks
Are you a Roomba Vacuum Expert? Answer questions, earn points and help others
