Question about Troy -Bilt String Trimmer/Blower Attachment #41AJBT-C966
Troybilt TB75SS String Trimmer will only run choked to partially choked. I can throttle it and it runs rough but will accelerate with about 1/4 choke. less than that it dies. Not much smoke I expect I should see more. I suspect I need to richen the mixture. No obvious mixture screw found. There are two small cam type devices in top of the carb. One red the other white. They may be some sort of mix adjustment. Any idea where I can find a manual for this?
  • 3 Answers
I was having the same problem I replaced the spark plug and cleaned the exhaust a bit. Mine had an adjustment screw on the carburetor (facing up) and I adjusted it while it was idling with full choke. When I screwed it IN (down) it increased the throttle ... I went too far and the engine raced a bit but continued to run (roughly) after releasing the choke. I turned off the engine and backed out the screw a bit and restarted. It seemed to idle normally and then I was able to slowly increase the throttle and the engine run. I noticed that there was air in the gas lines and figured it could be because I only had little gas in the tank. I put the plastic housing (with air filter) back on, filled the tank half full and restarted. I still ran roughly for a bit but I was able able to slowly increase my throttle until it reached half power and then it ran fine. I went ahead and did 30 minutes worth of trimming and it was like new. I will see if starts and runs ok from cold but at least it ran today. I had not seen anyone mentioning the adjustment screw.
Posted on May 03, 2010
  • 1,040 Answers
It sounds like your carburetor needs a good cleaning. You must disassemble the carb., clean all the ports with a small Den Tech Brush, (used for cleaning between teeth). They are very small and perfect for this job. You will also want to clean the small screen in the carb. It may be so clogged that it may need to be replaced. If this is the case, you will need a carb.kit for your Troybilt Trimmer; it comes with small parts and gaskets. (It will come with some gaskets that you will not need.) Replace all old parts with the new ones. This should fix your problem.
Posted on May 22, 2009
  • Jim Parker
    Jim Parker May 31, 2009
    Did this solve the problem?
    Jim
I have a Troy-Bilt XP grass trimmer...only run on full choke, I replaced the fuel filter because there was plugged.Still no help. I ordered a new carb and replaced it and still had the same problem.
When you installed the new carb did you adjust it for your engine? Idle control, idle mixture, fast misture? Running only with choke indicates that engine is not getting enough gas routinely via the main jet.
Sep 22, 2017 | Troy-Bilt Garden
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
Dec 09, 2015 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Fixing straight shaft attachment on Troy-Bilt string trimmer
Here is a link to sears parts direct. You can see prices for all parts and make a decision from that.
TROYBILT Trimmer Boom and trimmer Parts Model TB75SS
Aug 16, 2014 | Troy-Bilt Tb75ss
Troybilt Engine wont accelerate
The machine is running too lean on the fuel mixture, if the fuel filter in the fuel tank is clean ( replace if needed ) then you can unscrew the H screw on the carb to richen it up, you may need a special tool to turn the screw if it is an anti tamper type.
Jul 08, 2013 | Troy-Bilt 25cc 2-Cycle Curved-Shaft Gas...
Weedeater dies when you open choke
After you start it and are in the second stage of the choke (half choke ) let it run for awhile until it warms a bit then try openning choke and going to full throttle.
May 21, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
32 cc string trimmer will not run
It sounds like you need to adjust the fuel mixture screw in the carb. To do this, while it is running adjust the screw in either direction until it runs properly without the choke.
Sep 10, 2009 | Craftsman 25cc Gas Line Trimmer
Troy-Bilt TB75SS 31cc string trimmer dies when given throttle.
Your carburetor needs cleaned. Disassemble carb. and spray with carb. cleaner. Make sure that the small screen is free of debris. Use a Den Tek Brush,
(http://www.dentek.com/shop.php?target=products&product_id=7), to clean the small portals in the carb. Reassemble and start. If this doesn't work for you then you will have to buy a carb. kit and replace all appropriate parts. If you need further assistance, just let me know.
Jim
Jun 07, 2009 | Troy Bilt Tb70ss Gas Trimmer
Weedeater starsts and ildes won't run or accelerate
Make sure your gas supply is fresh...not from last year...
Secondly, clean and service the air filter element... you may need to reoil it before installation...check your manual.
Disconnect the fuel line and drain it and what little is in the carb...push on the prime bulb if it's got one...
Then with a clean air filter and fresh gas... give it a start and after start, disengage the choke..
Let me know how you do..
K
May 28, 2009 | Troy Bilt Tb70ss Gas Trimmer
Troy -Bilt String Trimmer/Blower Attachment #41AJBT-C966 Logo
2,792 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
