Question about InFocus IN2112 Projector
Repair dlp chip - InFocus IN2112 Projector
I have lines and black spots all over display
Most likely you have a failing DLP chip. The DLP chip is the one that forms the image that is projected onto the screen. Search for "Mitsubishi Black Dot" in your search engine and you will see you are not alone. Apparently, a lot of DLP chips in Mitsubishi products are failing. With the low price of projectors these days, your best bet is replacing it. If you want to repair it yourself, the chip will run you about $200 to replace and may require soldering.
Hope that helps,
Bax
Nov 10, 2013 | Mitsubishi EX240U Projector
I have white dots appearing on my veiwing screen.
Its a DLP chip Basically its alot of super tiny mirrors that open and close at various times to produce the image. The dots your seeing are mirrors that have stuck and the only repair is to replace the DLP chip which is easy but pricey 300.00 you can get repair kits with installation instructions from www.tvrepairworld.com
Jan 01, 2013 | Televison & Video
Mitsubishi projector xd50u dlp chip repair
Normally the dlp going bad would be white or black spots. Dead pixels. DMD/DLP is about 200$ from china. I've got a video of the repair on an ex51u
Dec 06, 2012 | Office Equipment & Supplies
Mitsubishi wd60735 white spots apperaing
Thats a very coomon problem which is caused by a failed DLP chip. The mirrors get stuck and thats what causes the white spots they will keep multiplying untill the entire screen is filled. You will need to replace the DLP chip. You can get the replacement DLP chip and illustrated instructions on how to do the repair from www.tvrepairworld.com
Oct 29, 2012 | Mitsubishi WD-65833 65" HDTV
How do I repair stuck pixels on a DLP projector
you have certification in this field or u have knowledge about repairing so try other wise do not try go to technician and they repair your projector
Sep 29, 2011 | InFocus IN102 DLP Projector
Small white dots have started to appear on our screen, first, on, then a couple days later 2 more, and today we have 6 small white dots on our screen. What is happening to cause this condition?
Your problem is that the DMD device is failing. You're in luck, though. Mitubishi has recently released a replacement DMD device in order to keep repair costs down for the consumer. Take your TV to an authorized Mitsubishi servicer for repairs.
Sep 25, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
I have white spots all over the screen
first clean the lens , if it dont help , then your Dlp chip is broken, there is no way to repair this at home because you cant buy spare parts,
May 10, 2011 | Dell 1209S DLP Projector
White dots appearing on Mitsubishi 1080p DLP tv.
Actually you must replace the DLP chip that is buried deep in the works of the tv. Unfortunately this can run into a nice lump of change. Do what I did. Perhaps you've heard the old addage
Mar 05, 2010 | Mitsubishi WD-73734 73" Television
Own a Samsung DLP TV 42 inch and white dots have
The random whit dots you are seeing is more than not the DMD or million little mirrors board. The white spots represent some of the mirrors that are sticking in the on position. In that case they are always reflecting white light from the lamp. I don't concider the DMD board a do it yourself repair since on the older DLP set it requires mechanical alignment as well. The best thing to do is contact a techincian and see what they might charge to repair the TV for you. Please take a few moments to rate my answer...Thanks..
Nov 15, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
White spots are just emerging on my 50 inch Samsung DLP TV everyd
the problem is in the DMD Board is it something like this?
usually this happens to Samsung DLP...
here is a link where you can find a DMD Board Good luck
you will need your part number
http://www.discount-merchant.com/SearchResults.asp?Search=dmd
Aug 01, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
InFocus IN2112 Projector Logo
24 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
