Palsonic tv sound on DVD drops out below a certain level. background sound disappears when dialogue and music not present
  • Paul Carlyle
    Paul Carlyle Jan 05, 2014
    To me it sounds like what is called a 'noise gate' in music recording terminology. Anything below a certain volume or frequency threshold is cancelled out. this is used a lot on noisy insruments like drums where there is a lot of 'bleed', to keep sounds seperate. But I can't see what purpose it would serve on a TV.
Nightdiver
  • 116 Answers
SOURCE: dialogue vs. background music and sound
The on-screen menu appears only when the selected source is DVD or VCD on the DVD/VCD/CD player and the disc is in the slot and NOT PLAYING. On the remote control ONLY: 1. Press CHOICE (it should work now) LANGUAGE menu appears. 2 Press Cursor to move to the menu you want? which is AUDIO Selected item changes its color to green. THEN: 1. Display EXPERT SPEAKER SETTING menu. 2. Press Cursor to select ?TEST TONE,? then press ENTER. ?TEST TONE? changes its color to green and test tone comes out of in the following sequence?left front speaker, center speaker, right front speaker, right rear speaker, and left rear speaker. ? Test tone is output only when the tray loaded with a DVD is selected, but not playing. 3. Press Cursor to move to ?C.SPK? LEVEL? or ?R.SPK?LEVEL,? then press ENTER. 4. Press Cursor to adjust the output level, then press ENTER. ? You can adjust the output level from ??6 dB? to ?+6 dB.? 5. Repeat steps 3 and 4 to adjust the other speaker output level. 6. Press Cursor to select ?TEST TONE,? then press ENTER. Test tone stops. 7. When finished, press Cursor to move to ?EXIT,? then press ENTER. EXPERT SPEAKER SETTING menu disappears. I hope this helps you, please let us know. Best regards, nightdiver
Posted on Jun 14, 2006
SparkGap
  • 363 Answers
SOURCE: background sound too loud
Check the audio settings. You might need to reduce the surround sound effect or increase the Center (dialogue)
Posted on Oct 21, 2007
Agent Jon
  • 100 Answers
SOURCE: emerson dvd player - background sound lauder than dialogue
Greetings surfjax,
If you will allow me to make an assumption, you do not have a 5.1 surround system connected to your DVD player. This is a common experience with users of a standard TV or stereo receiver if a movie is being presented in 5.1.
In a surround sound system the center channel speaker provides almost all the vocal tracks while the side channels will provide music and some background noises. You'll still be able to hear the voices in your side speakers, but it will be muted and over powered by music or sound effects.
Some DVD players allow you to "Downmix" the surround signal to stereo. You might want to look around your sound setup on the DVD player or check your owners manual.
Hope this helps.
Jon
Go Ahead. Use Us.
Posted on May 22, 2008
  • 46 Answers
SOURCE: dvd player
I assume the above problem is on all DVD's. Generally speaking, dialogue soundtrack is located in the Front Center speaker. From your description of the problem I would double check all the wiring to the front center speaker you have connected to your audio system. If there is no front center speaker, check to see how your audio system is set to handle the front center speaker . . . it should be set to "Phantom" or "none". On the other hand you're relying just on your TV speakers and you're not getting any dialog I would change, under the Settings of the DVD player, the Digital Out settings to PCM.
Posted on Jan 20, 2009
  • 1779 Answers
SOURCE: Music on DVDs is louder than the dialogue.
In the Audio set up menu, see if there is a setting to turn off surround sound. I believe it's in your owners manual also. LMK
Posted on Feb 28, 2009
Only background sound, no dialogue when playing blu ray
do you have a center channel speaker hooked up? Most dialogue in movies should come from the center channel.
Feb 28, 2014 | Onkyo TX-SR605 Receiver
Denon dvd-2900 suddenly has music and background sound but no dialogue
Is there subtitles instead of the dialogue? Sorry, may be an obvious thing that you have already checked.
Jan 22, 2012 | Denon DVD-2900 DVD Player
When I use the headphones listening to TV, I get the background sound (eg music) clearly but the dialogue is very low and drowned out by the background music or ambient sounds
It's because the TV's audio is stereo and the dialogue is mono split between two channels. When dialogue hits your headphones the majority of the mono signal gets cancelled. Try a different set of headphones or watch true stereo channels... IE movie channels
Apr 18, 2011 | Bose QuietComfort 2 Acoustic Noise...
Sound for DVDs
Turn Off or change surround sound mode in DVD system to get vocal sound (dialogues) in speakers.
Jun 03, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Feb 28, 2009 | Philips 32PFL5403D/27 32 in. LCD TV
Dvd player
Jun 09, 2008 | Sanyo DWM-390 DVD Player
Emerson dvd player - background sound lauder than dialogue
Greetings surfjax,
Hope this helps.
Jon
Go Ahead. Use Us.
May 22, 2008 | Emerson EWD7003 DVD Player
DVD Audio
check your connections. My PS2 does the same thing. The connection on the rear is touchy. Sometimes the sound will be garbled.
Jan 03, 2008 | Panasonic DVD-S52 DVD Player
Background sound too loud
Oct 21, 2007 | Protron PLTV-37 37 in. LCD Television
Dialogue vs. background music and sound
Jun 13, 2006 | JVC MX-DVA9 Shelf System
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
