Question about Motorola Mobility RAZR V3i Cellular Phone
Where do I insert sim card in a bz60
How do I insert it, it will not fit
Insert a nano sim card into blu R1HD, the gold side is up or down?
Sim card will only fit one way. The only way it will fit another way is if you force it. Look at the tray you will see the cut out for the nano sim. Now look at the nano sim and match the sim to the cut out. Insert it and press gently. Then slide it into the phone. Also note that the other spot that you are looking at is for a micro sd card so that you can increase the memory. Hope this helps.
Oct 22, 2017 | Blu Cell Phones
How to insert sim card in phone? and which card insert micro sim card or full sim card?
Depends on what phone as to what size. Most phones have the sim card under the back cover....some are under the battery. A few have a small door on either side of the phone. It should be relatively obvious as to which one will fit once you see the sim port.
Jul 18, 2016 | Cell Phones
Nokia 2600c-02 insert sim card
I had that problem with transferring my sim card into my new phone too. It's hard to believe (I know!) but not all sim cards are cut to exactly the right size to fit all phones. My husband got mine to fit by carefully shaving or trimming less than 1/8" off around all the edges of the sim card and then it fit just fine :) Please be assured that this trimming does not interfere with the embedded chip at all.
May 24, 2014 | Nokia 1661 Cell Phone
Unlock generic sim for BZ60
In this case, I recommend you to contact the original service provider for further assistance.
Best Regards
Suny
Motorola Support.
Mar 15, 2014 | Motorola Mobility BZ60 V3xx V6 Maxx
How to fit sim card to ipad
Insert the tip of the SIM eject tool or a straightened paper clip into the hole of the SIM card tray on the side of the iPad.
Press the SIM eject tool or paper clip firmly into the hole until the SIM tray ejects.
Remove the SIM card from the tray, if necessary, and place the other SIM card in the tray.
Push the SIM card tray back into the iPad.
http://www.bing.com/videos/search?q=how+to+fit+sim+card+to+ipad&mid=C532A5A729B9058B83CAC532A5A729B9058B83CA&view=detail&FORM=VIRE6
video insert micro sim card into Ipad
hope this helps
Sep 17, 2012 | Apple Ipad 2 Wi-fi Black 16 Gb Pc Tablet
Does the motorola razor bz60 have a sim card?
I do not believe so. To check for certain, take the back off of the phone, in the back by the battery (sometimes under the battery) you will find a card slot with a small card that can be pulled out and changed. Most media phones do not utilize the changeable SIM card like smart phones.
Mar 01, 2011 | Cell Phones
My phone said to insert sim but ive inserted my sim and tried to take it out and insert it again it still say insert sim
Here's what you have to do.
Maybe your sim card is not well fitted on your sim card port. If you thinks it is well firtted, based from my experience, just insert your sim card as usual to the sim card port and then do that 5 times. (rubbing slowly). and then try to power it on. Just try it. Hope it will work for you..
Nov 29, 2010 | Sony Ericsson Walkman W705 Cell Phone
Instructions on how to insert sim card
hello. there is often a diagram which shows u how to insert the sim card. it will be a little diagram of a box shape with a **** on one side, as ur sim has a **** on one side too. try looking for it. the sim insertion can be under the battery, or more rrarely- thru the side of the phone. dont get confused with where the memory card fits, it is much smaller in size.
May 05, 2009 | Nokia 2680 Slide Cell Phone
Phone doesn't recognize the SIM card
The sim card holder has a tiny slide mechanism. After inserting the sim card and pressing it against the body of the phone, place your finger over the card and slide it gently forward. The tiny plastic part that holds the card will snap it into place. Hard to explain, but it will work.
Dec 17, 2007 | Motorola Mobility V66 Cellular Phone
Motorola Mobility RAZR V3i Cellular Phone Logo
46 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
