Sound drops out after 1 minute or so. Change channel and sound is on but then drops out again?? Only started after I moved house. Conia plasma.42".
  • 19,396 Answers
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Posted on May 22, 2009
  • Ginko
    Ginko May 22, 2009
    Sorry I sent you the solution for a different problem by mistake.
    In your case start checking the cable connection to receiver, try moving or replacing cables.
    If you have a surround with external speakers check surround connection cable and speakers wiring.
    If the cables are OK, then the unit may be faulty.
    In that case the fault can be either the audio board (often audio circuit is integrated on the main board) , or the sinput output signal board.
    Also a contact on connection to internal speakers can give you same problem.
Picture just went out on my tv but I still have sound
I have the same problem with my HP PL4260N 42" Plasma HDTV serial # CNH6141988, model # CPTOH-0602. I have perfect sound and can change channels still with sound but NO PICTURE. I am a consumer with a question that need the advise of an expert.
Apr 17, 2013 | HP PL4260N 42 in. Plasma HDTV
Have sound...No picture whatsoever.
Have you tried unplugging the TV for a minute and then plugging it back in to cause a reboot? (After restarting you would need to scan for digital channels again.)
Jun 15, 2010 | Maxent MX-42V1 42 in. Plasma Television
TV- some channels don't have any sound, other channels do
RE TUNE UR TV AGAIN AND LET IT FIND ALL THE CHANNELS.......IF PROBLEM PRESISTS CALL PANASONIC SERVICE AND TELL THEM OR PROBLEM U HAVE IM SURE THEY WILL TELL U WHAT TO DO .........OR MAY OFFER U FREE SERVICE......WHAT WILL BE UNDER THE WARREN TIE U HAVE FOR 12 MONTS
Nov 20, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
VIZIO LCD VX20L, intermittant video/audio with Blue screen message "No Signal"
If the tuner is bad, changing the mainboard should fix the problem.
May 18, 2009 | Vizio VX20L 20 in. LCD TV
No sound on one channel
check your remote for a a audio button alot of times certain channels like PBS only plays in one sound It will be the button that changes the Mono/Sap/Main settings for audio or it could be a issue that network is having
Apr 28, 2009 | Hitachi 42HDS69 42 in. Plasma Television
LG DU-42PX12X Plasma, picture startes flashing then goes black after a few minutes
You need to get this tv service asap.i beleive that the problem is in the inverter board or yb board.
good luck
caypianan@yahoo.com
Oct 25, 2008 | LG 42PX5D 42 in. Plasma HDTV
No signal on digital TV
If you are talking about over the air digital channels I would lean toward ant problems
Apr 26, 2008 | Televison & Video
Plasma TV problem - My Plasma tv is having a serious problem. Suddenly the Red color is no longer Red but Orange. The picture looks much worse now. I know it may sound like the set was getting old but I...
Try checking the cable making sure they are tightly plugged in. My dads Plasma screen started showing orange / brown colors in place of primary red... he had been moving things around and didnt realize the wires were loosened in the process. This made him realize.... GET an HDMI and get rid of all the other cables......
May 07, 2007 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Help - 15 mth old 42" edtv "plasma" black screen" have power and sound
it could be 1 of 2 things, the panel could be shorted or the logic main board could be out, you must open the back and take voltage measurements, check the panel voltages and then start pulling the connectors off one at a time, to see if the voltages come back up
Nov 22, 2006 | Vizio P4221 Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
