Question about Whirlpool Heating & Cooling
The aircon does not keep its temprature what could the problem be? it keeps on jumping to 29"
  • 85 Answers
Is this a central AC or window unit?
Posted on Jan 03, 2014
I have air conditioner/heater will not come on after working for a while this morning.i alreaetdy tried reset button and doesnt help
if the aircon is running to heater and the temprature outside is really cold [ sorry do not know the exact temp] the evaperator at the back will ice up and stop the aircon from working.if this is the case you just have to wait for the ice to melt. hope this helps cheers
Oct 19, 2013 | Haier Heating & Cooling
AEG SANTO S 70178 TK38
check fan operation. have a pressure test done on the cooling system to check for gasket problems . have a flow test done on the radiator to check for blocked cores
Jul 18, 2013 | Cars & Trucks
It's 30c outside, we're trying to get cool and the aircon is blowing out air that isn't much cooler. I have the remote set on 21c with an icicle showing, but the conditioner is saying 29. I don't know...
In some models, setting temp flashes for 5 seconds, while setting. And then what it shows is room temp.
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil & out door coil are cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5.Check compressor is working with correctpressure. keep your arm on suction line (bigger pipe) in out door unit. If you feel chillness, pressure in compressor is o.k. otherwise, leak or short of gas. Call repairman to rectify.
Thanks. Helpful?
Feb 04, 2011 | Heating & Cooling
Temprature control
I suggest turn it to lower temperature, so that water won't drip down. You can get rid of the hardness by keeping those things out of the unit for about half an hour before using, so that it may lose some coldness and become soft.
Jul 05, 2010 | Fisher and Paykel Active Smart® E522BR...
BMW X3 aircon belt problem--keeps jumping out of crakshaft pulley
if air con belt runs off the pulley inspect the crankshaft damper pulley, it may be broken!
the air cond belt is a stretch belt with no tensioner!
Jan 21, 2010 | 2005 BMW X5
Audi a3
Does it keep running till the batt is flat? It could be the aircon condenser fan running - on the left as you stand in front of the car. This is a common prob with A3s of this age.
I have a '05 3.2L Quattro V6 and suffered the same prob. The batt is in the boot of the V6 and is sealed like Fort Knox so impossible to disconnect. After about 3 days with this the fan running constantly and having to put a charger on it every night I let the batt run completely flat to try and reset the complete system - no DIS lights - no starter motor clicks - DEAD. Then I jump started it and the prob disappeared completely. Everything is working perfectly ncluding the aircon. That was 4 days ago and 'touch wood' I've had no probs since. I know this won't work for everyone but it's worth a try before forking out £300+ for a new condenser fan unit. Good luck!
Oct 19, 2009 | 2005 Audi A3
Whirlpool fridge freezer alarm s20D RSB33AG-B
Hi, you have a common problem with your control boards; there is a cheap fix if you can use a soldering iron or you can have your modules repaired.
Let me know
bb
Aug 31, 2009 | Whirlpool Freezers
Water filter froze solid
Your refrigerator compartment temprature is below 32 degrees and freezing your water in the filter. Adjust the thermostat setting to a higher temprature setting using a thermometer in the referigerator as a refrence. 34-37 degrees is a good temprature range to keep food fresh.
Jul 31, 2009 | Refrigerators
Radio and aircon dont work change fuse but keeps poping
you have a short circuit somewhere in those to areas... advance trouble shooting is required to find which one is causing the problem.
Robert
Sep 06, 2008 | 1999 BMW 328 Series
Heating & Cooling Logo
26 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
