Question about Hobart ET27 4-Slice Toaster
One slot only toast one side of the bread slice.
One slot toasts only one side of the bread slice?
  • Anonymous Mar 17, 2014
    2 of the four slices - next to each - other stopped working. Other 2 slots are fine
  • Anonymous Mar 23, 2014
    Does not toast both sides of slice of bread
    Problem Solver:
  • 11 Answers
You may need to replace your toaster, but don't worry, just go to the following address:
http://shopping.msn.ca/results/toasters/bcatid1150/forsale?text=category:toasters
Posted on Dec 06, 2007
Does not toast bottom side
you have to turn the bread over to toast that side .
Mar 16, 2015 | Rival 4 Slice Toaster Oven
For HB 22708 Toaster Oven: Will it toast both sides of a slice of bread at the same time?
Yes, the Toastation works like a traditional toaster in the top slots. If it is not toasting both sides like a regular toaster then there is a problem. If that is so and if it is still under warranty, then contact the company for repair. If it isn't under warranty, then find a local repair business.
Mar 29, 2011 | Hamilton Beach 22708 Toaster Oven with...
The bread only toasts on one side (each piece)
I take it it that the outside is being toasted and not the part between the slices? That would mean that the element that is shared by the two slices has burnt out. Check with a dealer for a replacement.
Jan 20, 2011 | Hamilton Beach Eclectrics 22111 / 22112 /...
My 2 month old 2 slice toaster only toasts one side of the bread in one slot. Other slot is OK!
The heating element on one side is faulty. If it's only 2 months old, I'd return it -- this is likely not a simple fix.
Charlie
Aug 23, 2009 | Kitchen Appliances - Others
Toaster only toasts on one side
Please ensure that the "Bagel" function is not selected (LED is not lit up). The Bagel function will toast one side of the bread while only warming the other side.
Mar 13, 2009 | KitchenAid KTT261 Ultra Power Plus 2-Slice...
Only toasts part of bread
The solution I got from the FixYa team was: "Get a new toaster." Which is how I ended up with 4 new toasters that don't work. I'm glad I didn't PAY for THAT answer.
Sep 04, 2008 | Cuisinart CPT-140 Cool Touch 4-Slice...
Duraband 4 slice toaster manual model # TS-5221
if u need a manual for a toaster, then u r really in trouble...espcially for the amt of money u paid for it.
ok...
if u need instructions on how to use a toaster...here goes:
When:
A toaster is used to heat slices of bread, bagels, waffles, etc. to a hot, crispy consistency. Most toasters allow the user to set the toasting length to ensure the toasted bread comes out to temperature and crispiness to the user’s likes.
Where:
Toasters should be used on a flat, uncluttered surface near an electrical outlet but far from sinks, or running/standing water.
How:
To toast bread in a toaster, follow these instructions:
1. Place slices of toast, one each, in the slots on the top of the toaster.
2. Find the toast setting (a knob or lever) and adjust to the desired wellness of the toast. (Generally, there is a scale printed near the knob or lever ranging from light to dark toast).
3. Push down the toasting lever (moving the slices of bread down into the toaster between the heating elements.
4. When the toast is finished, the slices will “pop” up automatically.
5. Remove the toast from the toaster.
WARNING:
If the bread should get stuck inside the toaster, DO NOT PUT ANYTHING INSIDE THE TOASTER in attempt to dig it out. UNPLUG the toaster, turn it upside down and shake. If the toast does not fall out, use a plastic fork or knife to gently remove it from the toaster. Using metal utensils could damage the heating elements. NEVER stick anything in the toaster while it is plugged in.
*For further safety, it is recommended that the toaster be unplugged after each use.
I wish u luck and happy toasting.
Oct 14, 2007 | Kitchen Appliances - Others
Only toast one side of the bread
The other side that isn't toasting has an open element. Usually, the good side will burn twice as hot, and may have stressed that element. You might want to replace both in that slot. make sure you check the voltage rating plate. 208 and 240 volt toasters use different elements.
I just posted the procedure to replace elements, in a similar post here.
Oct 12, 2007 | Hobart ET27 4-Slice Toaster
Hobart ET27 4-Slice Toaster Logo
396 people viewed this question
Top Hobart Kitchen Appliances - Others Experts
Colin Stickland
Colin Stickland
Dennis Boxerman
Darial Jr Lasaria
Darial Jr Lasaria
Are you a Hobart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
